57veedub Samba Member
Joined: March 28, 2007 Posts: 42 Location: Alta Loma, So-Cal
Posted: Tue Jul 03, 2007 5:33 pm Post subject: Zwitter? |
so im curious other then the obvious (oval dash with split rear window) whats special about a zwitter and whats the story behind them?
why didint vw make more zwitters? _________________ 1957 oval ragtop baja |
thebucket Samba Stockbroker
Joined: April 06, 2004 Posts: 3734 Location: Houston Texas
vwwitch Samba Member
Joined: February 05, 2005 Posts: 74 Location: hagerstown maryland
Posted: Wed Jul 04, 2007 5:14 am Post subject: zwitter |
i have a zwitter and the differences i know of r as follows ...
there is a push button starter button on the left of the steering wheel , heart tail lights, dome light switch under the dash on the left of the steering wheel , dome light without an on off switch on it , speedo is a 6 month only speedo it has 2 separate arrows on it to indicate the signal is on , ash tray is different then an oval , there is an A/Z on the heater nob , the ignition switch is an on and off and is a zwitter only ,
as far as i can think thats all i can remember ... if i think of anything else ill post it ... |
working dog Samba Member
Joined: September 10, 2006 Posts: 22 Location: LA.CA.
Posted: Wed Jul 04, 2007 6:48 am Post subject: |
| Hey vwwitch my nov 5 1953 oval has all off the parts you just mentioned not zwitter only.These parts were used mid 1952 till dec 1953. Hope this helps ! |
John Moxon  Samba Moderator
Joined: March 07, 2004 Posts: 14262 Location: Southampton U.K.
Posted: Wed Jul 04, 2007 10:22 am Post subject: |
| did not know that about using the parts till dec 53 ... thanx for the info |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17685 Location: Left coast, Canada
Posted: Wed Jul 04, 2007 10:39 am Post subject: |
| thebucket wrote: |
| They were using up old parts before the ovals went into full production..... |
Nope! That is a common conclusion that isn't true most of the time. When you are manufacturing as many cars per day as VW was, planning parts delivery is extremely important. There is no way VW had 4-5-6 months of inventory hanging around to use up. Besides, the only difference between a zwitter and the first ovals is the roof stamping, rear glass and rear window rubber. How many roof stampings do you think they had piled up in heaps in Oct 52 that they had to "use up"? Enough to keep production going until Mar 53? _________________
| overheard at the portland Swap Meet... wrote: |
| ..... a steering wheel made from a mastadon tusk..... |
banana split Samba Member
Joined: January 22, 2002 Posts: 1137 Location: Beautiful British Columbia Canada
Posted: Wed Jul 04, 2007 12:15 pm Post subject: |
And remember, those Zwitter roof stampings are different than the earlier split ones if you consider where the interior light was located. The earlier splits had a big round light mounted above the "split" and Zwitters had them mounted in the same location as an oval etc. That big round hole for the early splits had to be stamped out. And yes I realize the big hole was stamped into a separate panel that was welded to the roof section. _________________ My Beetles :
1953 Zwitter
1964 Chop Top |
passoa55  Samba Member
Posted: Wed Jul 04, 2007 1:05 pm Post subject: |
A zwitter haves also an alluminium font hood handle, same model as oval. _________________ 1950 Hebmuller #458
1952 Azure blue crotch cooler ragtop
1953 original paint oval ragtop
1955 lowlight lizard green
1955 original paint oval
1956 1600 super V-sunroof Porsche
1958 lowlight ghia black
1967 SO42 westy
1969 original paint Westy
1970 one owner 1300L bug |
Posted: Wed Jul 04, 2007 1:09 pm Post subject: |
thanks everyone for the positive answers
i always thought there was more differance other then just the roof stamp _________________ 1957 oval ragtop baja |
IN2VWS Samba Member
Joined: January 29, 2006 Posts: 2556 Location: Australia
Posted: Wed Jul 04, 2007 2:24 pm Post subject: |
I was speaking to a nice guy in Germany in April this year. He had a Zwitter, and has owned it for over 30 years. It was a very nice example of the car.
Whether this is true or not I don't know, but he told me the reason the Zwitter was not an oval is because there was issues with the curved glass of the oval windows, so they continued with the split window until the problems with the curved glass was sorted out. But the intention was for it to be an oval from October 1952. _________________ ( ⫏ ⫐ )
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹ ¹⁹⁵⁸
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³ |
25horseboxer Samba Member
Posted: Wed Jul 04, 2007 3:01 pm Post subject: |
| Also, the "split" rear window in a Zwitter has Aluminum trim. a split doesn't. |
52HoffmanSplit Samba Member
Joined: April 07, 2006 Posts: 1276 Location: Lamorinda CA
Posted: Wed Jul 04, 2007 3:41 pm Post subject: |
| IN2VWS wrote: |
Whether this is true or not I don't know, but he told me the reason the Zwitter was not an oval is because there was issues with the curved glass of the oval windows, so they continued with the split window until the problems with the curved glass was sorted out. But the intention was for it to be an oval from October 1952. |
This may have some truth to it as the reason the Split Window was originally adopted was due to the expense of curved glass in 1937/38 and the fact they were trying to get and keep the VW38 and 39's under the 1000RM price. (Split was introduced in the VW303.. and designed as usual by Erwin Komenda).....Curved rear glass would have blown the budget on the KDF-Wagen. (or... thats what they thought!!)
This is all in Chris Barber's "Birth of the Beetle"... which I think is a fascinating book... not sure what everyone else thinks of this one... it has some great pictures and quite a bit of technical background. It's more like a really COOL coffee table book.. but definitely gives some good info. _________________ DB
11/1966 Porsche 912
7/1968 Type 265 Double Cab
4/1955 Type 117 - 3 Fold |
Dave Haviland Samba Member
Joined: June 26, 2005 Posts: 322 Location: Burlington, Vermont
Posted: Wed Jul 04, 2007 4:54 pm Post subject: |
Do early ovals have the rectangular headlight switch like a zwitter? Same ash tray?
Dave |
Posted: Thu Jul 05, 2007 8:29 am Post subject: |
| Yes my 53 oval has same ash tray and rect. lite switch. |
usariemen Samba Member
Joined: August 28, 2004 Posts: 1745 Location: Germany
Posted: Thu Jul 05, 2007 2:34 pm Post subject: |
Zwitter ashtrays have no handle, 53 ovals have the little chromed handle on the ashtray but not yet the later chrome frame around. _________________ Master of my domain! |
Zwitter Samba Member
Joined: November 01, 2003 Posts: 227 Location: Las Vegas
Posted: Thu Jul 05, 2007 6:02 pm Post subject: Zwitter |
All the noted facts concerning the Zwitter models have been accurate!
I have been wating to see if there would be a posting by anyone in reference to the non-anodized body side mouldings, door window aluminum scraper frames, and running board trim, which match the mouldings found in the window rubbers.
I think over the years these mouldings have been replaced during "restoration", the owners liking the look of the shiny anodized trim.
It's certainly not easy to find the original trim mouldings. |
bam Samba Member
Joined: April 28, 2004 Posts: 691 Location: Cameron park CA
Posted: Fri Jul 06, 2007 5:14 pm Post subject: |
don't forget the antenna lump in the roof. _________________ hi |
53 0val Samba Professor
Joined: July 03, 2003 Posts: 11396 Location: Irvine, CA
Posted: Fri Jul 06, 2007 5:45 pm Post subject: |
A difference between a Zwitter and a '53 oval not mentioned is that the interior light has NO switch at the light......a '53 oval has a two position light switch and in '54 they got the familiar three position light switch. _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Posted: Sat Jul 07, 2007 8:40 pm Post subject: |
| as far as i know there is no hump on the roof for an antenna ... my zwitter doesnt have it and neither does my friends ... |
