Removing aftermarket paint to get OG paint
Page: Previous  1, 2, 3 ... 7, 8, 9 ... 52, 53, 54  Next
NAES
NAES is offline
PostPosted: Fri Jun 15, 2007 1:04 pm    Post subject: Reply with quote
I just wax over the bare metal with regular car wax every few months when I do the rest of the bus. Has worked well for me in the past. I use Meguiars cleaner wax which cuts off any surface oxidation
Barndoor Mafia
Box On Wheels
SBS #00
RINC
RINC is offline
PostPosted: Fri Jun 15, 2007 2:42 pm    Post subject: Reply with quote
I do the same an no rust is showing on the bare metal.
BTW, I gotta do it again this weekend.
60DoubleTurd
Type 3 Contributor
60DoubleTurd is offline
PostPosted: Fri Jun 15, 2007 3:31 pm    Post subject: Reply with quote
j.pickens wrote:
VW_MAN_73 wrote:
jimmy1 wrote:
VW_MAN_73 wrote:
I have easy off and goof off. Right now iam using the easy off and its working good. I have to leave it on for atleast 5 min because its been painted 5 times and in some areas 6 and not in house paint. I have to go over it a few times but it will be worth it seeing that mango come through. Iam allready seeing it Razz I'll post pics when iam done with the rear cargo door. easy off really works. aircraft stripper is too scary and the easy off doesn't smell as bad as goof off.
i tried that, oven cleaner and goof off, I felt its a waste of time, id do jasco paint remover and steel wool, do one section at a time.
Yeah, iam affraid to scratch the paint with the steel wool. The easy off is working pretty good but the goof off smells bad and it doesn't work as well. Maybe i'll try that jasco sometime if I run out of easy off. Thanks. Craig.
000 or 0000 grade steel wool won't scratch the paint.
Debris pulled up from the surface trapped in the wool can scratch, though.
Just be cautious about keeping a clean side to the paint, and it will polish, not scratch. You will need lots and lots, though.
I used 0000 steel wool and some kind of 409 degreaser on the OG dash paint on the DD and it came out sweet. I just kept a roll of paper towels handy and got all the gunk off before respaying and rebuffiing.
Frank
66 L87 Variant Pigalle
SBS #17
crofty
Judas of the North
crofty is offline
PostPosted: Sat Jun 16, 2007 1:30 am    Post subject: Reply with quote
Skim wrote:
http://www.towerpaint.com/customcans.html
It's easier to navigate the 405 than that damn site! Mad
HamburgerBrad wrote:
von_hansel Premium Member
von_hansel is offline
PostPosted: Sat Jun 16, 2007 11:06 am    Post subject: Reply with quote
I just did the "skim" treatment to my ride and it shines nice! I used graffiti remover, oven cleaner, jasco paint remover, and for the surface rust i use steel wool and clr. I left the jasco paint remover on too long and it went to bare metal, sucks but sh*@ happens
Mugatu wrote:
vdubmax
vdubmax is offline
PostPosted: Sat Jun 16, 2007 2:05 pm    Post subject: Reply with quote
The Skim treatment
The Original German Folks
RINC
RINC is offline
PostPosted: Sat Jun 16, 2007 2:24 pm    Post subject: Reply with quote
vdubmax wrote:
The Skim treatment
No, Skim would have finished to job.
Post the rest Max.
Skim
Rants Master
Skim is offline
PostPosted: Sat Jun 16, 2007 7:50 pm    Post subject: Reply with quote
I did as much as I could for the day and a half I was in Phoenix and we got it pretty good. After removing all the primer we threw down on the sides etc. Heres half way thru the process. Between Max, Jay and myself, we worked on it until 1 hour before they took me to the airport to fly home and I took these after pics right before I left.
before
During
and he will have to post the afters since they worked on it all day after I flew home to Texas.
**Edit** He just sent me these..
GFK
1953 Kabriolet
1959 Lowlight Ghia vert
Skim
Rants Master
Skim is offline
PostPosted: Sat Jun 16, 2007 7:53 pm    Post subject: Reply with quote
You have any pics? Just remember the warmer it is outside the faster those chemicals go to work on that paint so keep some fresh water or a running hose near by to neutralize the stripping process. It will take off good original paint. When in doubt use fine sand paper Cool
GFK
1953 Kabriolet
Skim
Rants Master
Skim is offline
PostPosted: Sat Jun 16, 2007 11:15 pm    Post subject: Reply with quote
On his bus, we went to the local auto paint store with the color code for blue-white and turkis. They made us 6 rattle cans in single stage in 20 minutes.
Basically we only used paint where it was needed. Somebody previously thought it would be a good idea to hit every knick and scratch with a D.A. so it had burrs all over it.
after final color sand and buff, the colors blended pretty well for coming right out of the spray can like that.
Next he plans on restoring his bumpers the same way. Good for him.
GFK
1953 Kabriolet
sixfootdan
Samba Smartass
Location: \Lo*ca"tion\, n. 1. The act or process of locating.
sixfootdan is offline
PostPosted: Sun Jun 17, 2007 4:59 am    Post subject: Reply with quote
This thread kicks ass, I've learned alot.
Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!!
RINC
RINC is offline
PostPosted: Sun Jun 17, 2007 10:16 am    Post subject: Reply with quote
Saw the bus last night.
Good work y'all.
Culito
11010101
Culito is offline
PostPosted: Thu Jun 21, 2007 6:42 pm    Post subject: Reply with quote
Did some work on my '62 SC this week, with some cheap dollar store oven cleaner:
Gotta love the turkis!! Who would want to cover that beautiful paint up!?!
© CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote:
Skim
Rants Master
Skim is offline
PostPosted: Fri Jun 22, 2007 9:08 am    Post subject: Reply with quote
Good work!^^^ Cool
GFK
1953 Kabriolet
cosmo
cosmo is offline
PostPosted: Fri Jun 22, 2007 8:26 pm    Post subject: Reply with quote
Just started doing some stripping on mine:
before
after
The OG paint was sanded real good prior to the primer. It is extremely thin.
Skim
Rants Master
Skim is offline
PostPosted: Sat Jun 23, 2007 7:06 pm    Post subject: Reply with quote
Jason M wrote:
the begining...
during...
sweet Jay, has he found a new corner yet?
GFK
1953 Kabriolet
vwdmc16
vwdmc16 is offline
PostPosted: Mon Jul 02, 2007 1:39 pm    Post subject: Reply with quote
im striping primer off my '66 here, this thread has given me some ideas
ive just been using 800 grit wetsanding
like the bus roof on the Trooper? Laughing
"Fiberglass is for boats and race cars-Steel is real-fix it right the first time"-Wolff
'72 Ghia: http://i111.photobucket.com/albums/n146/vwdmc17/100_1964.jpg
'72 Honda Z600
'81 Delorean
www.EVILGENIUSRACING.com
66busman
Samba Motorcyclist
66busman is offline
PostPosted: Mon Jul 02, 2007 7:55 pm    Post subject: Reply with quote
Wicked flames! That must have been a rare option.
'66 SO-42
'73 Bay
'75 Type 181
PostPosted: Tue Jul 03, 2007 6:45 pm    Post subject: Reply with quote
not showing pics tell it's done; which should be shortly Very Happy
Mugatu wrote:
sleepykid
sleepykid is offline
PostPosted: Wed Jul 04, 2007 2:20 pm    Post subject: Reply with quote
damn mine has a thick ass layer of black on the top half...not sure if it was some kind of rust treatment paint but its thick..and ill try n get some photos in here soon..
Page 8 of 54
