Anyone add reverse lights??
mintonman
mintonman is offline
PostPosted: Sun Sep 23, 2007 6:58 pm    Post subject: Anyone add reverse lights?? Reply with quote
Looking for ideas for reverse lights/light on my 59. I almost backed into a car due to a light in front of me reflecting on my rear window(singlecab), so I couldn't see shit. I had 2 crappy square ones hidden under my rear bumper before, but they were only on there for a short time due to a speed bump smashing them into a billion pieces Laughing Laughing It was funny I have to say cause they didn't really help much being under the bumper and they were just stupid looking, so now I'm thinking of putting a(1) clear foglight back there on top of the bumper & am wondering if anyone has done this & how it worked out visually or if there are any other ideas out there??
Hoockd on fonicks werkt for mee?
under the influance "DUH"
Culito
11010101
Culito is offline
PostPosted: Sun Sep 23, 2007 8:10 pm    Post subject: Reply with quote
I was thinking about doing this soon.
I just want a simple round light mounted on the overrider that I can also swivel around and/or detach for an engine bay light.
I'll have it switched on the dash.
© CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote:
Andrew
Andrew is offline
PostPosted: Sun Sep 23, 2007 9:22 pm    Post subject: Reply with quote
I've been thinking about this for a while, and just adding them to the bumper with custom brackets so they'd bolt on on a '67 Beetle. Never really got around to doing it, though. Laughing
-Andrew
Clara Premium Member
Clara is offline
PostPosted: Sun Sep 23, 2007 9:30 pm    Post subject: Reply with quote
It's a '67ish bug reverse light tucked in betwen the bumper and left bumper tube.
I wired it with a connector so I could unplug the wire for when I have to pull the bumper off. The light is aimed slightly to the left.
The bracket is a 67ish bug bracket 'massaged' into shape, bolted to the bumper at an existing bolt, no holes drilled in bus or bumper. I used a 67 nose cone.
After I hooked up the reverse light, people were often courteous about waiting for me to back out of a parking space. Shocked
pyrOman
Fire Master
pyrOman is offline
PostPosted: Mon Sep 24, 2007 7:29 am    Post subject: Reply with quote
Clara wrote:
It's a '67ish bug reverse light tucked in between the bumper and left bumper tube.
I've had that same set up before on my old bus in Puerto Rico. Yes, they are great for backing up at night but I used it more while driving on the island since there were plenty of corksuckers there driving with their high beams on! Evil or Very Mad
TeamSpatula
Samba In The Rain
TeamSpatula is offline
PostPosted: Mon Sep 24, 2007 7:43 am    Post subject: Reply with quote
A friend of mine did a similar setup, but with 2 '67 backup lights - 1 on each side...I finally scored 1 myself, and am waiting to find another before copying that setup...
<---Air Cooled Search & Rescue Team - STICKERS & T-shirts for sale!
1981 Diesel Rabbit
I NEED A CAMPER!!!! (1971 is ideal but will consider other years)
http://www.TeamSpatula.com
crofty
Judas of the North
crofty is offline
PostPosted: Mon Sep 24, 2007 7:44 am    Post subject: Reply with quote
This one is hooked up with the speedo cable switch. The one on my '65 ( in the same spot) has the switch on the nosecone.
HamburgerBrad wrote:
CarlSpackler
CarlSpackler is offline
PostPosted: Mon Sep 24, 2007 2:12 pm    Post subject: Reply with quote
When I got my SC it had exactly the set up you described. A rather large, round light on the left side of the rear bumper, with a pull switch mounted under the dash behind the speedo (pull a switch similar to the light switch toward the floor to turn it on). Problem with that set up is the the rear gate smacked it when it was down. I bought a pair of beetle lights I plan on putting between the overrider and the bumper, like on Clara's photo. I thought about getting one of those speedo switches (I've seen them here and on ebay numerous times) but I decided I'd rather have it on a switch so I can use it as a bright light response, as mentioned previously, or for tail-gaters. My plan also includes a self fabricated clamp type mount so I don't have to drill a hole in the bumper. Not that it would hurt my current bumper at all, but for one day when I get a real bumper Laughing
'67 Micro Bus
'73 Thing
'91 Westy
Culito
11010101
Culito is offline
PostPosted: Mon Sep 24, 2007 2:19 pm    Post subject: Reply with quote
Didn't think about the rear gate thing....but I still want to be able to multi-purpose it. Engine bay, tailgaters, and generally confusing people...
'62 bug
johnnypan wrote:
Fish
Fish is offline
PostPosted: Mon Sep 24, 2007 5:18 pm    Post subject: Reply with quote
He's my two cents. I put a pair of stock 68 back up lights in my 63 bus. Cut the body above the tail lights and installed like stock. They hook up to the trans and worked great, but still couldn't see as well as I would like when backing up. SO I installed a off-road light on the rear roof of my camper. Sure lite things up behind me, could see great and would back off tail gaters, but it was too bright for loading or un-loading a trailer or the bus when camping. SO I installed a 8 foot stainless steel buggy whip on the bumper with a single 12v light bulb mounted on top. This was perfect for camping, loading the bus or tailer at night. It lite up a very large area around the bus with out blinding you and in a pinch I could bend it down to lite up inside the engine compartment.
Prosit!
# 303 and #156
Slowlow Premium Member
Slowlow is offline
PostPosted: Mon Sep 24, 2007 6:32 pm    Post subject: Reply with quote
Clara wrote:
Hate to get off topic... but that is just one of the coolest pics Shocked
• Metal Fab & Quality Suspensions, Type I-II-III. Since 2004 •
Clara is offline
PostPosted: Mon Sep 24, 2007 8:45 pm    Post subject: Reply with quote
Thanks!
RINC
RINC is offline
PostPosted: Mon Sep 24, 2007 9:53 pm    Post subject: Reply with quote
Clara wrote:
Thanks!
Off Topic #2.
That pics is cool X2 Clara.
stephenmullens Premium Member
stephenmullens is offline
PostPosted: Mon Sep 24, 2007 10:55 pm    Post subject: Reply with quote
This is perfect. I'll be doing this to our 65 the next time we pull the trans.
PostPosted: Mon Sep 24, 2007 10:56 pm    Post subject: Reply with quote
RINC wrote:
Clara wrote:
Thanks!
Off Topic #2.
X3
swervyjoe
swervyjoe is offline
PostPosted: Tue Sep 25, 2007 12:14 am    Post subject: Reply with quote
here is mine. its a cheapo H3 foglight that i bought off of here a while back.
photo snagged from UZI
xavi_242
xavi_242 is offline
PostPosted: Sat Feb 07, 2009 1:17 am    Post subject: Reply with quote
Ok, I have a nose cone without switch Sad
Don't want to install an in-line speedo switch because people say they don't work fast, correct me please.
Is there any way of fitting a universal switch under the shift stick?
thanks
Xavi
1967 Split SO-42 Dormobile
mightymouse
mightymouse is offline
PostPosted: Sat Feb 07, 2009 9:13 am    Post subject: Reply with quote
thanks
Xavi
I think you should just hook them to a toggle switch on your dash. I mean, it would be nice to have them work exactly when you shift to reverse, but they arent necessary when the sun is out. So if you dont have the nosecone, and dont want to use the cable drive.... use a switch. Smile
I had planned on building a bracket setup to weld onto the shiftrod and frame of a bus for a friend, so he could have reverse lights...but the bus was sold.
Have fun either way xavi, show us your setup when its done.
Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
Know your ZDDP levels or you WILL lose a cam and lifters.
BarryL Premium Member
BarryL is offline
PostPosted: Sat Feb 07, 2009 9:27 am    Post subject: Reply with quote
I would think a tab attached to the shift rod with a normally open button that is bumped could be used somehow as the rod only swings that far during reverse Make the tab as wide as the slide motion so it can contact all during the slide.
Eric&Barb
Eric&Barb is online now
PostPosted: Sat Feb 07, 2009 10:42 am    Post subject: Reply with quote
VW in the 1950s and early 1960s sold kits with that setup.
Personally we prefer to just find a parking spot that can be driven through into the next so backing out is not required. Failing that, backing into the parking spot and being able to just drive forward out is a lot safer. Kind of obvious to other drivers that your moving around when you are backing into a parking spot.
Before doing this as a norm, had three minor fender benders with the panel camper when backing sloowly back out of parking spots with turn signal on and looking back and forth at both exterior mirrors.
Here is a simular backup light (with images of the tab kit) forum on the K. Ghia side:
http://www.thesamba.com/vw/forum/viewtopic.php?p=3589996#3589996
In Stereo, Where Available!
