deep 6 (901) question.
Page: 1, 2, 3  Next
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
hanapaa
hanapaa is offline
PostPosted: Fri Mar 02, 2007 11:18 am    Post subject: deep 6 (901) question. Reply with quote
I have a pair of deep 6's part# 901.361.012.06 and it does NOT have hearts. My question is if that's cottect?
Or is the deep 6 with part# 901.361.012.00 ONLY supposed to have hearts? I did a search but there wasn't enough specific information.
MAHALO
Rich's 50
Rich's 50 is offline
PostPosted: Fri Mar 02, 2007 4:02 pm    Post subject: Reply with quote
I have two pairs just like that. They are suppose to have the hearts but i think back in the days people grinded the hearts down, doesn't mean they are not real but they cant hold the same value as ones with the hearts..........
hanapaa
hanapaa is offline
PostPosted: Fri Mar 02, 2007 5:55 pm    Post subject: Reply with quote
Thanks alot Rich I had a feeling it would of been one of you GFK guys to answer that.
I have one more question on that rim...
I put it on my 57 oval today and the inside tire wall was rubbing the shock tower (were the body bolts to the shock tower) is it because I have a short axle trans and you guys have a long axle trans?
scottvw
scottvw is offline
PostPosted: Fri Mar 02, 2007 6:09 pm    Post subject: Reply with quote
There are indeed deep 6's w/o hearts. Not all of them were ground down. I have pics of a 912 on my phone that had all originals w/o hearts.
Rich's 50
PostPosted: Fri Mar 02, 2007 9:18 pm    Post subject: Reply with quote
I'm runing short axle on the split but i had to put 1 inch spacers so it wouldn't rub on the shock bolt. I have deep 6's with 205/70 in the rear and they dont rub at all.
Rich's 50
PostPosted: Fri Mar 02, 2007 9:20 pm    Post subject: Reply with quote
Thats news to me Shocked i never had seen an og deep 6 with a 901 number with no hearts, I'm calling bullshit on that my friend Cool
Bruce
Bruce is offline
PostPosted: Sat Mar 03, 2007 2:07 am    Post subject: Reply with quote
I've seen plenty of them. The very last deep 6s were like that. Check the date stamps and post. They will all be close to each other.
Skim
Rants Master
Skim is offline
PostPosted: Sat Mar 03, 2007 2:20 am    Post subject: Reply with quote
The pair on the back of my split have no hearts. I got fucked on that one because I sent my rims out and when John delivered them he brought like 5 sets over, everybody grabbed their sets and I was left with 2 without the hearts. I got there late and got early owned.
GFK
1953 Kabriolet
1959 Lowlight Ghia vert
joe comfort
joe comfort is offline
PostPosted: Sat Mar 03, 2007 9:09 am    Post subject: Reply with quote
There are 4 right now on e*ay with NR and 2 of them have no hearts, info from seller due to bad pics.
hanapaa
hanapaa is offline
PostPosted: Sat Mar 03, 2007 1:05 pm    Post subject: Reply with quote
Why is it in the other thread http://www.thesamba.com/vw/forum/viewtopic.php?t=67203 they list all 901... part numbers from 4.5's - 7r's but not 901...06 they only mention 6" 901...00 and 901...03?
I got some pics of the numbers on back (not the greatest).
on the top it has the 901...06 part number, bottom left it has AS1 08, fox head and on the right it has 26710.
Is the AS 1 08 the date ?
hanapaa
hanapaa is offline
PostPosted: Sat Mar 03, 2007 5:45 pm    Post subject: Reply with quote
were can I get 1 inch spacers?
Rich's 50
PostPosted: Sat Mar 03, 2007 6:24 pm    Post subject: Reply with quote
Pep boys or any tire shops.........If you cant find them let me know and i will send you some.....
Bruce
Bruce is offline
PostPosted: Sun Mar 04, 2007 2:49 am    Post subject: Reply with quote
hanapaa wrote:
Is the AS 1 08 the date?
No. That is the alloy designation. The alloy numbers on all Fuchs are an internal code that don't conform to any industry standard.
The closest alloy is 6082.
The date code is stamped in between the lug holes, closer to the centercap hole, eg. 1069 for Oct 1969.
mr. warehouse
mr. warehouse is offline
PostPosted: Sun Mar 04, 2007 2:57 am    Post subject: Reply with quote
Wide 5 to Porsche adapters will do the same trick.
hanapaa
hanapaa is offline
PostPosted: Sun Mar 04, 2007 7:14 pm    Post subject: Reply with quote
I found the dates and it says 1270, dec. 70
vdubinit
vdubinit is offline
PostPosted: Sun Mar 04, 2007 10:22 pm    Post subject: Reply with quote
Can you run foxcraft skirts with that set up without any rubbing issues?
**WANTED** ONE 4 1/2 EARLY FUCH
Rich's 50
PostPosted: Sun Mar 04, 2007 10:31 pm    Post subject: Reply with quote
No it rubs on the skirts, i'm running 205/70/15 in the back
vdubinit
vdubinit is offline
PostPosted: Sun Mar 04, 2007 10:41 pm    Post subject: Reply with quote
thanks for the heads up Cool
hanapaa
hanapaa is offline
PostPosted: Sun Mar 04, 2007 10:51 pm    Post subject: Reply with quote
I just got another set of deep's and these have the date stamp of 7 69
(july '69) and yes it does have the hearts. I guess somewere between july '69 and december '70 they changed.
Also I noticed that the outside lip is different. The ones with the hearts have a rounder lip just like the 4.5, the ones with out the hearts have a more square edge (lip) like the late 6".
Rich's 50
PostPosted: Mon Mar 05, 2007 8:21 am    Post subject: Reply with quote
Really, do you mind taking some photos of those areas because all of mine look the same.......
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
Page: 1, 2, 3  Next
