KaBam
[email protected]
marine_nco@hotmail.com is offline
PostPosted: Tue Dec 24, 2002 7:25 pm    Post subject: KaBam Reply with quote
I just put in a new solex carb onto my 1600sp
I have a problem with backfireing and loss of RPMS every once and a while. This generaly hapens when I drive at a constant speed for long periods of time such as 60 min., and down shift when I am stopping for a light or stop sign any insights into this problem would be helpful thanx
[email protected]
dangerang@cox.net is offline
PostPosted: Wed Dec 25, 2002 10:35 pm    Post subject: KaBam Reply with quote
ka bam
Tell me what distributor did you use and what Solex did you put in? Typical combination 34 solex and and a dual port distributor on the vacuum canister one is connected to full vacuum and the other to ported vacuum. If you are using a mech advance only like an 009 it wont work. There is a modification you can do for a 34 if you have that combination. For trouble free combination I have a 30 solex and 009 It gives better mileage and you wont feel that much difference.
