Speedometer reset
olde skool
olde skool is offline
PostPosted: Mon Jul 17, 2006 8:28 pm    Post subject: Reply with quote
Thanks glutamodo, with your advice I reset my '68 speedometer back to zero miles and replaced the gels looks awesome!!!
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Mon Jul 17, 2006 10:41 pm    Post subject: Reply with quote
Your the man Andy!
My needle was bouncing at lower speed. I lubed the speedo cable (which appeared to be ok). I then took the speedo apart and found the grease under the magnet and drive assy to be pretty old and thick! The magnet didn't spin very easily. I sprayed out all the old grease with carb cleaner, relubed it up and it spins very easily now.
I reinstalled the speedo after setting the mileage to what my new engine has on it and no more bounce!
Great pictures Andy and you DO ADD LOTS of value to this site.
Good job!
The Samba member since 2004.
orbitron
orbitron is offline
PostPosted: Fri Mar 02, 2007 3:27 pm    Post subject: Reply with quote
My speedo is intermittant. The odometer seems to work fine, but in just sub-zero temps, it wails like nobody's business and then quits indicating entirely. Initially I thought it was the speedo cable but the odometer still works so it must be inside.
any insight?
I'm trying to decide if I should fix the old one or convert to metric...
http://www.cip1.ca/ProductDetails.asp?ProductCode=VWC%2D113%2D957%2D055%2DD Shocked
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Fri Mar 02, 2007 4:40 pm    Post subject: Reply with quote
Take it apart and see if you had the same problem as me. Sray some WD40 in the speedometer cable to free it up and relube the gears inside. Mine works like new know.
Its not a hard project, just take your time.
orbitron
orbitron is offline
PostPosted: Sun Mar 11, 2007 8:43 pm    Post subject: Reply with quote
Bought a used metric one on Friday. I'm not sure if I'll gut it or not though. Not sure about the Canadian laws when it comes to resetting speedo's though
jkyes
jkyes is offline
PostPosted: Sun Apr 01, 2007 8:15 am    Post subject: Reply with quote
just got mine apart this am, and i have a cracked gear just like the one in the pict. speedo works, odometer turns by hand, it appears to just be the bad gear, is there a fix? are there replacement parts?
MConstable wrote:
So, Glenn wasn't "trying" to correct you
he "did" correct you.
James
'74 bug
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Sun Apr 01, 2007 7:49 pm    Post subject: Reply with quote
Try contacting these guys for the gear:
http://www.speedometerplus.com/
Fowvay
Fowvay is offline
PostPosted: Mon Jun 04, 2007 9:17 pm    Post subject: Reply with quote
My 70 came with a 100mph late model Speedo so I bought a well used and dirty 3/70 speedo out of the classifieds.
Thanks for this post! I got it all cleaned up but I didn't bother to roll back the miles since the miles fit the look of my bug nicely. Wink
I also found it very easy to calibrate the preload using the factory alignment notch. Just be gentle lifting the needle up and over. For the gears I used a moly blend water proof marine grease meant for lubing up gauge shafts on ships. I keep it around for lubing cables etc. Worked the charm. The needle is super smooth and no jumps. Very Happy
before:
During:
After:
My 13.98@104mph New Beetle "Pomelo" | My 1970 Bug "Oscar"
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
mnussbau
mnussbau is offline
PostPosted: Thu Jul 05, 2007 5:29 pm    Post subject: Reply with quote
I assume plain old wheel bearing grease would be just as good for the gears? And the brass replacement gear--it just presses on without any adhesive?
Mike
‘74 bug vert
Parts...
jmsmilin
Samba's Most Posted
jmsmilin is offline
PostPosted: Thu Aug 23, 2007 2:40 pm    Post subject: Reply with quote
looking to rebuild a speedo-where does one get needle-chrome ring-gels-lens etc?
Der Schmutzige Süden.
(o\ ! /o) | o \/ o | (o)=|=(o) [o\|_|_|/o] \m/
jmsmilin
Samba's Most Posted
jmsmilin is offline
PostPosted: Mon Sep 24, 2007 5:02 pm    Post subject: Reply with quote
I got my gels today, I cant see which side faces the driver, the shiny side of the gels, or the hazy "textured" side of the gels?
Fowvay
Fowvay is offline
PostPosted: Wed Sep 26, 2007 4:26 am    Post subject: Reply with quote
My gels are stock and have the shiny side facing in with the texture facing out.
jmsmilin
Samba's Most Posted
jmsmilin is offline
PostPosted: Wed Sep 26, 2007 2:04 pm    Post subject: Reply with quote
sweet, so when you say facing out-you mean facing toward the driver right?
1969
1969 is offline
PostPosted: Wed Sep 26, 2007 2:44 pm    Post subject: Reply with quote
wow i tried to reset my speedo by air drill, and it takes over 30 seconds to move one digit! its at 80 320 right now, still have quite a ways to go! i may just take it apart like shown in this forum. would save some time!
fonz15
fonz15 is offline
PostPosted: Wed Nov 14, 2007 4:16 pm    Post subject: Reply with quote
does anyone know where to get the speedometer gear? i went to the link thats on top and they have super beetle ones that are metal, just wondering if they are the same or where i can get the plastic ones.
mnussbau
mnussbau is offline
PostPosted: Wed Nov 14, 2007 6:24 pm    Post subject: Reply with quote
Same gear for beetle or super, and as far as I know you can only buy new brass gears.
Mike
‘74 bug vert
Parts...
fonz15
fonz15 is offline
PostPosted: Thu Nov 15, 2007 5:25 pm    Post subject: Reply with quote
cool... hope it works.
GatorJZ
GatorJZ is offline
PostPosted: Thu Nov 15, 2007 6:15 pm    Post subject: Reply with quote
Plastic gears:
http://www.odometergears.com/
mnussbau
mnussbau is offline
PostPosted: Fri Nov 16, 2007 12:47 pm    Post subject: Reply with quote
GatorJZ wrote:
Plastic gears:
That's $29 shipped. The one from http://www.speedometerplus.com/ is brass and is $25 shipped... Wink Just confirm it fits your car first.
Mike
‘74 bug vert
Parts...
70bugken
70bugken is offline
PostPosted: Mon Dec 31, 2007 9:36 am    Post subject: Reply with quote
Wow...what a fantastic thread this is! I bought a used '70 speedometer on ebay (sorry Samba sellers Sad) and cleaned the glass, replaced the turn signal gel with a file folder tab, and reset the odometer!
Check it out:
Those 3/10 of a mile are "finger miles". It is in my "Beetle Projects" box for things to do when the weather warms up! Needless to say, the box is getting fuller and fuller, while my wallet is getting emptier and emptier...
Page 2 of 8
