transaxle oil
porterville
porterville is offline
PostPosted: Wed Nov 14, 2007 3:50 pm    Post subject: transaxle oil Reply with quote
what kind of transaxle oil should i use
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed Nov 14, 2007 3:53 pm    Post subject: Reply with quote
This has been beaten to death so do a search and you'll find more that you care to read.
I use Swepco 201 80W-90. You'll read all about GL4 vs GL5... I use GL5 and have for years. Valvoline is also a good brand and available at all auto parts stores.
<<moderator's note>> this is on a short leash, so stay on topic.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
vwracerdave
vwracerdave is offline
PostPosted: Wed Nov 14, 2007 5:18 pm    Post subject: Reply with quote
For a stock to mild performance car use any national brand of 85W90.
73BuzzBomb
73BuzzBomb is offline
PostPosted: Wed Nov 14, 2007 9:58 pm    Post subject: Reply with quote
as recommended by my tranny builder, I run Heavy Duty 80/90 plus half qt. Lucas trans additive.
'73 Super
2270 type IV
nikita
nikita is offline
PostPosted: Thu Nov 15, 2007 1:19 pm    Post subject: Reply with quote
If newly rebuilt, I'd go with Redline MT-90. If not, because seals may not be perfect enough for synthetic, CRC Sta-Lube 80W-90 GL-4 from NAPA.
A valid second "universal" choice is any name-brand 80W-90. For Example, Castrol Hypoy is only about $5 a quart at PepBoys. Synchromesh fluids, such as those from Pennzoil and Royal Purple are too thin to protect the ring and pinion. They are meant for modern FWD transaxles.
Zundfolge1432
Zundfolge1432 is offline
PostPosted: Thu Nov 15, 2007 1:29 pm    Post subject: Reply with quote
God I love this Glenn Very Happy
Bruce
Bruce is offline
PostPosted: Fri Nov 16, 2007 2:04 am    Post subject: Reply with quote
It doesn't matter which end of the car a transaxle is, the oil is no different.
nikita
nikita is offline
PostPosted: Fri Nov 16, 2007 11:24 am    Post subject: Reply with quote
It matters if the engine is transverse mounted instead of longitudinal and the final drive gears are helical instead of spiral bevel.
porterville
PostPosted: Fri Nov 16, 2007 7:44 pm    Post subject: Reply with quote
6 to 7 pints of transmission fluid is the correct ammount of transmission fluid....right?
2002sportside
2002sportside is offline
PostPosted: Fri Nov 16, 2007 7:59 pm    Post subject: Reply with quote
Bentley says 5.3 US pints... (less than 3 quarts)
With the car level, fill it slowly until it's full. The fill is on the side so it will only take so much fluid, not much danger of overfilling.
1973 Volkswagen Beetle never ending project
70bugken
70bugken is offline
PostPosted: Thu Nov 29, 2007 9:08 am    Post subject: Reply with quote
Ok...I've been reading, and it's time to figure out how to change the trans fluid in my '70 Beetle. If I have it figured out right (more or less) I need to do the following, right?
0. Jack and block the car (keep it level?) and remove the wheel on the side with the filler hole (right? left?)
1. Remove the filler hole bolt (17mm allen wrench)
2. Put a pan under the gearbox and drain bolt
3. Remove the drain bolt (17mm allen wrench again)
4. Chill out for a while until it drains
5. Look at the old oil to see if there is any metal shavings or hunks in it (hopefully not!)
6. Replace the drain bolt
7. Refill the box with 5.3 US pints of Swepco 201 80W-90 GL5 (or one of the others mentioned above)
***How do I actually get it INTO the fill hole?!?***It seems kind of like a weird reach...Suggestions?
8. Stop filling when the fluid starts to spill out of the hole
9. Let it sit for another minute or two
10. Replace the filler hole bolt
I am at a loss as what to do next. Do i start it up, and run it through the gears? Can I drive it right away?
ScottK
ScottK is offline
PostPosted: Thu Nov 29, 2007 9:29 am    Post subject: Reply with quote
Go to your local FLAPS and get a quart fluid pump for about 4 bucks.
70bugken
70bugken is offline
PostPosted: Wed Dec 05, 2007 1:06 pm    Post subject: Reply with quote
[I bought one of those cheapy pumps from my FLAPS. One thing I'll probably do next time is use a spare hose clamp and clamp the hose onto the pump. Transaxle oil is super thick, and a few times the hose shot off the pump, and laid a couple nice puddles of oil on me/garage floor. It's a messy job to clean up.
Cusser
Cusser is offline
PostPosted: Wed Dec 05, 2007 5:28 pm    Post subject: Reply with quote
Yes, do that with the hose clamp, and I've attached a curved piece of copper tubing at the end that fits inside the fill hole so it won't slip out. I don't like when things slip out and make everything messy !
J-Gaz.
J-Gaz. is offline
PostPosted: Thu Dec 06, 2007 3:44 pm    Post subject: Reply with quote
Sergical tubing and duct tape is the cheep and nasty way to do it.
And I use 85-140 Royal Purple Synthetic (the good stuff)
go slow (no spills) and just fill it untill its level with the bottom of the filler hole. Then Drive!
johneliot
johneliot is offline
PostPosted: Thu Dec 06, 2007 7:55 pm    Post subject: Reply with quote
Not only is it messy, but that stuff stinks.
John
John
There is no distinctly American criminal class - except Congress.
Mark Twain
69 bug - "The Grey Ghost"
