Choosing a "key blank"
richtrek
richtrek is offline
PostPosted: Sun Apr 22, 2007 5:47 pm    Post subject: Choosing a "key blank" Reply with quote
I have only one key for my Thing. I found a ton of "key blanks" in the Samba classifieds. Does anyone know if Thing keys are the same as Bug, etc.? Is there some type of identifier on the key that specifies the type of key to buy?
Rich
Woreign
Woreign is offline
PostPosted: Sun Apr 22, 2007 6:12 pm    Post subject: Reply with quote
Eastlake/Curtis key blank "V-29" that can be found at any key shop. Fits the VW Bus...
FreakCitySF
FreakCitySF is offline
PostPosted: Sun Apr 22, 2007 6:29 pm    Post subject: Reply with quote
http://cgi.ebay.com/ebaymotors/KEY-VW-THING-BIG-BL...enameZWD1V
Here is a seller of reproductions and aftermarket.
I bought and had the key cut to my factory code. Ended up not working at all. Turns out my ignition lock and keys were well worn.
I could have it cut again to match the worn key to make it work.
but for now have a 20.00 key fob.
kubelmann
kubelmann is offline
PostPosted: Sun Apr 22, 2007 6:31 pm    Post subject: Reply with quote
The key that fits a 73-74 Thing is the "R" profile. You can cross reference this key to lots of otehr blanks. Some key blanks are good quality and some are not. I have lots high quality VW keys available. If you give me the key code I can send you a key that will fit your car. It will be cut to code not made from your old worn key. There is a big difference.
kuebelwagen84
kuebelwagen84 is offline
PostPosted: Sun Apr 22, 2007 7:11 pm    Post subject: Reply with quote
I had to go to my local VW dealer to get keys copied for mine, they had the blanks and a machine that cut the whole thing exactly like the original...
no other place (aside from ebay and the classifieds) had the correct blank
Ian Epperson
Ian Epperson is offline
PostPosted: Sun Apr 22, 2007 7:27 pm    Post subject: Reply with quote
I happened to be at a locksmith's place and saw that he had old VW keyblanks, so I had him make 2 keys. Turned out to be a few dollars more than I could have paid at the local hardware store, but it was WELL worth it. He gave me back my worn key and told me to put it away somewhere safe, then asked me to go back to the car and try one of the new keys in ALL the locks (they're all original - ignition, doors, decklid). I found that it worked in the ignition but not one of the doors and the decklid. So, he grabbed a file, vicegrips and some powder went out to my car and worked and filed the key until it worked in all the locks, then recut the other to fit. Shocked $5 per key suddenly seemed real cheap.
bciesq
bciesq is offline
PostPosted: Mon Apr 23, 2007 4:31 am    Post subject: Reply with quote
FWIW, CiP1 sells a ridiculously expensive OE key:
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D113%2D837%2D219%2DAR
Of course, I've wasted $15 on less.
Ian's right about going to a real locksmith. I had the same experience and ended up nicely working copy. It's amazing how worn down my original key had gotten. The original is now tucked away for safe keeping.
'73 Thing -- making 45 mph exciting again.
Thingster
Thingster is offline
PostPosted: Wed May 09, 2007 3:30 pm    Post subject: Reply with quote
That is all rediculously expensive. I went to a local locksmith and he had the blank on the shelf, walked out for $7.50 cut and working fine Wink
Justin
"I like to take my Thing out and play with it."
1974 Thing (Play Toy)
1957 Sedan(Show Car)
1954 Sedan (On the back burner)
SteveGIndy
SteveGIndy is offline
PostPosted: Tue Mar 07, 2023 11:11 am    Post subject: Re: Choosing a "key blank" Reply with quote
Old thread but i was looking for keys and found a list of key manufacturers and the corresponding part numbers that fit the Thing.
Ilco : VW71A
JMA : VO-R /VOR
Curtis : V-29/V29
Taylor : V81V
Cole : VW25
Dominion : HF32
ESP : V29R
JET : V29R
Silca : VO1/V01
Star : VW5
Orion : VW20
obus Premium Member
obus is offline
PostPosted: Wed Mar 08, 2023 7:39 pm    Post subject: Re: Choosing a "key blank" Reply with quote
https://www.thingparts.com/key-blank-original-with-black-rubber-for-locks/
smokeydogvol
smokeydogvol is offline
PostPosted: Tue Nov 19, 2024 9:41 am    Post subject: Reply with quote
Do you still deal in key blanks? I need one for my Thing as well!
sportin-wood
sportin-wood is offline
PostPosted: Wed Nov 20, 2024 1:55 pm    Post subject: Reply with quote
These are pretty cheap (for 2) on eBay. I would compare the picture to any working key you have before buying.
https://www.ebay.com/itm/151435702850?fits=Model%3...R_zFy7XpZA
Dave
1966 Bug project
1973 Thing project
[email protected]
mpb181@aol.com is offline
PostPosted: Fri Nov 29, 2024 10:58 pm    Post subject: Re: Choosing a "key blank" Reply with quote
Michael Basso
http://www.thingparts.com
New and Used VW Thing Parts Free advice
CALL 518 630 0173
T2funtimer
T2funtimer is offline
PostPosted: Sat Aug 23, 2025 2:58 pm    Post subject: Re: Choosing a "key blank" Reply with quote
First time poster. Thanks in advance for helping a new guy.
Does anyone know why my new "R" blanks don't push all the way in on my 1974 bus? I have one old key which works fine -- it is stamped V-29, and R, and it's from Curtis Industries. I ordered two R blanks from Wolfsburg West. When I push the WW keys into the locks or ignition, they stop about an 1/8" shorter than the old Curtis key. They stop about where the key grooves stop. The photo shows that the grooves are different lengths between the Curtis and new WWs. Did WW send me the wrong blanks? Why won't they go all the way in?
[email protected]
PostPosted: Sat Aug 23, 2025 3:36 pm    Post subject: Re: Choosing a "key blank" Reply with quote
Looks like you should’ve bought one of ours
Michael Basso
CALL 518 630 0173
wbailey2112
wbailey2112 is offline
PostPosted: Tue Aug 26, 2025 7:14 am    Post subject: Re: Choosing a "key blank" Reply with quote
Wrong forum. You should probably post this in the Bay Window Bus Forum.
As for the R profile key blank with VW logo shown in your post, I purchased a set of these style blanks years ago and paid a local reputable lock shop to cut new keys for my '74 Thing and had no issues whatsoever.
'74 Thing
'83 Westfalia
wbailey2112
PostPosted: Tue Aug 26, 2025 7:15 am    Post subject: Re: Choosing a "key blank" Reply with quote
As for the R profile key blank with VW logo shown in your post, I purchased a set of these style blanks years ago and paid a local reputable lock shop cut new keys for my '74 Thing and had no issues whatsoever.
'74 Thing
'83 Westfalia
