Installing a dual master cylinder
65Busstop
65Busstop is offline
PostPosted: Thu Jan 22, 2004 6:34 pm    Post subject: Installing a dual master cylinder Reply with quote
I was thinking about putting a dual master cylinder in my 65 Bus for safety reasons. Has anyone done it? And is there much invovled in doing it?
TIA
ronnie
Location: lost somewhere between the earth and my home.
ronnie is offline
PostPosted: Thu Jan 22, 2004 6:58 pm    Post subject: Reply with quote
go to www.type2.com
click on library
click on brakes
there is an article by eric and barb on how to do the conversion at the bottom of the page.
I'd rather be a free man in my grave, than living as a puppet or a slave.
_____________________
http://www.rideable.org/
http://www.oslp.org/
dstefun
dstefun is offline
PostPosted: Fri Jan 23, 2004 2:34 am    Post subject: Reply with quote
Just did it following Eric & Barbs article. Cut my own spacer out of 3/8" phenolic instead of paying Wolfgang $40 for their aluminum one. http://www.wolfgangint.com/html/SinglePartDisplay....1472958219
Used a 70's Rabbit reservoir ($4 from PickNPull) to match a new 70's bay M/C, had to get a new T-fitting and an extra 6" line for the front lines, and a couple longer bolts. Bent existing lines slightly to get everything to fit, and made a new shaft from a new metric bolt to connect to the pedal. Haven't tested it yet as the brakes still need to be adjusted and bled. All in all pretty easy to install, took several hours including parts fabrication time. The main problem locally is nobody stocks metric brake lines, T-fittings, etc. so I had to order them.
Radio Questions R Us - what'cha need to know?
"Out! Out! You demons of stupidity!"
Remember - You are required to get older but you are not required to grow up!
62 SC & 66 Bus
Mr Tim
Mr Tim is offline
PostPosted: Wed Feb 18, 2004 4:39 pm    Post subject: Duel master cylinder Reply with quote
You mention in this thread using a "rabbit" master cylinder resevoir, would that be what we in the uk know as a "golf" and you say from the 70`s is that correct. Confused
Do Your Bit Save A Split
"Lifestyle is the art of discovering how to live uniquely" --- Jim Rohn
dstefun
dstefun is offline
PostPosted: Wed Feb 18, 2004 7:31 pm    Post subject: Reply with quote
Over here Golf & Scirocco came out in '74 and Rabbit in '75. I'll bet they're all pretty much the same reservoir. Even a 70's and maybe 80's Volvo reservoir will fit. Just make sure the distance between the nipples on the reservoir match the master cylinder. And buy new rubber seals for the top of the master cylinder where the reservoir plugs into it. Wink And a 1/2" or maybe even 5/8" spacer would be better than the 3/8" one I made. Then the filler on the reservoir will be that much closer to actually being under the hole in the floor.
62 SC & 66 Bus
