Standard hubcaps
steven wood
steven wood is offline
PostPosted: Thu Jun 14, 2007 5:51 pm    Post subject: Standard hubcaps Reply with quote
I picked up the new car today and I wanted to find some bare metal or primered hub caps. I looked at BFY and Wolfsburg West and didn't see any. Anyone have any ideas on painting the chrome ones? I know you can paint chrome if you prep it right but I'd rather not go through the trouble.
johnshenry
johnshenry is offline
PostPosted: Thu Jun 14, 2007 6:42 pm    Post subject: Reply with quote
I bought a set of original std hubcaps a while back Steve, haven't stripped them yet. You could probably find a set of original chrome ones with bad chrome but no dents, and media blast them to strip the chrome off, then primer, scotchbrite and paint.
I'd try to find some originals before I went for repros. Of course....
John Henry
'57 Deluxe
'56 Single Cab
Richard Roth
Richard Roth is offline
PostPosted: Thu Jun 14, 2007 6:51 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/classifieds/detail.php?id=458732
The problem with reality is that there's no background music !
1966 Empi GTV MKIV
1954 Kabriolett Beetle
1953 Porsche 356 1500S
1957 Cable brake standard model
1962 cable brake standard model
1956 23 window Samba
1960 Austin Healey 3000
1961 Corvair Greenbrier
twinwindows
Samba Pimp
twinwindows is offline
PostPosted: Thu Jun 14, 2007 6:54 pm    Post subject: Reply with quote
Any chrome shop will strip the chrome off them for you. Then put some "Heavy duty" paint remover and let them sit under the sun. Later rinse them of with water and paint them and you will be good to go.
I said paint remover because they will probably not get the copper off under the chrome that's where the paint remover comes in.
John you ever try blasting chrome?
CRG
My builds
BAD TEMPER 11
CHRISTINE
GFK LIFER!
myzamboni wrote:
Yeah, everyone's now doing it GFK style . . . everythinig is covert until the finished product is revealed.
johnshenry
PostPosted: Thu Jun 14, 2007 7:01 pm    Post subject: Reply with quote
Yes I have. Black Beauty will get it off at 120 psi, but you have to "lean on it" a bit. Small handles and stuff are pretty easy. I agree that a set of hubcaps might be tedious, if you can find a chrome shop that can dip-strip (reverse electrolysis) them, that is the bast option.
Those repros in the link above don't look too bad....
John Henry
'57 Deluxe
'56 Single Cab
Brezelwerks
Brezelwerks is offline
PostPosted: Thu Jun 14, 2007 7:04 pm    Post subject: Reply with quote
You'll definitely not get anywhere blasting chrome off hubcaps, even if its flaking off, and if you do you'll risk seriously damaging them. Quality chrome shops can acid strip the chrome and if they are really good from my experience they can also get down to bare metal for you to repaint thereafter, good luck.
Gary
61vdubbug
Wildlife Wookie
61vdubbug is offline
PostPosted: Thu Jun 14, 2007 7:08 pm    Post subject: Reply with quote
Steve,
I have a buddy in Petersburg that works at a chrome shop. I'm getting my hubs de-chromed, and the '61 is getting it's bumpers re-chromed. I'm waiting until after vacation to do this, but maybe the more shit we give him at one the less it will cost. Not too sure how fast you want it done though?
72 Super Beetle
63 Beetle
61 Beetle
52 Split Beetle
"The man who views the world at 50 the same as he did at 20 has wasted 30 years of his life." - Muhammad Ali
steven wood
PostPosted: Fri Jun 15, 2007 3:17 am    Post subject: Reply with quote
What are the differences between those above and "bus" hub caps?
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211601151
Can I use bus hubcaps?
splitjunkie
splitjunkie is offline
PostPosted: Fri Jun 15, 2007 7:35 am    Post subject: Reply with quote
they are the same but those are powder coated. Good luck getting that off if you want to paint them a different color. But if you want them grey then you are all set.
Chris
Val1950
Val1950 is offline
PostPosted: Fri Jun 15, 2007 7:54 am    Post subject: Reply with quote
Status VW in the UK sell plain, un-chromed hub caps...
http://www.status-vw.co.uk/shop/en-gb/dept_15.html
