Body replacement procedure?
James Dwan
James Dwan is offline
PostPosted: Wed Jun 20, 2007 7:51 am    Post subject: Body replacement procedure? Reply with quote
I have finished the chassis work and am ready to put the body back on. I have never done thios so any pointers and suggestions would be greatly appreciated!
Basically I am wondering about lining up the holes for the body bolts and the seal.
Should I pre-cut the holes in the seal and glue it to the outer rim of the pan?
I'll be underneath while they are lowering it to see if they line up Shocked
The PO didn't put it on right, holes not aligned and used caulk instead of a seal, so I took it off and noticed a bunch of rust issues and just got done with the POR-15
Looking to do this in 3 days from now Very Happy
DAC
TCB
'59 23 Window Deluxe
'73/'77 Westfakia
'78 SuperVert
"Many dreams come true, and some have silver linings.
I live for my dreams and a pocket full of gold. Acapulco gold!" Robert Plant
Rome
Rome is offline
PostPosted: Wed Jun 20, 2007 8:39 am    Post subject: Reply with quote
It's been almost 15 yrs since I remounted a body to a pan. I would recommend gluing the perimeter seal onto the pan beforehand. For the mounting bolt holes, just make "X" slits so that the bolt can slide thru and shape the hole as needed.
Remove the shift lever, engine and seats from the pan so that the body does not have to be lifted up so high. Remember to use the thick rubber spacers between the body, at the 2 front axle mounts and at each mount in the rear wheelwells.
James Dwan
PostPosted: Wed Jun 20, 2007 12:53 pm    Post subject: Reply with quote
Thanks!
DAC
TCB
'73/'77 Westfakia
'78 SuperVert
tspot100
tspot100 is offline
PostPosted: Wed Jun 20, 2007 4:35 pm    Post subject: body install Reply with quote
I got a great tip from someone on thesamba about keeping the belly gasket in place as the body is fitted. Some pop rivet, some glue... The suggestion I used was to use fishing line . Weave it up and down the pan holes to hold the gasket in place , then either leave it, or cut it and pull it out.
SandSquid
SandSquid is offline
PostPosted: Wed Jun 20, 2007 5:13 pm    Post subject: Re: body install Reply with quote
what about rubber cement, you know.. the stuff we used to sniff back in first grade Wink
V/R
SandSquid
1974 Super Beetle, ("Put-Putt")
1971 Super Beetle Convertable (a bare shell.)
1987 Volvo 745Ti 835k Mi. "Grouchy"
1988 Volvo 764Ti 380k Mi. "Speedy"
1988 Volvo 765Ti 160k Mi. "Road Trip!!!"
conrad1468
conrad1468 is offline
PostPosted: Thu Jun 21, 2007 5:59 am    Post subject: Reply with quote
what i did for my body to pan was... i didn;t want to use any glue so i put poked the hole in the seal for the bolts then i put the seal on the floor pan and put the bolts up thru the pan seal about half way then i lowered the body on the seal and the bolts were already there and then i just worked on each bolt a little bit at a time and once they were all started into the body i cranked them all down...
check out my gallery for the resto pics... good luck
Fresh Air VW Car Club
New Pittsburgh, PA Car Club. 100% free!!!
club website link
http://groups.yahoo.com/neo/groups/FreshAirVWCarClub/info
thesamba link
http://www.thesamba.com/vw/forum/viewtopic.php?t=363031
Official website
http://www.freshaircarclub.com/
Look us up on Facebook, too
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger Gallery Classifieds Feedback
James Dwan
PostPosted: Thu Jun 21, 2007 7:59 am    Post subject: Reply with quote
Excellent ideas! I'll cut the cross for each bolt hole to hold the bolt in place and lower the body on to it. I have some fishing line just in case.
Thanks again and if anyone is in the Dallas area Sat feel free to stop by for burgers and beer Very Happy
DAC
TCB
'73/'77 Westfakia
'78 SuperVert
James Dwan
PostPosted: Mon Jun 25, 2007 6:50 am    Post subject: Reply with quote
Well the body replacement was a success. I laid the seal down and cut out a triangle on the inside of each corner to make the curve and stabbed a hole through each bolt hole. Then put the body bolt through it from underneath and it held the seal in place. We then lined up the rear two bolts and the front bolts. From then on it was easy!
DAC
TCB
'73/'77 Westfakia
'78 SuperVert
trn
trn is offline
PostPosted: Tue Aug 19, 2008 1:28 pm    Post subject: Reply with quote
I'm replacing the body in the next week or so. This thread has helped with my questions, but I'm still wondering one thing: what is the detail where the two loose ends of the seal come together? Do you just overlap one end over the other?
1971 Bug in restoration: http://vw-restoration.blogspot.com
conrad1468
PostPosted: Wed Aug 20, 2008 8:17 am    Post subject: Reply with quote
one piece i ran to the edge of the body and the other piece i cut off to meet the piece...
good luck.. it's awesome when the body is back on...
club website link
thesamba link
Official website
trn
trn is offline
PostPosted: Wed Aug 20, 2008 8:37 pm    Post subject: Reply with quote
Thanks. I'm looking forward to it. All I intended on doing was replacing the seal because it was leaking, and I ended up in three months of project creep. It WILL be nice to have the body back on.
