rockfish Samba Member
Joined: February 13, 2007 Posts: 740 Location: Palo Alto, Calif.
Posted: Wed Jun 13, 2007 10:13 am Post subject: Vanagon/Westy Hot Foot! |
I know about the problem (and fix) where some hot air escapes the heater box and blows onto your right foot. I don't seem to have that issue right now. However, I am wondering if my problem is related to the same solution (install valve to shut off hot-coolant to heater core during hot weather).
I usually wear flip-flops ... which means I usually drive bare foot. What I have noticed is that the accelerator pedal and the carpeting directly to the right of the pedal (just below the removable heater vent) gets pretty hot - to the point of distraction while driving.
Would installing a heater core shut-off valve solve this problem? Has anyone installed the valve so that it is easy to access (w/o taking off the heater cover or going under the van)? I was thinking about creating a spot for the valve stem to poke through the heater cover ... that way I could easily turn the coolant flow off/on on an as needed basis. |
Dogpilot Samba Member
Posted: Wed Jun 13, 2007 10:26 am Post subject: |
Part of the problem is heating of the tunnel by air passing through the radiator. THis is cured by putting some kind of foil/foam insulation on the outside of the tunnel. You can kind of do an experiment by putting some cardboard (like cut from the back of a legal pad or cereal box) over the lower vent by your foot. Tape it in place and see if you still have your hot foot. Also, some hot air can come up around the accelerator linkage. _________________ Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G |
Posted: Wed Jun 13, 2007 11:30 am Post subject: |
Dog:
I'm not quite sure if I know what you mean when you refer to the "tunnel" ...
Thanks in advance. |
Posted: Wed Jun 13, 2007 11:38 am Post subject: |
If you remove the spare from the clamshell and peer up to where the shifter box is mounted. There is a tunnel like arch that the radiator van and shifter is mounted behind the radiator on the floor area. Hot air comes out of the radiator and passes down this arch or tunnel. Your foot is along the drivers side of this structure. It can get quite warm from this heating effect. The cure is to glue some Frost King type insulation on the outer surface to cut down on its ability to conduct the heat. _________________ Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G |
Posted: Wed Jun 13, 2007 12:12 pm Post subject: |
Dog:
Thanks for the detailed information. Sounds like an easy fix. I have used Frost King duct insulation behind the door panels.
http://www.homedepot.com/webapp/wcs/stores/servlet...=100028603
Is that the type of insulation you are thinking of? One layer or more? Or something thicker than this particular product?
I would imagine that you'd want to clean the metal surface first before applying the insulation. The Frost King stuff is self-adhesive, but I think this job will require a more permanent adhesive. What kind of adhesive would you recommend?
Thanks again. |
tencentlife Samba Member
Joined: May 02, 2006 Posts: 10159 Location: Abiquiu, NM, USA
Posted: Wed Jun 13, 2007 1:34 pm Post subject: |
Dog's right as usual; most of the hot-foot effect is from radiant energy coming off the metal bodywork of the post-radiator air hump. Some folks have a heater valve that's not closing completely, but if that's your problem, you can feel the warm air coming out the vents with your hand. But get the valve to close completely, and you'll still get the hotfoot while driving on hot days, especially in sandals. I'm usually wearing flip-flops all summer, too, so I know of what you speak.
VW actually had a bulletin and a kit for the "hot footwell" upgrade, it's there in Bentley, consisting of some reflective insulation to be glued to the inner surface of the radiator hump, and some fiberboard panels to be put in around the radiator to divert more of the heated air downward. My van ha it. It was minimally effective.
Whatever you use, it has to be foil-faced, not just insulative, because it's radiant energy you're trying to limit. It goes thru the carpet as if it isn't even there.
I used some Reflectix bubble-wrap I had around, and cut some to fit under the carpet around the interior surface of the hump and under the gas pedal. No adhesive was needed. cut it to a good fit, and the carpet holds it right in place and you'd never know it was there to look at it. This will be the first summer to try that out, but it's got to offer some relief compared to only having the carpet there. |
McVanagon Samba Member
Joined: February 19, 2007 Posts: 1684 Location: Northern part of the Virginia
Posted: Thu Jun 14, 2007 4:31 am Post subject: |
I've seen this mod before. This guy made a trip to the Home Depot.
_________________ '69 Mike
'85 GL
'87 Wolfsburg Hardtop |
bucko Samba Member
Joined: December 09, 2004 Posts: 2617 Location: Coppell, Texas
Posted: Thu Jun 14, 2007 4:49 am Post subject: |
That mod is good for closing off the water flow to the front heater core, but will do nothing for the warm air that flows back from the radiator.
Good post, and good idea about the insulation trick. I will be replacing the radiator when I get back from a current business trip. While I'm on my back with the spare tire clamshell removed, I will put in some insulation in that tunnel area, along with some under the carpet by the gas pedal.
Then maybe some overhead, and in the doors, and under the seats, and on the door handles, and behind the outside mirrors, and covering the hubcaps, and...... _________________ Current VW drives: 1984 Westfalia
Past VW drives: 1967 Beetle, 1973 Beetle, 1977 Bus, 1971 Military Type 181 |
Volksaholic Samba Member
Joined: December 26, 2005 Posts: 1771 Location: Salt Lake City, Utah, USA
Posted: Thu Jun 14, 2007 6:30 am Post subject: |
| tencentlife wrote: |
I'm sure it will provide some relief, but wouldn't it have been more effective between the radiator and body steel rather than between the steel and you? Having something more than carpet between you and the metal is certainly better than nothing. Reflectix looks like good stuff... and it looks like Home Depot carries at least some of the Reflectix product line.
As far as attaching it goes... I would think that cleaning up the sheet metal and using a spray or brush-on contact adhesive like 3M High-Strength 90 Spray Adhesive would work pretty well. The cured adhesive is good to about 250 degrees F, and if the insulation is between the radiator and adhesive there should be no way it will get that hot unless you live in Yuma!
I'm prepping our Wolfsburg for a 2000+ mile family vacation through No. California/Oregon in mid-July. I've got the A/C blowing cold now, new brakes and shift linkage bushings should be here from BusDepot today, then I'll have to clean up and insulate this area. I tend to drive barefoot and the aftermarket cruise control that someone installed is caput so my foot's going to be parked on the pedal! |
Posted: Thu Jun 14, 2007 10:39 am Post subject: |
| Quote: |
| wouldn't it have been more effective between the radiator and body steel rather than between the steel and you? |
Yes, definitely, but in my case, the VW fix was already there. The problem with that is that it's just not big enough, and the foil product they used is thin and heat-couples the reflective surface to the body steel. The very best fix is to get under there and glue some bubble foil all over the inside of the hump. In my case, I just wanted to try something easy. It was a 15-minute job, no glue or cleaning or cleanup required, just cut'n'fit, whereas doing the underneath would be a lot more involved and messy. So I'll see how much this helps, and if it's inadequate I can add the rest later. |
Posted: Thu Jun 14, 2007 11:35 am Post subject: |
I will definitely employ both methods ... insulating underneath and then under the carpet. In early August we're going on a 2-week trip via the Calif. coast ... while the beach temps can be mild, the heat will come up on the highway surfaces and then through the radiator and the floor. And that is something that the AC can do nothing about!
Tencent - I'll check my Bentley while I'm at it. Thanks for the tip.
As always, The Samba rocks!
camo westy Samba Member
Joined: July 23, 2006 Posts: 400 Location: Madison, Va
Posted: Thu Jun 14, 2007 7:05 pm Post subject: |
I have seen a kind of bubblewrap with aluminum foil bonded to both sides. check out www.teksupply.com
They call it teTEKFoil, and they have it in small lot sizes. It comes foil faced, with a white plastic on the oposite side. Uses include under concrete in rediant floor heating systems, so I imagine it is tough as hell.
I am going to order some soon for the hot areas of my 85 Weekender, that is getting the Subaru treatment.
I found the TekFoil, comes in 2X25 foot roll for $31 and 4X25 roll for $56, and that is the foil/bubble/foil variety.
Good Luck,
Bates |
Posted: Fri Jun 15, 2007 9:14 am Post subject: |
That's pretty much what I used. I don't remember the brand. I said Reflectix just as a generic name, like Kleenex. It might have been Tekfoil for all I know, I just have a roll here so it was handy. It came from Home Despot or one of those places. Bubble wrap with silver Mylar both sides. The bubbles assure that you have the required 3/8" airgap next to the foil that is needed for radiant barriers to be effective.
Cruised 120 miles to 'Burque yesterday, late afternoon of a pretty warm day, in sandals, and I never noticed my foot getting warm. But we've had a really cool and wet year, and it's just now finally heating up a bit, so the real test is yet to come. |
Terry Kay Banned
Posted: Fri Jun 15, 2007 11:11 pm Post subject: |
The foil insulation is a good idea and works real good.
However, another big problem which no one has mentioned is re-sealing the heater door's,in the heater box, behind the front heater core---
Let's see-- at best the newest wasserleaker is 16 years old, and that foam tape insulation that seals the heater doors is almost guaranteed to be dust.
The stock heater valve will leak some coolant to the core, and with the poor seals you will get the hot foot even though you have added a insulation barrier from the radiator's heat.
Another thing to be cautious about is the Home Depot /Menards ball valves only have a rubber seal in them , and won't shut down the coolant to the front core too long.
The rubber seals will go away pretty quick with the hot coolant, and the less expensive valve will leak just as the stock plastic valve once did.
Best locate a Parker teflon sealed ball valve.
They are a little more money, but will last as long as you own the Van, and keep the hot coolant from getting to the front core in an absolute way. _________________ T.K.
Posted: Sat Jun 16, 2007 4:51 am Post subject: |
I put a 3/4 inch gate valve back at the motor, yes its not as easy to access, but it turns off the heaat to both heaters.
I open it up at oil change time to flush out the heater cores, but I doubt that is needed with nice fresh clean orange antifreeze and the van's current pampered condition.
Heat sems to be the classic 'Feast or Famine', no middle ground. |
jjt52 Samba Member
Joined: August 21, 2007 Posts: 10 Location: Charlotte, NC
Posted: Tue Aug 28, 2007 2:12 pm Post subject: heater valve |
| Yep! I like the idea of installing a valve in the engine compartment. Just cut the hot coolant off from reaching the cabin. Every once in awhile open it up to circulate the fluid and close it off again. I had a 1971 MG Midget and it had a valve right off the engine block. Standard. Every winter we opened it back up for heat! |
Terry Kay Banned
Posted: Tue Aug 28, 2007 2:18 pm Post subject: |
The primary Heater Valve arrangement is nothing new to automotive, truck or heavy equipment.
Mack, Brockway, Diamond Reo, Diamond T, Hendrickson Trucks, & Caterpillar for instance always had a primary heater valve on the engine block, and then at the heater core thay all had a secondary ball valve.
Definate positive & total heater coolant shut down.
It would be a real good idea to mount the accesssory heater valve back near the engine. _________________ T.K. |
Perales Samba Member
Joined: May 07, 2007 Posts: 2046 Location: Nova Scotia
Posted: Fri Jun 19, 2009 11:19 am Post subject: |
VW actually had a bulletin and a kit for the "hot footwell" upgrade, it's there in Bentley, consisting of some reflective insulation to be glued to the inner surface of the radiator hump, and some fiberboard panels to be put in around the radiator to divert more of the heated air downward. |
Does anyone have a photo of this fix? I would love to see what I am getting myself into.
How much reflective insulation is required to cover the area? _________________ -- 1987 Westfalia automatic (Captain Vino) |
Posted: Fri Jun 19, 2009 5:06 pm Post subject: |
Bentley has a page or two explaining what the upgrade consists of and how to install the dealer kit. Problem is, they were on the right track but their solution was inadequate.
You understand there's two distinct problems here: the more obvious one of coolant circulating when the control valve is "closed". Remedies: adjust the cable control, if that doesn't do it get a new valve, or override the stock valve with an add-on ball valve somewhere in the coolant loop.
But, you can fix up that section and still have the hot-foot. That's because there'a great deal of radiant heat that comes thru the cowling and it roasts your gas pedal foot. The VW fix was supposed to address this but they didn't go far enough.
I always had the hot foot in warm weather and my heater valve worked perfectly; the air coming out the lower vents when the control was closed was ambient, and the hoses were never warmer than ambient when closed. Here's what I did to fix the other problem:
Pull back the carpet, and cover the whole cowling with Reflectix bubble-wrap insulation, the kind with a silver Mylar laminate. It isn't hard to trim a big piece to shape around the cowling, and just one or two pieces of tape to hold it in place until the carpet goes back up. Then the carpet holds it in place. Fixed. _________________ Shop for unique and useful Vanagon accessories at the Vanistan shop:
If you can't stop grindin' your axe, you'll just end up with a piece of hickory. Might as well burn it since no firewood's gettin' chopped.
Experience is death to doctrine. |
carterzest Samba Member
Joined: January 22, 2008 Posts: 3841 Location: Star, ID
Posted: Sat Jun 20, 2009 8:12 am Post subject: |
Pull back the carpet, and cover the whole cowling with Reflectix bubble-wrap insulation, the kind with a silver Mylar laminate. It isn't hard to trim a big piece to shape around the cowling, and just one or two pieces of tape to hold it in place until the carpet goes back up. Then the carpet holds it in place. Fixed. |
You have just had your value upgraded to TEN$LIFE.....(Stimulus!). Great info.....
Where can I get me one of those Bentley thingys
Vanagon/Westy Hot Foot!, I always called it Vanagon/Westy StinkFoot!  |
