0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3456 Location: OR & CA (Oregon/California)
Posted: Sat Mar 03, 2007 3:25 pm Post subject: tools... tools... |
hi all,
Could anyone please recommend me a good tool set to put in my vanagon... I have a tool box full of mismatched and redundant tools which I want to replace with something that I can bring along on a trip and also use it to do some light repair....
thanks in advance,
dan |
riceye Samba Member
Joined: March 09, 2006 Posts: 1700 Location: Caledonia, WI
Posted: Sat Mar 03, 2007 6:37 pm Post subject: |
In my van:
In my canvas tool bag:
Multi-meter (cheap, small one from Sears).
Jump wire w/ alligator clips.
Combo wrenches - 6mm - 24mm.
Adjustable wrenches 4" and 10".
Vice grips - 6" curved jaws and 8" nut grabbing jaws.
Trusty Snap-on 6-in-1 screwdriver.
Small screw driver.
3/8" 12 point metric sockets w/ rachet, extensions and flex joint.
Spark plug socket.
Tranny fill bit (15mm?).
Metric hex keys and 3/8" drive metric hex keys.
Folding Torx set - for Thule rack.
Hammer - small ball-peen.
Linesman pliers.
Diagonal cutting pliers.
Needle nose pliers.
Water pump pliers.
Wire stipper/crimper w/ assortment of crimp ends.
Spare parts:
Fuel pump.
Water pump.
Fuel filter.
Belts (old ones left from previous change).
Plugs, cap, rotor (old).
1 set of front wheel bearings and seal.
Spare bulbs.
Handful of relays.
Fuses.
wiper blades (old).
I also have an AFM, ECU and various other parts at home ready to be shipped if I need them.
General auto stuff:
Bentley manual.
Tire plug kit and 12v compressor.
Jumper cables.
12v light and flares.
Qt engine oil.
Gal antifreeze.
Bottle isopropanol for fuel.
Wheel bearing grease.
several pieces of fuel line.
Gloves - leather and several pairs of latex.
Waterless hand cleaner.
Decent lug wrench and sockets.
Funnel.
Rags.
Electrical tape.
Duct tape!
Sleeping bag.
All of this fits under the bench, with ample room for boots, tarps and more.
I'm sure I missed a few things.
Cheers,
Ric _________________ '87 Westy Weekender - daily driver on salt-free roads
There's gonna be some changes made.
“I find that things usually go well right up until the moment they don't.” - Ahwahnee
"Quality isn't method. It's the goal toward which the method is aimed." - Socrates, later quoted by R.M. Pirsig |
Da TOW'D Samba Member
Joined: December 25, 2005 Posts: 1382 Location: Bella Coma Canada
Posted: Sat Mar 03, 2007 7:16 pm Post subject: |
AAA card  _________________ '57 type 1 Blackberry
'58 SC Ruf
'62 type 3 Notch
'92 Eurovan Willy
'99 Eurovan Winnie
and NUTS |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Sat Mar 03, 2007 7:33 pm Post subject: |
Riceye!
wow, that's a lot of stuff!
what're water pump pliers? Never heard of that. Should I have had that when I put in my new water pump? Is that why it took me part of 3 days?
You forgot the self-fusing silicone tape. Good to about 500 degrees, nice to have if a hose should bust, even at the H-pipe. |
dr. no Samba Member
Joined: August 06, 2004 Posts: 579 Location: Santa Fe
Posted: Sun Mar 04, 2007 8:14 am Post subject: |
Screwdriver with 4 bits
duck tape
fuses
jumper wires (and cables)
13, 17, 8, 7, 10, 15mm wrenches
2 vise grips
ratchet handle with various bits
breaker bar with 19mm head (for wheels)
2 more 13mm wrenches (they seem to reproduce)
large hemostat
pump handle pliars (also called channel-loks)
Bentley
belts
heater hose
whatever part I think will die next (currently water pump) _________________ Scott
http://lungehphoto.com
'83.5 Westy s/p 1.6td JX and 4sp DK transplant
'09 Jetta SportWagen TDI
'06 MB Sprinter
'86 Iltis
'89 Isuzu Trooper
PAST VWs:
'82 NA diesel Vanagon
'86 7-passenger Vanagon
'77 Bay
'71 Bay
'74 Things (2)
'69 Karmann Ghia (the only one I miss--in nice weather, anyway...)
'91 Fox |
riceye Samba Member
Posted: Sun Mar 04, 2007 10:47 am Post subject: |
Water pump pliers = Channellocks. Not useful for waterpump r&r, but good for general grabbing of things, like hot pans on the campfire.
Ditto on the self-fusing tape. It's not on the list, but it is in the van.
Sounds like a lot of stuff, but it all fits under the bench to the passenger side of the heater box, with the exception of the sleeping bag and Bentley. They're under the jump seat.
Cheers! _________________ '87 Westy Weekender - daily driver on salt-free roads
ShootingFish Samba Member
Joined: July 25, 2010 Posts: 330 Location: Portland, OR
Posted: Tue Jun 07, 2011 9:50 pm Post subject: |
I am looking for suggestions on a good set of wire crimpers... I am about to start a total re-work of the house electrical system and am willing to throw down on a decent tool.
SF _________________ SF
Props aren't just for boats....
'88 2WD ALH-TDI Westy
'90 Syncro 16 Doka  |
climberjohn Samba Member
Joined: January 11, 2005 Posts: 1840 Location: Portland Orygun
Posted: Tue Jun 07, 2011 10:11 pm Post subject: |
ShootingFish wrote: |
SF |
Dear SF,
These are not crimpers, but wire strippers. An amazing tool.
Irwin Vise-Grip Self-Adjusting Wire Stripper — 8in., Model# 2578300.
About $21 online.
This makes electrical work SO much more enjoyable! You'll get perfectly stripped wires every time.
_________________ '86 Westy, 2.5 Subaru power
Know your limits. Exceed them often. |
erdonline Samba Member
randywebb Samba Member
Posted: Tue Jun 07, 2011 10:23 pm Post subject: |
dr. no wrote: |
so, there is no need for 9, 11, 12, 14 mm wrenches on the Vanagon? _________________ 1986 2.1L Westy 2wd Auto Trans. |
Posted: Wed Jun 08, 2011 4:00 am Post subject: |
randywebb wrote: |
dr. no wrote: |
so, there is no need for 9, 11, 12, 14 mm wrenches on the Vanagon? |
The 9 fits some brake bleeders, the 11 some brake fittings, and the 14 the nuts on the valve adjusting screws, while the 12 will be needed for that metric bolt you scrounged off a Toyota in the wrecking yard.  |
Perales Samba Member
Joined: May 07, 2007 Posts: 2046 Location: Nova Scotia
Posted: Wed Jun 08, 2011 5:10 am Post subject: |
SF |
I highly recommend the Klein 1005. I bought it on TK's suggestion and Wow, what a difference a good tool makes. Home Depot had it in stock for about the same price.
http://www.amazon.com/Klein-Tools-Insulated-Non-Insulated-Terminals/dp/B0006M6Y5M/ref=pd_cp_hi_2
_________________ -- 1987 Westfalia automatic (Captain Vino) |
Posted: Wed Jun 08, 2011 11:18 am Post subject: |
Wildthings - you include "1/2 drive sockets 15mm-22mm" in your list (other thread)
To put together a reasonable minimal set of tools to carry in the Vanagon, which of those are needed?
17, 19, and ?? _________________ 1986 2.1L Westy 2wd Auto Trans. |
Stockurai Samba Member
Joined: May 06, 2011 Posts: 42 Location: New Britain, CT
Posted: Wed Jun 08, 2011 11:20 am Post subject: |
what I have:
bentley manual
adjustable wrench
needlenose pliers
regular pliers
crow bar
duct tape
5000+ zip ties
ratchet straps
and THIS
http://www.sears.com/shc/s/p_10153_12605_00937154000P?prdNo=1&blockNo=1&blockType=G1
(WHICH IS ON SALE GOOD DEAL!)
 _________________ 1990 Vanagon Transporter 2.1L [the fridge] - Daily Driver for College Commuting
Dogpilot wrote: |
Besides, Yuppies cannot run to a dealership and give a credit card and just buy one. You have to breath life into it, kind of like an Egyptian afterlife thing. Once you resurrect it, it becomes your buddy. It is unusual and has character. |
