67 Only Battery Tray
OG Velvet
Samba Family Man
OG Velvet is offline
PostPosted: Tue Jul 03, 2007 9:27 am    Post subject: 67 Only Battery Tray Reply with quote
I searched but came up empty.
I would like to see a picture of a stock 67 battery tray with the strap and everything. I just bought an nos battery tray, but I have no idea how the battery straps down. When I replace it, I want it to look factory.
Thanks!
'67 13 Window
'77 Westy
'69 Sunroof Beetle
'65 Honda Dream
Major Woody
Samba Enigma
Major Woody is offline
PostPosted: Tue Jul 03, 2007 1:14 pm    Post subject: Reply with quote
There are no straps. A 67 clamps the battery from the base. On the back side there is an L-shaped clip, fixed in place like what you would see on a late bug pan. On the front side there is a removable galvanized clamp with a bolt going downward through it to clamp the battery in place. The bolt threads into a weldnut mounted to the underside of the tray. Come on by this week and check out the original tray and clamp in my 67 if you would like to take exact measurements. I think you have my number. I'll be on vacation until the 14 Surprised
crofty
Judas of the North
crofty is offline
PostPosted: Tue Jul 03, 2007 1:36 pm    Post subject: Reply with quote
Major Woody wrote:
On the front side there is a removable galvanized clamp with a bolt going downward through it to clamp the battery in place. The bolt threads into a weldnut mounted to the underside of the tray. o
Similar to a bay window bus
HamburgerBrad wrote:
Major Woody
Samba Enigma
PostPosted: Tue Jul 03, 2007 2:24 pm    Post subject: Reply with quote
Damn, I'm proud to say I wouldn't know. Razz
crofty
Judas of the North
crofty is offline
PostPosted: Tue Jul 03, 2007 7:35 pm    Post subject: Reply with quote
You need to get your "'67 only" learn on then partner!
Jerry J
Jerry J is offline
PostPosted: Wed Jul 04, 2007 10:19 am    Post subject: Reply with quote
A photo would be really cool. Very Happy My bus has remenants of a battery tray and fitted sheet of plywood. I'm waiting for the day when I see my battery go bouncing down the highway. Laughing
Jerry
'58 Bug
'63 KGhia
'67 Squareback
'67 Standard Bus
'60 Single cab
crofty
Judas of the North
crofty is offline
PostPosted: Wed Jul 04, 2007 11:15 am    Post subject: Reply with quote
Jerry J
Jerry J is offline
PostPosted: Wed Jul 04, 2007 1:45 pm    Post subject: Reply with quote
crofty wrote:
Thank you...that will work. I looked on the Failsure sited but couldn't find anything like this. I musta not looked hard enough.
Brian, where did you find that battery tray? I've never seen an NOS or any '67 specific trays advertised here on TheSamba.
Jerry
'58 Bug
'63 KGhia
'67 Squareback
'67 Standard Bus
'60 Single cab
Major Woody
Samba Enigma
PostPosted: Wed Jul 04, 2007 1:57 pm    Post subject: Reply with quote
One other thing about a 67 is the vertical piece at the forward edge of the tray where the tray meets the rear edge of the wheelwell. I presume that the intended purpose of the piece is to keep the battery from sliding forward, but what it really does is trap dust and crap that comes in the vents, where it accumulates, gets wet and rusts out. I had to patch mine. Here is a photo of the tray area of my bus. The clamp is not on because I am having it hot dip galvanized. I can take another one with the battery out if necessary.
The battery strap is just sitting there as the bus is apart at the current time.
And yes Dave, all my hardware is original Kamax, re-plated! Razz
crofty
Judas of the North
crofty is offline
PostPosted: Wed Jul 04, 2007 2:02 pm    Post subject: Reply with quote
What's the yellow wire for?
Major Woody
Samba Enigma
PostPosted: Wed Jul 04, 2007 2:08 pm    Post subject: Reply with quote
Alarm trigger. Pinswitch is mounted underneath the hatch seal so the switch opens when the seal is compressed by the decklid. From that angle you can see it if you know what to look for. I do have a locking handle as well.
splitpile
Samba's Worst Speller
splitpile is offline
PostPosted: Wed Jul 04, 2007 2:25 pm    Post subject: Reply with quote
Kassic Fab make 67 only trays. I have a couple coming on my next shippment.
"no more hacking my sig line"
BarryL Premium Member
BarryL is offline
PostPosted: Wed Jul 04, 2007 3:33 pm    Post subject: Reply with quote
Ronnie I'll probably be getting one for the wrecked '67 Westy. Here's a shot of the '67s battery area. It's been coated with epoxy and red oxide primer a couple times to stop the acid.
Here's the battery bracket.
Here's the battery holddown. Notice the bolt has a self cutting tip. It's missing a washer I think.
PostPosted: Wed Jul 04, 2007 7:37 pm    Post subject: Reply with quote
Major Woody wrote:
Just to be annoying, you are missing the extra sheathing on your positive battery cable that keeps it tight in the battery cable holder on the wheel well.
Jerry J
Jerry J is offline
PostPosted: Wed Jul 04, 2007 8:18 pm    Post subject: Reply with quote
Ronnie, do you have prices for the tray? Does it come with the part "82" from the drawing?
I also need to get prices on a passenger side rocker which would include the outer, the inner-inner and the inner rocker for my '67, please.
Jerry
'58 Bug
'63 KGhia
'67 Squareback
'67 Standard Bus
'60 Single cab
crofty
Judas of the North
crofty is offline
PostPosted: Wed Jul 04, 2007 8:26 pm    Post subject: Reply with quote
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111701433
I thought the rockers were $85 at BOR, but I may be wrong.
splitpile
PostPosted: Wed Jul 04, 2007 10:58 pm    Post subject: Reply with quote
I am curently on my 1st family Vacation in 15 years (closed till July 10th). Off the top of my head the cargo door rocker and strethener are 885 dollars, the 67 only battery tray I believe between 80 and 90. It does nnot come with the clamp but that is a very common item and if I took a magnet in the yard behind my shop 'd probaly find some
crofty
Judas of the North
crofty is offline
PostPosted: Wed Jul 04, 2007 11:30 pm    Post subject: Reply with quote
Holy f'n mark-ups Batman!! Wink
Metalwizard
Metalwizard is offline
PostPosted: Thu Jul 05, 2007 6:36 am    Post subject: Reply with quote
Here you go, i think its runs from mid 66 -67. as i have did a couple 66 with this style tray.
battery tray $85.00, I have 1 in stock.
also the rocker cost is
outer and strengther $85.00
outer, strenghter, inner rocker $120.00 that $5.00 discount by buying all 3 pcs at once.
http://s461.photobucket.com/albums/qq335/Metalwizard/
Kelly aka
"Bubble & Nut Buster for wannabe BadBoy's of Restoration"
"There is no cure for Stupid"
ITMC "Drill SGT"
View user's profile Send private message AIM Address Yahoo Messenger Facebook Gallery Classifieds Feedback
Metalwizard
PostPosted: Thu Jul 05, 2007 6:37 am    Post subject: Reply with quote
LOL, don't have a cornary Crofty. Ronnie had a miss type. ROFLMAO
Kelly aka
ITMC "Drill SGT"
