NAES Samba Member
Joined: September 10, 2003 Posts: 2191 Location: AREA-52 Southern Killafornia
Posted: Fri Jun 15, 2007 1:04 pm Post subject: |
I just wax over the bare metal with regular car wax every few months when I do the rest of the bus. Has worked well for me in the past. I use Meguiars cleaner wax which cuts off any surface oxidation _________________ Barndoor Mafia
Box On Wheels
SBS #00 |
RINC Samba Member
Joined: July 22, 2005 Posts: 3877 Location: A Sunny Place For Shady People
Posted: Fri Jun 15, 2007 2:42 pm Post subject: |
| NAES wrote: |
| I just wax over the bare metal with regular car wax every few months when I do the rest of the bus. Has worked well for me in the past. I use Meguiars cleaner wax which cuts off any surface oxidation |
I do the same an no rust is showing on the bare metal.
BTW, I gotta do it again this weekend. |
60DoubleTurd Type 3 Contributor
Posted: Fri Jun 15, 2007 3:31 pm Post subject: |
| j.pickens wrote: |
| VW_MAN_73 wrote: |
| jimmy1 wrote: |
| VW_MAN_73 wrote: |
I have easy off and goof off. Right now iam using the easy off and its working good. I have to leave it on for atleast 5 min because its been painted 5 times and in some areas 6 and not in house paint. I have to go over it a few times but it will be worth it seeing that mango come through. Iam allready seeing it I'll post pics when iam done with the rear cargo door. easy off really works. aircraft stripper is too scary and the easy off doesn't smell as bad as goof off. |
i tried that, oven cleaner and goof off, I felt its a waste of time, id do jasco paint remover and steel wool, do one section at a time. |
Yeah, iam affraid to scratch the paint with the steel wool. The easy off is working pretty good but the goof off smells bad and it doesn't work as well. Maybe i'll try that jasco sometime if I run out of easy off. Thanks. Craig. |
000 or 0000 grade steel wool won't scratch the paint.
Debris pulled up from the surface trapped in the wool can scratch, though.
Just be cautious about keeping a clean side to the paint, and it will polish, not scratch. You will need lots and lots, though. |
I used 0000 steel wool and some kind of 409 degreaser on the OG dash paint on the DD and it came out sweet. I just kept a roll of paper towels handy and got all the gunk off before respaying and rebuffiing. _________________ Frank
66 L87 Variant Pigalle
SBS #17 |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19938 Location: Land of Whine and Phonies
Posted: Sat Jun 16, 2007 1:30 am Post subject: |
It's easier to navigate the 405 than that damn site!  _________________ Your Vanagon sucks, Stop waving at me.
| HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
von_hansel  Samba Member
Joined: June 12, 2006 Posts: 867 Location: Inland Empire
Posted: Sat Jun 16, 2007 11:06 am Post subject: |
I just did the "skim" treatment to my ride and it shines nice! I used graffiti remover, oven cleaner, jasco paint remover, and for the surface rust i use steel wool and clr. I left the jasco paint remover on too long and it went to bare metal, sucks but sh*@ happens _________________
| Mugatu wrote: |
| von_hansel is still so hot right now |
vdubmax Samba Member
Joined: February 24, 2004 Posts: 509 Location: Minneapolis
Posted: Sat Jun 16, 2007 2:05 pm Post subject: |
The Skim treatment
_________________ The Original German Folks |
RINC Samba Member
Posted: Sat Jun 16, 2007 2:24 pm Post subject: |
| vdubmax wrote: |
The Skim treatment
No, Skim would have finished to job.
Post the rest Max. |
Skim Rants Master
Joined: April 15, 2001 Posts: 17098 Location: GFK 33 Year Vet
Posted: Sat Jun 16, 2007 7:50 pm Post subject: |
I did as much as I could for the day and a half I was in Phoenix and we got it pretty good. After removing all the primer we threw down on the sides etc. Heres half way thru the process. Between Max, Jay and myself, we worked on it until 1 hour before they took me to the airport to fly home and I took these after pics right before I left.
before
During
and he will have to post the afters since they worked on it all day after I flew home to Texas.
**Edit** He just sent me these..
_________________ GFK
1953 Kabriolet
1959 Lowlight Ghia vert
Skim Rants Master
Posted: Sat Jun 16, 2007 7:53 pm Post subject: |
| norman wrote: |
| I just did the "skim" treatment to my ride and it shines nice! I used graffiti remover, oven cleaner, jasco paint remover, and for the surface rust i use steel wool and clr. I left the jasco paint remover on too long and it went to bare metal, sucks but sh*@ happens |
You have any pics? Just remember the warmer it is outside the faster those chemicals go to work on that paint so keep some fresh water or a running hose near by to neutralize the stripping process. It will take off good original paint. When in doubt use fine sand paper  _________________ GFK
1953 Kabriolet
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
Skim Rants Master
Posted: Sat Jun 16, 2007 11:15 pm Post subject: |
On his bus, we went to the local auto paint store with the color code for blue-white and turkis. They made us 6 rattle cans in single stage in 20 minutes.
Basically we only used paint where it was needed. Somebody previously thought it would be a good idea to hit every knick and scratch with a D.A. so it had burrs all over it.
after final color sand and buff, the colors blended pretty well for coming right out of the spray can like that.
Next he plans on restoring his bumpers the same way. Good for him. _________________ GFK
1953 Kabriolet
sixfootdan Samba Smartass
Joined: February 13, 2002 Posts: 4852 Location: \Lo*ca"tion\, n. 1. The act or process of locating.
Posted: Sun Jun 17, 2007 4:59 am Post subject: |
This thread kicks ass, I've learned alot. _________________ Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!! |
RINC Samba Member
Posted: Sun Jun 17, 2007 10:16 am Post subject: |
| Skim wrote: |
Next he plans on restoring his bumpers the same way. Good for him. |
Saw the bus last night.
Good work y'all. |
Culito 11010101
Joined: December 07, 2006 Posts: 5882 Location: Columbia Missourah
Posted: Thu Jun 21, 2007 6:42 pm Post subject: |
Did some work on my '62 SC this week, with some cheap dollar store oven cleaner:
Gotta love the turkis!! Who would want to cover that beautiful paint up!?! _________________ © CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
| johnnypan wrote: |
| ...dont pay no attention to Culito,he's a cornhole.. |
Skim Rants Master
Posted: Fri Jun 22, 2007 9:08 am Post subject: |
Good work!^^^  _________________ GFK
1953 Kabriolet
cosmo Samba Member
Joined: February 07, 2004 Posts: 179 Location: FWB, FL
Posted: Fri Jun 22, 2007 8:26 pm Post subject: |
Just started doing some stripping on mine:
before
after
The OG paint was sanded real good prior to the primer. It is extremely thin. |
Skim Rants Master
Posted: Sat Jun 23, 2007 7:06 pm Post subject: |
| Jason M wrote: |
the begining...
during...
sweet Jay, has he found a new corner yet? _________________ GFK
1953 Kabriolet
vwdmc16 Samba Member
Joined: January 12, 2006 Posts: 1734 Location: sacramento, CA
Posted: Mon Jul 02, 2007 1:39 pm Post subject: |
im striping primer off my '66 here, this thread has given me some ideas
ive just been using 800 grit wetsanding
like the bus roof on the Trooper?
_________________ "Fiberglass is for boats and race cars-Steel is real-fix it right the first time"-Wolff
'72 Ghia: http://i111.photobucket.com/albums/n146/vwdmc17/100_1964.jpg
'72 Honda Z600
'81 Delorean
www.EVILGENIUSRACING.com |
66busman Samba Motorcyclist
Joined: September 14, 2006 Posts: 1166 Location: Madison, Wisconsin
Posted: Mon Jul 02, 2007 7:55 pm Post subject: |
Wicked flames! That must have been a rare option. _________________ '66 SO-42
'73 Bay
'75 Type 181 |
Posted: Tue Jul 03, 2007 6:45 pm Post subject: |
| Skim wrote: |
| norman wrote: |
You have any pics? Just remember the warmer it is outside the faster those chemicals go to work on that paint so keep some fresh water or a running hose near by to neutralize the stripping process. It will take off good original paint. When in doubt use fine sand paper  |
not showing pics tell it's done; which should be shortly  _________________
| Mugatu wrote: |
sleepykid Samba Member
Joined: August 25, 2006 Posts: 71 Location: Cardiff By The Sea
Posted: Wed Jul 04, 2007 2:20 pm Post subject: |
| damn mine has a thick ass layer of black on the top half...not sure if it was some kind of rust treatment paint but its thick..and ill try n get some photos in here soon.. |
