Pressurized air through copper pipe What is common practice
coW
coW is offline
PostPosted: Wed Apr 11, 2007 10:30 am    Post subject: Pressurized air through copper pipe What is common practice Reply with quote
Not sure where to ask this question, but figured someone here'd know:
My garage was my do-all workshop but recently split it into two, having the garage for my bug's restoration and my basement shop for woodworking, etc.
I have a good size compressor that I'd like to put in my basement and plumb pipes all over the place, including outside. The outside pipe will be hooked into air hose reel that could then be hooked into the garage's tools.
What is the common practice of making pipe connections?
I can just use regular copper pipe, right?
Can these connections be sweated or do the need to be threaded for safety?
I was thinking of putting sweat/threaded converters on and thread a hose connector to it - is that right?
Looking around at work, they seem to use a combination of threaded copper pipe and compression fittings - just making sure that nothing incredibly stupid and dangerous will be done by me..
DaveM
Mad Samba Scientist
DaveM is offline
PostPosted: Wed Apr 11, 2007 10:33 am    Post subject: Reply with quote
thick walled pvc used to be used a lot... I have a machinist friend that used it all over until the osha people got after him. Standard black pipe is what I would use.
Sounding like a broken record as to why You should be measuring protein during harvest in order to better your agronomic practices.
johnshenry
johnshenry is offline
PostPosted: Wed Apr 11, 2007 10:36 am    Post subject: Reply with quote
I've plumbed my shop with 3/4" copper. One pull down reel, and 2 other "drops" See TPTOOLS.COM for some good tips on laying out air systems. All drops must have a valve at the lowest point to drain condensation.
TPtools will say steel pipe only, but I find copper very easy to work with and virtually no leak problems ever.
John Henry
'57 Deluxe
'56 Single Cab
Ace
Ace is offline
PostPosted: Wed Apr 11, 2007 10:39 am    Post subject: Reply with quote
We used PVC and it holds up well if it is in a non abusive environment. On the copper, I was playing with compression fittings last weekend and they seem to hold up fine.
coW
coW is offline
PostPosted: Wed Apr 11, 2007 10:52 am    Post subject: Reply with quote
Thanks for those tips, guys!
I'm leaning towards using 3/4 copper because of the convenience factor (used it a lot and sweating connectors comes easy). It is only me in the shop and could easily make most the pipe be out of normal reach to avoid abuse.
TPTool's suggestion of the use of risers to dry the air hadn't occured to me. Those gate valves used to drain are those special air ones or would any solid ball valve do?
Fish
Fish is offline
PostPosted: Wed Apr 11, 2007 11:02 am    Post subject: Reply with quote
The Machine shop I work in all air lines are sweated 5/8" copper pipe and we operate at a max of 85 PSI. You can buy plastic water traps that go in-line, but they don't work that good when the humidity goes up. We run an air dryier system so no problems with water in the lines. We pass CA state inspections every year.
Prosit!
# 303 and #156
The Sage
The Sage is offline
PostPosted: Wed Apr 11, 2007 11:08 am    Post subject: Reply with quote
I recommend an air line drying system with the granulates. They turn color when they are ready to be replace...we have found you can simply bake them in the oven at about 120 and they can be reused...
This is very important when it comes to painting booths...
Feel My Pain l Sage Ad World
sweetlokin66
sweetlokin66 is offline
PostPosted: Wed Apr 11, 2007 11:30 am    Post subject: Reply with quote
1/2" schedule 80 PVC works great. It doesnt corrode, its easy to set up/work with, wont brake the bank, you have endless amounts of options for connections. My whole shop took about 7-8 hours to do and i was running air tools that night. That was 9 years ago.
Follow IG for more content @greyarearacing
Turbo type 4
http://shoptalkforums.com/viewtopic.php?f=3&t=134157
66 NA hard top
****Insert event here****
Fish
Fish is offline
PostPosted: Wed Apr 11, 2007 11:33 am    Post subject: Reply with quote
We have a refrigerated air dryer. Probably more expensive than what you are talking about. We don't paint, but it ain't cool spraying water mist on mills and lathes.
Prosit!
# 303 and #156
coW
coW is offline
PostPosted: Wed Apr 11, 2007 11:39 am    Post subject: Reply with quote
I use these things:
It is only hobby use, though. Don't do spraying but just there to protect my tools (nailers, impact hammer, chisel, buzzsaw, etc).
Fish
Fish is offline
PostPosted: Wed Apr 11, 2007 11:57 am    Post subject: Reply with quote
Don't forget to oil your tools and you should be fine. And keep an eye open on those high humidity days.
Prosit!
# 303 and #156
Iowa Mark
Iowa Mark is offline
PostPosted: Wed Apr 11, 2007 1:01 pm    Post subject: Reply with quote
I just got done sweating about 200 3/4" fittings together at work for our new paint system. "K" copper and 95/5 solder. 100psi all day long. For the buried lines, I'd go with flex copper in one continuous stretch to avoid splices under ground. And make sure it's below your frost line. Have fun!
60's Burnout
60's Burnout is offline
PostPosted: Sat Apr 14, 2007 7:21 pm    Post subject: Reply with quote
Unless you have really long runs, over 100 feet, just use 1/2" copper, soldered together. Compare the inner diameter to the rubber airhose you're using and you can see it's several times bigger. Plastic is a no-no. Something hits it, it'll explode and throw plastic shards. Use the drops, otherwise the female quick disconnect on the end of the line will rust, ask me how I know.
bugninva
bugninva is offline
PostPosted: Sat Apr 14, 2007 7:49 pm    Post subject: Reply with quote
Rem, copper is fine, but you MUST use at *least* type L copper... K would be even better, but possibly overkill and alot more expensive(plus commonly available fittings would be your weak point if you use type K anyway, so unless you wanna shell out, and locate, high pressure copper fittings, type L is fine)... i ran copper in my father in laws garage and he has been using it daily for six years.... no leaks.... one word of advice i give to anyone using copper(*and really for anyone using anything) if you shut your compressor off from the airlines when not in use(like with a ballvalve to isolate the line from the compressor) always open the pressure valve slowly till the pressure in the lines equalizes to the regulator's pressure output.... this avoids popping fittings...
[email protected] wrote:
With a show of hands, who has built over 1000 engines in the last 25 years? Anyone?
GEX has. Just sayin
steponmebbbboom
steponmebbbboom is offline
PostPosted: Sat Apr 14, 2007 11:01 pm    Post subject: Reply with quote
sched. 40 black iron
coW
coW is offline
PostPosted: Sun Apr 15, 2007 5:28 am    Post subject: Reply with quote
bugninva wrote:
Rem, copper is fine, but you MUST use at *least* type L copper... K would be even better, but possibly overkill and alot more expensive(plus commonly available fittings would be your weak point if you use type K anyway, so unless you wanna shell out, and locate, high pressure copper fittings, type L is fine)... i ran copper in my father in laws garage and he has been using it daily for six years.... no leaks.... one word of advice i give to anyone using copper(*and really for anyone using anything) if you shut your compressor off from the airlines when not in use(like with a ballvalve to isolate the line from the compressor) always open the pressure valve slowly till the pressure in the lines equalizesp to the regulator's pressure output.... this avoids popping fittings...
Thanks, Chris (and everyone).
After all this wonderful advice, I've been pricing both copper and black pipe with all required fittings. I'll have to see what my wallet can bear but am a strong believer in overkill.
What I do to equalize (and eventually zero) the pressure is open the little valve at the bottom of the tank so it always hisses very slightly. This also seems to nicely get rid of the water in the tank.
One drawback is that, should I forget to turn the compressor off, I might get a wake up call from it in the middle of the night.. Smile
60's Burnout
PostPosted: Sun Apr 15, 2007 8:28 am    Post subject: Reply with quote
CoW, the working pressure for 1/2" L copper is 722psi, it's 3900 psi burst. Somehow I don't think you're going anywhere near those.
Black pipe is overkill, I had to put that in my house for the gas lines, mainly so you can't drive a nail or screw into it. Propane is about 2psi. Total pain in the ass to work with, threading it and not having it leak, even with pipe dope and teflon tape was a challange. Had to have a new, sharp, set of Ridgid dies, correct cutting oil, and pipe that wasn't slightly oversize.
Don't worry about letting the air into the piping from a charged compressor tank, it's air, not water. You don't get the water hammer where the moving water hits the end of the line and spikes the pressure.
Don't leave the copper where anybody can see it, it's like $3+ a pound for scrap. And install the drip loops.
bugninva
bugninva is offline
PostPosted: Sun Apr 15, 2007 8:36 am    Post subject: Reply with quote
well i guess years as a pipe fitter and welder didn't teach me shit..... you drop ball valve when your tank is at 100psi reguarly and you can, and likely over time will, pop off a copper fitting...usually the first ell...
GEX has. Just sayin
60's Burnout
PostPosted: Sun Apr 15, 2007 8:56 am    Post subject: Reply with quote
Don't know what to tell you, I have a 3/4" flex from the Curtis 175psi into a tee and I have opened the ball valve on a full tank and it's been working for the last 8 years. Maybe a solenoid valve that can yank it open in an instant, but just turning the handle on the valve, hasn't happened. YMMV
bugninva
bugninva is offline
PostPosted: Sun Apr 15, 2007 8:59 am    Post subject: Reply with quote
experience is nice to know...but just because it hasn't happened doesn't mean it's not a good idea to caution folks to what can happen.... lots of folks here have never had a fuel filter burn their ride to the ground...won't stop folks(myself included) from cautioning them against having it in the engine compartment....lots of folks here have never had the battery short out when someone sits in the backseat, won't stop folks from being warned that the battery terminals need to be covered....etc... i don't know why everything on this site has to be a debate...if you want to slam the valve open and it works for you, great... that doesn't mean that its a good idea....
GEX has. Just sayin
