thom Samba Member
Joined: October 12, 2000 Posts: 6199 Location: Sacramento
Posted: Thu May 03, 2007 9:07 am Post subject: |
Here's a writeup I did on this several years ago
http://vintagebus.com/howto/pivot.html _________________ -Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type |
polo Samba Member
Joined: May 31, 2006 Posts: 418 Location: Pacific Palisades, CA
Posted: Thu May 03, 2007 9:40 am Post subject: |
"Write a note to the list telling everyone what a stud you are."
LoL.
Nice write up.
I should have taken pictures.
Another thing I didn't mention;
I fashioned a puller from: 8" all thread carriage bolt, a socket (I think 30mm as you suggest in your write up) a few different sized and THICK washers, a cast iron 1-1/2" close nipple (plumbing supply) with a cast iron cap with a hole drilled through it for the carriage bolt and several nuts.
I worked it by using a nut and washer at the top end with the socket below that pressing the bushings down, and a nut and washer under the cast iron piece that cupped over the bottom of the shaft opening and was long enough to take both bushings as they dropped out. I used the top nut to adjust the placement of the bolt so I could always keep a vise grip on the head to hold it from spinning. A hex head all threaded bolt would work too if you had a socket long enough to drop into the shaft and hold it as it got down to the last bit of the last bushing. (Would need to be about a 4" long socket.
Oh... and remove the shift rod early on, you'll need to do it anyway once you go to ream and it being out of the way will make the whole bushing removal much easier. _________________ Michael P.
1965 Kombi
1989 Jetta GL (R.I.P.)
2004 New Beetle Convertible GLS 1.8T
BumbleBuggy wrote: |
Nothing is cooler than driving a car that brings joy to the world simply by idling at a light. |
xavi_242 Samba Member
Joined: May 06, 2005 Posts: 1672 Location: Barcelona (SPAIN)
Posted: Sun May 13, 2007 11:58 am Post subject: |
hey guys!
here you have my job of this weekend... Like an amateur I am it takes me about 5 hours to complete the job that people that have right tools and lots of experiencie do in 2. I did with the beam in the bus... so a dirty and hard job.
0. Read the largest amount of how to's you can. Bentley is correct for the procedure, John Muir for tips but not for procedure as he recommend machine bushings before and then install... Read all related threads and the vintagebus procedure.
1. Prepare tools needed... It's not funny when you need the 17mm wrench that lays on the table and you are under the bus
2. Jack and put the bus on stands (saftety first!)
3. Remove splash pan (to an easier access) and shifter rod (necessary to let the reamer pass through)
4. remove shaft, washers, seals (remember order) and greasing nipple
5. Extract old bushings with proper extractor (If you don't have one it's easy to do a cheap one with pipe and some washers and bolts...) This is a hard job, especially when lower and upper bushing are togrther.
6. Install bushings with proper tool. If you don't have correct tool it's a VERY HARD job. I installed first lower from bottom and then upper from top. DON'T hammer to get bushings in, you can use sand paper to make bushing edge a bit more conical (a bit), then bushes come in easily. Note that upper bushing should protube 1.4-1.7mm.
7. Ream bushes until proper fitting (24mm) with an adjustable reamer. People talk about sandpaper... after doing it with a reamer I can't understand how can one remove that amount of material using sandpaper... I passed through the reamer at least 5 or 6 times (3 last times same size...) until the shaft enter tight but NOT overtight. Note you cannot do it with the shifter rod in place.
8. Clean bushings and use some iron wool. Grease assy properly.
9. Install pin and washer.
10. Install top washer, seal 'O' ring and cover. Check if the old small 'O' ring is not in the swing lever arm, mine was there and nearly I didn't see...
11. Align notch with swing lever arm. Install swing lever arm.
12. Use a 'C' clamp to compress the assy and drive the bolt. That was the last hard part of the job... Secure it with the locktab.
13. Install splashpan, shifter rod, remove stands and lower the bus.
After that experience my steering play is less than before (of course)
Some shots...
the home made extractor... :p
note wear on the old one
installing lower bushing
reamer in action
'C' clamp in action... it's important to align the holes of the swing lever arm if you want to screw the 17mm bolt...
Done!
Note old bushing groove style, not a spiral through the bushing _________________ 1967 Split SO-42 Dormobile |
Campy Samba Member
Joined: January 10, 2005 Posts: 4933 Location: Chico, CA
Posted: Sun May 13, 2007 9:32 pm Post subject: |
I removed bushings from three old frontends, lately, and I, too, noticed that they all had a different groove than the replacement bushings.
That was a real nice, step-by-step instruction. I've never done it with a frontend still in the bus. |
Posted: Sun May 13, 2007 11:50 pm Post subject: |
Campy wrote: |
I removed bushings from three old frontends, lately, and I, too, noticed that they all had a different groove than the replacement bushings. |
With the ones that groove pass through the bushing in diagonal I think it doesn't matter the position of the bushing... then with the greasing tool the grease reaches all the assy. But the one that starts and ends at the same edge if you install it upsidedown the grease will not enter into the grooves...
Campy wrote: |
thanks, I had it fresh in mind :p
Doing with beam in the bus means broken neck for 2 days... _________________ 1967 Split SO-42 Dormobile |
eh0s Banned
Joined: June 25, 2003 Posts: 760 Location: Splitsville, AB, Population = 1
Posted: Tue May 15, 2007 9:58 pm Post subject: |
I'm about to do this..
Just curious, why is the reamer used AFTER the new bushings are installed? Can't they be reamed beforehand?
(I don't have the kit in front of me).
Is the plan to make the new pin fit with the new bushes? _________________ Cootra |
commercial air Samba Member
Joined: July 19, 2005 Posts: 230 Location: Driving in the crumple zone...Regina, Saskatchewan, Canada
Posted: Tue May 15, 2007 10:14 pm Post subject: |
The new bushings compress slightly once installed. They have to be reamed to 24mm for the new pin to fit.
Chris _________________ Northern United Transporter Society
www.nuts.commercial-air.com |
Posted: Wed May 16, 2007 7:21 am Post subject: |
commercial air wrote: |
Chris |
seems impossible but it's true.
when I bought the kit the pin enter in the buishings without problem, then after tha pain of installing bushings the pin jast can't get in. So you have to ream. _________________ 1967 Split SO-42 Dormobile |
eh0s Banned
Posted: Wed May 16, 2007 12:07 pm Post subject: |
How much do they compress? It seems to me the biggest problem is the 'reaming' to get the new pin installed.
Otherwise it seems like a straightforward R&R. Shouldn't it 'compress' the same exact amount all the time?
Considering there are so many buses with 'loose' center pins, this procedure seems complicated for no reason. (A local VW shop wanted 4 shop hours to do it!) _________________ Cootra |
Posted: Wed May 16, 2007 12:12 pm Post subject: |
VW spec'd it with the beam removed back in the day. Labour was cheap then.
It's really no big deal to ream them. I guess the only hard part may be finding a reamer.
Let me know if you need one.
Posted: Wed May 16, 2007 11:39 pm Post subject: |
It's really no big deal to ream them. I guess the only hard part may be finding a reamer. |
I agree _________________ 1967 Split SO-42 Dormobile |
polo Samba Member
Posted: Thu May 17, 2007 7:14 pm Post subject: |
WW rents a reamer for $25, but as I noted above: it WILL NOT ream both bushings at once, in their correct placement with the beam in the bus. It's not long enough in the final blade dia to catch both bushings installed in their final location.
With the WW reamer, you either have to take the beam out and ream from above then from below, OR with the beam in the bus install the bushings tight against each other at the bottom, ream them and then remove them and re-install to the correct positions. _________________ Michael P.
1965 Kombi
rusbus Samba Member
Joined: August 27, 2003 Posts: 790 Location: Maryland
Posted: Thu May 17, 2007 7:27 pm Post subject: |
Quote: |
"Write a note to the list telling everyone what a stud you are." |
I just did mine - I pounded the old bushings out and the new ones in with a socket, piece of wood, and a hammer. Seemed to go just fine. What's the concern about this technique? |
Campy Samba Member
Posted: Thu May 17, 2007 8:15 pm Post subject: |
I have a bushing driver set and one of the the last bushings that I installed, a while ago, had a slight lip on the inside from the driver banging against the edge. The reamer cleans it out. |
Posted: Fri May 18, 2007 8:18 am Post subject: |
polo wrote: |
With the WW reamer, you either have to take the beam out and ream from above then from below, OR with the beam in the bus install the bushings tight against each other at the bottom, ream them and then remove them and re-install to the correct positions. |
I don't know the length of the WW reamer but mine didn't catch both bushings installed at the same time (final blade diameter)... but when I reamed (better if you do it with a buddy) I pushed at the time the reamer so it passes through both bushings from lower to upper... I think it worked fine. _________________ 1967 Split SO-42 Dormobile |
wholmes Samba Member
Joined: December 28, 2005 Posts: 1 Location: Burlington, NC
Posted: Wed Apr 18, 2018 12:14 pm Post subject: Re: Swing lever pin install |
Bought this adjustable hand reamer from Amazon for $36. Got it delivered to NC within 24 hours. Worked great. Started reaming with the reamer adjusted just a little undersize. Made multiple passes, each time increasing the size just slightly until the pin just fit into the bushings.
https://www.amazon.com/HHIP-2006-0085-16-1-1-Adjus...ullets-btf |
