richtrek Samba Member
Joined: May 21, 2006 Posts: 204 Location: Santa Clarita Valley Area
Posted: Sun Apr 22, 2007 5:47 pm Post subject: Choosing a "key blank" |
I have only one key for my Thing. I found a ton of "key blanks" in the Samba classifieds. Does anyone know if Thing keys are the same as Bug, etc.? Is there some type of identifier on the key that specifies the type of key to buy?
Rich |
Woreign Samba Member
Joined: June 04, 2006 Posts: 2840 Location: Crestview FL
Posted: Sun Apr 22, 2007 6:12 pm Post subject: |
| Eastlake/Curtis key blank "V-29" that can be found at any key shop. Fits the VW Bus... |
FreakCitySF Samba Member
Joined: June 08, 2004 Posts: 642 Location: San Francisco
Posted: Sun Apr 22, 2007 6:29 pm Post subject: |
http://cgi.ebay.com/ebaymotors/KEY-VW-THING-BIG-BL...enameZWD1V
Here is a seller of reproductions and aftermarket.
I bought and had the key cut to my factory code. Ended up not working at all. Turns out my ignition lock and keys were well worn.
I could have it cut again to match the worn key to make it work.
but for now have a 20.00 key fob. |
kubelmann Samba Member
Posted: Sun Apr 22, 2007 6:31 pm Post subject: |
| The key that fits a 73-74 Thing is the "R" profile. You can cross reference this key to lots of otehr blanks. Some key blanks are good quality and some are not. I have lots high quality VW keys available. If you give me the key code I can send you a key that will fit your car. It will be cut to code not made from your old worn key. There is a big difference. |
kuebelwagen84 Samba Member
Joined: March 15, 2007 Posts: 144 Location: Edison, NJ
Posted: Sun Apr 22, 2007 7:11 pm Post subject: |
I had to go to my local VW dealer to get keys copied for mine, they had the blanks and a machine that cut the whole thing exactly like the original...
no other place (aside from ebay and the classifieds) had the correct blank |
Ian Epperson Samba Member
Joined: January 12, 2005 Posts: 2262 Location: Alameda, CA
Posted: Sun Apr 22, 2007 7:27 pm Post subject: |
I happened to be at a locksmith's place and saw that he had old VW keyblanks, so I had him make 2 keys. Turned out to be a few dollars more than I could have paid at the local hardware store, but it was WELL worth it. He gave me back my worn key and told me to put it away somewhere safe, then asked me to go back to the car and try one of the new keys in ALL the locks (they're all original - ignition, doors, decklid). I found that it worked in the ignition but not one of the doors and the decklid. So, he grabbed a file, vicegrips and some powder went out to my car and worked and filed the key until it worked in all the locks, then recut the other to fit. $5 per key suddenly seemed real cheap. |
bciesq Samba Member
Joined: April 13, 2005 Posts: 495 Location: Orlando, FL
Posted: Mon Apr 23, 2007 4:31 am Post subject: |
FWIW, CiP1 sells a ridiculously expensive OE key:
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D113%2D837%2D219%2DAR
Of course, I've wasted $15 on less.
Ian's right about going to a real locksmith. I had the same experience and ended up nicely working copy. It's amazing how worn down my original key had gotten. The original is now tucked away for safe keeping. _________________ '73 Thing -- making 45 mph exciting again. |
Thingster Samba Member
Joined: February 28, 2006 Posts: 150 Location: Webster Groves, MO
Posted: Wed May 09, 2007 3:30 pm Post subject: |
That is all rediculously expensive. I went to a local locksmith and he had the blank on the shelf, walked out for $7.50 cut and working fine
Justin _________________ "I like to take my Thing out and play with it."
1974 Thing (Play Toy)
1957 Sedan(Show Car)
1954 Sedan (On the back burner) |
SteveGIndy Samba Member
Joined: April 07, 2012 Posts: 19 Location: Indianapolis, IN
Posted: Tue Mar 07, 2023 11:11 am Post subject: Re: Choosing a "key blank" |
Old thread but i was looking for keys and found a list of key manufacturers and the corresponding part numbers that fit the Thing.
Ilco : VW71A
JMA : VO-R /VOR
Curtis : V-29/V29
Taylor : V81V
Cole : VW25
Dominion : HF32
ESP : V29R
JET : V29R
Silca : VO1/V01
Star : VW5
Orion : VW20 |
obus  Samba Member
Joined: March 08, 2001 Posts: 11810 Location: just off Garden State Parkway Exit 81
smokeydogvol Samba Member
Joined: November 04, 2024 Posts: 11 Location: Knoxville, TN
Posted: Tue Nov 19, 2024 9:41 am Post subject: |
Do you still deal in key blanks? I need one for my Thing as well!
| kubelmann wrote: |
sportin-wood Samba Member
Joined: September 12, 2010 Posts: 2322 Location: Texas
Posted: Wed Nov 20, 2024 1:55 pm Post subject: |
| smokeydogvol wrote: |
| Do you still deal in key blanks? I need one for my Thing as well! |
These are pretty cheap (for 2) on eBay. I would compare the picture to any working key you have before buying.
https://www.ebay.com/itm/151435702850?fits=Model%3...R_zFy7XpZA _________________ Dave
1966 Bug project
1973 Thing project
"Relax, all right? My old man is a television repairman. He's got this ultimate set of tools. I can fix it." --- Jeff Spicoli |
Joined: February 21, 2003 Posts: 879 Location: Clifton Park NY Saratoga County
T2funtimer Samba Member
Joined: October 12, 2024 Posts: 4 Location: Alexandria, Virginia
Posted: Sat Aug 23, 2025 2:58 pm Post subject: Re: Choosing a "key blank" |
First time poster. Thanks in advance for helping a new guy.
Does anyone know why my new "R" blanks don't push all the way in on my 1974 bus? I have one old key which works fine -- it is stamped V-29, and R, and it's from Curtis Industries. I ordered two R blanks from Wolfsburg West. When I push the WW keys into the locks or ignition, they stop about an 1/8" shorter than the old Curtis key. They stop about where the key grooves stop. The photo shows that the grooves are different lengths between the Curtis and new WWs. Did WW send me the wrong blanks? Why won't they go all the way in?
Posted: Sat Aug 23, 2025 3:36 pm Post subject: Re: Choosing a "key blank" |
Looks like you should’ve bought one of ours _________________ Michael Basso
http://www.thingparts.com
New and Used VW Thing Parts Free advice
CALL 518 630 0173 |
wbailey2112 Samba Member
Joined: October 02, 2015 Posts: 560 Location: Grove City, OH
Posted: Tue Aug 26, 2025 7:14 am Post subject: Re: Choosing a "key blank" |
Wrong forum. You should probably post this in the Bay Window Bus Forum.
As for the R profile key blank with VW logo shown in your post, I purchased a set of these style blanks years ago and paid a local reputable lock shop to cut new keys for my '74 Thing and had no issues whatsoever. _________________ '74 Thing
'83 Westfalia |
Posted: Tue Aug 26, 2025 7:15 am Post subject: Re: Choosing a "key blank" |
As for the R profile key blank with VW logo shown in your post, I purchased a set of these style blanks years ago and paid a local reputable lock shop cut new keys for my '74 Thing and had no issues whatsoever. _________________ '74 Thing
'83 Westfalia |
