Large tire/big meats - Stock suspension Bus thread
Page: 1, 2, 3 ... 103, 104, 105  Next
mpribanic
mpribanic is offline
PostPosted: Mon Nov 19, 2007 11:26 am    Post subject: Large tire/big meats - Stock suspension Bus thread Reply with quote
OK,
I decided to edit the title of this thread. I know there is a thread on suspension, wheels & tires for lowered buses. Didn't see one for stock buses with large tires/ big meat buses. Here is what I want to put on mine:
Anyone know if these will fit on a 1958 split bus at stock height? I'd be running 15" crows feet rims.
I recall there was a single cab on the west coast who had a tire that looked like this.
Here are the specs:
Firestone - 700-15 FIRESTONE MILITARY NDCC
SKU 587117
Construction: 6 ply nylon
Load Capacity: 1720 @ 50 psi
Tube Type: Requires Tube
Overall Diameter: 29.50
Cross Section: 7.80
Max Inflation: 50
Price: $86.00
Call your Cunado's:
https://vimeo.com/67661950
Touch Nicks Thing
Touch Nicks Thing is offline
PostPosted: Mon Nov 19, 2007 12:08 pm    Post subject: Reply with quote
I doubt it.
Sweet Rides
Sweet Rides is offline
PostPosted: Mon Nov 19, 2007 12:26 pm    Post subject: Reply with quote
I have some 670R15 6ply bridgestones on my bus and they fit, just! Wink Laughing
mpribanic
PostPosted: Mon Nov 19, 2007 12:42 pm    Post subject: Reply with quote
pic?
Call your Cunado's:
thom
thom is offline
PostPosted: Mon Nov 19, 2007 12:53 pm    Post subject: Reply with quote
I think they'd be too tall, or close to it. A 205/70 is roughly 25 1/2" tall - these are 4" taller than tat!
-Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type
ezcamper
ezcamper is offline
PostPosted: Mon Nov 19, 2007 1:00 pm    Post subject: Reply with quote
tubes........ I don't know about that.
BUCIOBATISTI
BUCIOBATISTI is offline
PostPosted: Mon Nov 19, 2007 1:25 pm    Post subject: Re: Firestone - 700-15 FIRESTONE MILITARY NDCC Reply with quote
Here are the specs:
SKU 587117
Cross Section: 7.80
Max Inflation: 50
Price: $86.00
I got something vaguely similar to that for the back of my 1960 Kombi years ago, I believe that the size was the same, and I didn't have to even mount them to see that they wouldn't fit. They would have rubbed in at least one way from what I recall. I *really* would have loved to stuff some nasty looking nobby bias plies up in there but I wasn't able to find something stylish, vintage, and the right size to do it.
Please check us out on Instagram at @holygrailgarage
That's the best place to see the latest things we are up to as well as catch an occasional sneak peek of our latest car and parts listings!
eddiemoney
East Coast Scavenger
eddiemoney is offline
PostPosted: Mon Nov 19, 2007 2:22 pm    Post subject: Reply with quote
in the other thread on colby's bus some one said that 30 inch tires can fit under a bus. but that might be only if it is a raised beam or running raised spindles.
Will
instagram im_eating_pizza
WhitewallsJohnson
WhitewallsJohnson is offline
PostPosted: Mon Nov 19, 2007 2:23 pm    Post subject: Reply with quote
They look tuff MP but i bet theyd never fit without lifting.
My 225-70-14 A/Ts work out to about 26.5 inches over all diameter and 8.8 inches wide. Ive got about 1.5 inches at the closest point at the rear of the dog legs. Your NDCCs are 29.5 inches overall diameter which means Zero clearance.
But then again, the NDCCs are a little narrower, as is the 15 inch rim. Maybe it could tuck inside the dogleg, but i wouldnt bet on it.
Maybe buy one and try it out? Ive done that in the past.
Show your love for the Land of Kong:
http://www.thesamba.com/vw/forum/viewtopic.php?t=254661&highlight=
Kermit, the highroof westy:
http://www.thesamba.com/vw/forum/viewtopic.php?t=318687&highlight=
j.pickens
j.pickens is offline
PostPosted: Mon Nov 19, 2007 2:27 pm    Post subject: Reply with quote
Its too bad, but it appears that most of the serious heavy duty tires which will fit are only available in 14" rim sizes. I looked them up on various websites and was able to find over 15 tires in a 14" which are LT or better rated, or offroad, with diameters of 28 inches or less. The 15" tires are very limited.
BeaterBarndoor wrote:
Red Fau Veh wrote:
mpribanic
PostPosted: Mon Nov 19, 2007 2:30 pm    Post subject: Reply with quote
John,
How tall are the Firestone bias-ply's that are on the SS Kombi?
Call your Cunado's:
derRHDmeister
derRHDmeister is offline
PostPosted: Mon Nov 19, 2007 2:35 pm    Post subject: Reply with quote
I did similar research and wanted to use exactly same military spec tires- but this wont work because its almost 30 inch diameter - WONT FIT.
My bus has 215/75r15 hercules terra tracs, 6 ply, very good and strong. (heard they dont make em any more) they run abt 27.1 inches tall. Works perfectly and doesnt rub- a tight fit and have to deflate rear tires to mount em!
in '07 , went on shasta snow trip with these wheels and it ripped up the backroads w/out plms-
Ask not what your bus can do for you, but ask what you can do for your bus.
unclespanky wrote:
Piercy could dip those wheel cylinders between his cheek and gums and spit them out rebuilt.
Check us out on Instagram:
@DeafVolks
@BarndoorBuggy
derRHDmeister
PostPosted: Mon Nov 19, 2007 2:37 pm    Post subject: Reply with quote
this is for stock suspension set up. Im not sayin g 30" tires wont fit, im sure they will with modifications to suspension etc.
@DeafVolks
@BarndoorBuggy
SHSC
SHSC is offline
PostPosted: Mon Nov 19, 2007 2:45 pm    Post subject: Reply with quote
You could always narrow the beam and tub it!
DKB
faster
faster is offline
PostPosted: Mon Nov 19, 2007 2:46 pm    Post subject: Reply with quote
Did you sling the rabbit into the fence with those big tires Confused
[/quote]
mpribanic
PostPosted: Mon Nov 19, 2007 2:58 pm    Post subject: Reply with quote
[/quote]
I think that is Wiley Coyote...(sp)
Call your Cunado's:
60freak
60freak is offline
PostPosted: Mon Nov 19, 2007 3:04 pm    Post subject: Reply with quote
ohh yes, good ol dead coyote road, miles and miles of dead coyotes, everytime I show these pics to someone they freak out.....man what a fun trip though and that road was way cool. Cool
VWsArent4Hippies
VWsArent4Hippies is offline
PostPosted: Mon Nov 19, 2007 3:14 pm    Post subject: Reply with quote
Yea, there's no way a 30 inch tire could fit under a stock height bus. The tires on my bus are 30 inches tall, and they caught the doglegs even with the turned beam. For the back however, I think they would work
aeromech wrote:
in my opinion you don't know shit
mpribanic
PostPosted: Mon Nov 19, 2007 3:19 pm    Post subject: Reply with quote
I found this in the thread about Colby's Standard...Here's an edited quote per Big Bus Mike
"That being said, You can run up to a 30" tall tire in the rear w/o modification and no body clearance issues. "...
Anybody else run 30" tall tires in the rear?
How tall a tire can you fit in the front suspension?
I'd like to hear what people with stock buses are running for large meats.
Size and brand's please
Thanks,
Mark
Call your Cunado's:
mpribanic
PostPosted: Mon Nov 19, 2007 3:23 pm    Post subject: Reply with quote
Touch Nicks Thing wrote:
I doubt it.
Nick,
What are you running on the Veta Crete panel?
Size?
Brand?
Call your Cunado's:
Page 1 of 105
