Twiggy Samba Member
Joined: July 07, 2006 Posts: 115 Location: Belleville,ill
Posted: Mon Mar 19, 2007 9:22 pm Post subject: 195/50/15's on a 4.5"? |
| anyone running this size on that width? Will they fit? |
buggpower Samba Member
Posted: Mon Mar 19, 2007 11:50 pm Post subject: |
195/50's are same width as a 195/60 except taller. I have 195/60's on my car right now with 4.5" wide rims. I personally dont like it because they balloon out but not really bad, but since 195/50's are shorter you might not have a big balloon look like i have. _________________ 1972 Standard Beetle
Bite My Shiny Metal A$$ (quoted by Bender)
click the cool link haha!
http://img.photobucket.com/albums/v600/bigguy/avatars/150_tits1.gif |
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11497 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Tue Mar 20, 2007 3:16 am Post subject: |
same here - running 195/60's on stock 4.5 steelies with no problems... _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
Bryan67 Samba Member
Joined: January 01, 2003 Posts: 2962 Location: Fresno, Ca.
Posted: Tue Mar 20, 2007 6:38 am Post subject: |
Not true. 195/50`s are actually wider than a 195/60. Measure them sometime. _________________ If you`re going to do something, do it right. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80428 Location: Sneaking up behind you
Posted: Tue Mar 20, 2007 6:42 am Post subject: |
| Bryan67 wrote: |
| Not true. 195/50`s are actually wider than a 195/60. Measure them sometime. |
Tires do not measure exactly what the size is, but generally a 195 is a 195 is a 195. So a 195/50-15 is the same width as a 195/60-16 and a 195/50-14.
I have 195/60-15 on 5.5" wide wheels and think a 4.5" is a bit narrow. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13586 Location: Tejas!
vwfye Samba Member
Posted: Tue Mar 20, 2007 10:05 am Post subject: |
you will wonder why your car feels 'squishy' inthe turns. also, you actually have a greater chance of rolling the bead of the tire off of the rim in a hard defensive/evasive turn. read that as 'very bad'. _________________ 64 No'back Speedster "Pearl"
LME "Little Giant Killer 3"
1974 Ghia "PUK" |
Twiggy Samba Member
Posted: Tue Mar 20, 2007 12:05 pm Post subject: |
yeah I did a little more reseach after I posted this and found out they'll have the "baked bread" look.
Also that size might be a bit to low and throw off my gearing too much in my bug. |
Posted: Tue Mar 20, 2007 4:57 pm Post subject: |
You can run a 185/55 or 175/55 with no problem though. Or even a 185/60. _________________ If you`re going to do something, do it right. |
clarkbre Samba Member
Joined: June 20, 2004 Posts: 1107 Location: Everett, WA
Posted: Tue Mar 20, 2007 6:05 pm Post subject: |
| I run 175/65/15's on the front of my bug. They're 24" tall, a little wider than stock and have a fairly wide footprint on them. They ride really nice too. |
ivsamhell Samba Member
Joined: June 12, 2006 Posts: 858 Location: hesperiaCA
Posted: Tue Mar 20, 2007 8:02 pm Post subject: |
i used to run 195/50 up front, slammed and narrowed 4" on stock wheels.
i like the look and the handling. just bought some 145/65s to try out. |
Skim Rants Master
Joined: April 15, 2001 Posts: 17098 Location: GFK 33 Year Vet
Posted: Wed Mar 21, 2007 11:45 pm Post subject: |
Before they started coming out with the smaller width low profiles, I ran them on 4.5 fuchs, I didnt care for the look but thats all they had at the time.
Notice how the 195x50 bubbled out on the side wall...
Personally nowadays I like the 165x45 on a 4.5. Its like a match made in heaven. Plus they are cheaper than 195x50's _________________ GFK
1953 Kabriolet
1959 Lowlight Ghia vert
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
Stevepi Samba Member
Joined: February 24, 2006 Posts: 112 Location: Surrey.UK.
Posted: Thu Mar 29, 2007 10:55 am Post subject: |
I have in my possession a 185/55 and 195/65 and the 185s are wider than the 195s.
In fact when I measure them the 185 measures close to 195 and the 195 measures 185.
These are dirt cheap tyres made in china. |
glandnut 40 horses of Fury
Joined: February 26, 2003 Posts: 1432 Location: J-ville, FL
Posted: Thu Mar 29, 2007 5:28 pm Post subject: |
| Skim wrote: |
Personally nowadays I like the 165x45 on a 4.5. Its like a match made in heaven. Plus they are cheaper than 195x50's |
Do you mean on a bus, or on sedans as well? _________________ Looking for aluminum single port Kadron manifolds. |
Skim Rants Master
Posted: Fri Mar 30, 2007 3:43 am Post subject: |
| glandnut wrote: |
| Skim wrote: |
Do you mean on a bus, or on sedans as well? |
Honestly I dont like how they look on sedans, If a bug is not super low it will show a huge gap. I like 135's because its the traditional front tire on a bug but I would never, ever put them on a bus. _________________ GFK
1953 Kabriolet
Posted: Sat Mar 31, 2007 4:31 am Post subject: |
| Stevepi wrote: |
that may be the reason right there.... _________________ póg mo thóin
