Lever shocks
JDV
JDV is offline
PostPosted: Thu Sep 13, 2007 3:25 pm    Post subject: Lever shocks Reply with quote
I was hoping that I could get some good pictures of how the lever shocks are mounted to the spring plate. My spring plates were fitted with "custom" mounts for gas shocks, and I don't see any evidence of a spot to mount the lever arm.
thanks in advance
PostPosted: Thu Sep 13, 2007 10:09 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/classifieds/detail.php?id=451419
That eye bolt goes through the spring plate mounting hole. The 2 plates connect to the lever shock.
The lever shocks themselves mount to the body, not the spring plate.
Scotty
Scotty is offline
PostPosted: Fri Sep 14, 2007 12:46 am    Post subject: Reply with quote
They mount to the torsion tube end casting on a barndoor
JDV
JDV is offline
PostPosted: Fri Sep 14, 2007 9:37 am    Post subject: Reply with quote
My single cab had the lever shock lever arms cut off, so I bought some cores to build a couple of good ones. So If I understand so far, I need the bolts with the eyes, and then the metal strap. It looks like I might be able to fabricate those. What I will need to know is the location of the holes on the spring plates, so I can drill for the mounting bolts. I am assuming that I can use the later model spring plates that are now on there and just drill for the holes?
PostPosted: Fri Sep 14, 2007 12:55 pm    Post subject: Reply with quote
You don't have Barndoor spring plates on your Barndoor?
The holes are the same as a Bug spring plate with the axle cutout and 3 holes if you have one of those on-hand.
There is one eye bolt and 2 metal plates per side.
Brezelwerks was selling the plates and some other hardware at one point but i don't see an ad for them from that seller anymore.
JDV
JDV is offline
PostPosted: Fri Sep 14, 2007 2:53 pm    Post subject: Reply with quote
Looks like I don't understand how the lever attaches to the spring plate. The lever didn't look long enough to reach where the axle tube is bolted to the spring plate, so I assumed that those eye bolts attached somewhere along the spring plate, and therefore there should be a hole somewhere. So any pics would help out alot.
PostPosted: Fri Sep 14, 2007 3:31 pm    Post subject: Reply with quote
The eye bolt passes through the front spring plate mounting point:
JDV
JDV is offline
PostPosted: Fri Sep 14, 2007 5:46 pm    Post subject: Reply with quote
That is great diagram, thankyou very much. I bought those lever shocks from you and I am figuring out how it should all fit together.
Anchovy
Anchovy is offline
PostPosted: Fri Sep 14, 2007 9:20 pm    Post subject: Reply with quote
Here's a grimey real world photo:
PostPosted: Fri Sep 14, 2007 9:25 pm    Post subject: Reply with quote
Let me know what it takes to get the arms swapped over. I have another set I need to do at some point.
jingram
jingram is offline
PostPosted: Fri Jul 16, 2010 9:00 pm    Post subject: Reply with quote
So I know that this is kind of an old thread, but what I was wondering is what those of you, who don't have lever shocks, have done to add conventional rear shocks to a barndoor. Anyone want to post up some ideas or photos?
Thanks
BeaterBarndoor
BeaterBarndoor is offline
PostPosted: Fri Jul 16, 2010 10:15 pm    Post subject: Reply with quote
Concept1 came up with a nice clean idea,i made my own version of it just recently.
Concep1's forum..
http://www.thesamba.com/vw/forum/viewtopic.php?t=380453
couple photos of his set up
my version...
www.thebustransfer.com
Whaaaaat?
nlorntson
Crazy VW Lady
nlorntson is offline
PostPosted: Sun Jul 18, 2010 7:35 pm    Post subject: Reply with quote
I have a set of nearly NOS what I believe to be barndoor lever shocks that I would really like to get in the hands of a deserving barndoor in exchange for a pair of type 1 single action lever shocks as seen in this picture:
The part number on the dual action ones I have begins with a 211 so is it safe to assume they fit all barndoors or a particular year range?
I'm planning to place an ad for a swap and I want to have the details correct.
PostPosted: Mon Jul 19, 2010 10:45 am    Post subject: Reply with quote
Yes, 211 are Barndoor Bus level shocks.
Earlier ones have 29A on the cover because of the earlier part number scheme but I don't believe they have any internal differences.
Rick
Rick is offline
PostPosted: Sun Dec 05, 2010 9:45 am    Post subject: Reply with quote
I'm looking for information on the linkage pictured below. Are these available anywhere, or is fabricating your own the way to go? Aren't there two pieces per side? I need these as well as the eye bolts. Are barndoor and split beetle eye bolts the same? I get the impression that they are not.
PostPosted: Sun Dec 05, 2010 10:02 am    Post subject: Reply with quote
Brezelwerks told me he was going to make the linkages but I don't know if he ever did. This was a few years ago.
Super old ad
http://www.thesamba.com/vw/classifieds/detail.php?id=248382
The eye bolts are different according to these Gallery entries:
http://www.thesamba.com/vw/forum/album_page.php?pic_id=494396
http://www.thesamba.com/vw/forum/album_page.php?pic_id=494397
Shorter shank/more threads is the Barndoor one according to the links above.
