ukdj Samba Member
Joined: September 06, 2004 Posts: 389 Location: easley sc
Posted: Thu Nov 29, 2007 9:15 pm Post subject: Deluxe bumper trim |
Do you think they used a special tool to put that rubber in Do you think it was cut by machine or by hand? _________________ driving down the road of life at 60 mph |
derv Samba Member
Joined: October 12, 2005 Posts: 2601 Location: Oak Park (Chicago), IL
Posted: Thu Nov 29, 2007 9:20 pm Post subject: Re: deluxe bumper trim. |
| ukdj wrote: |
| Do you think they used a special tool to put that rubber in Do you think it was cut by machine or by hand? |
Hey Craig -
I was flipping through my bentley yesterday and saw that there was a special tool used to insert the rubber into the trim.
I am sure it can be done using something else. _________________ Jack
| Quote: |
| Mr. Hido: To post your bare ass to virtually all hardened bus enthusiasts casts thick, a slag not easily ground smooth. |
Andrew Samba Member
Joined: October 27, 2000 Posts: 5865 Location: Who in the what now?
Posted: Thu Nov 29, 2007 11:28 pm Post subject: Re: deluxe bumper trim. |
| derv wrote: |
| ukdj wrote: |
| Do you think they used a special tool to put that rubber in Do youthink it was cut by machine or by hand? |
Hey Craig -
I am sure it can be done using something else. |
We did mine using a flat head screw driver. Just be careful not to slip and stab the bus.  _________________ -Andrew |
Scotts 63 23 Samba Member
Joined: March 09, 2002 Posts: 1280 Location: Somewhere in my mind... The Real er Laguna Beach :)
Posted: Fri Nov 30, 2007 10:19 am Post subject: |
I used a flat burnishing tool made of bone to push the rubber into the slot.
I cut the rough shape of the rubber with a knife/utility blade, then sanded it down, eventually wet sanding the rubber and then waxing it when finished. Turned out perfect! _________________ '63 23 Daily Driver
www.scottmooreart.com |
Riff Raff Shivering Sambian
Joined: October 25, 2004 Posts: 3097 Location: Alberta
Posted: Fri Nov 30, 2007 11:33 am Post subject: |
Yeah, that rubber cuts/sands/buffs surprisingly well.
I used a large flat blade screwdriver on baby oil soaked pieces and installation went pretty easy. _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
ukdj Samba Member
Posted: Fri Nov 30, 2007 9:23 pm Post subject: |
i,ve put it in before i was just wondering if it was pre made by a machine or if they cut it or filed it by hand at the factory?All those years ago _________________ driving down the road of life at 60 mph |
Lind Samba Member
Joined: November 06, 2000 Posts: 10273 Location: idaho
Posted: Fri Nov 30, 2007 9:29 pm Post subject: |
| ukdj wrote: |
| i,ve put it in before i was just wondering if it was pre made by a machine or if they cut it or filed it by hand at the factory?All those years ago |
I have had NOS trim inserts, and they were cut and sanded smooth. they were not formed ends. _________________ .
Wanted:
twinwindows Samba Pimp
Joined: December 08, 2000 Posts: 4086 Location: So.Cal. Highland Park GFK!
Posted: Fri Nov 30, 2007 10:09 pm Post subject: |
| Lind wrote: |
| ukdj wrote: |
I have had NOS trim inserts, and they were cut and sanded smooth. they were not formed ends. |
Hmm.. Thanks for the info _________________ CRG
My builds
BAD TEMPER 11
CHRISTINE
GFK LIFER!
| myzamboni wrote: |
| Yeah, everyone's now doing it GFK style . . . everythinig is covert until the finished product is revealed. |
Stocknazi Samba Member
Posted: Sat Dec 01, 2007 7:58 am Post subject: Re: deluxe bumper trim. |
| derv wrote: |
| ukdj wrote: |
Hey Craig -
where in the bently manuel was the pic of the special tool you are refering to? is this in the 50-62 bently? _________________ WANTED:
Thomas Jefferson |
Empicollector Samba Member
Joined: March 02, 2002 Posts: 316 Location: Seattle, WA
Posted: Sat Dec 01, 2007 9:39 am Post subject: |
| I use a wooden kitchen spoon--works good and no damage----and warm the rubber first |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71937 Location: Phoenix 602
Posted: Thu Dec 11, 2008 9:14 pm Post subject: Re: deluxe bumper trim. |
| StockNazi wrote: |
| derv wrote: |
| ukdj wrote: |
where in the bently manuel was the pic of the special tool you are refering to? is this in the 50-62 bently? |
In the body section
_________________ How to Post Photos
Posted: Thu Dec 11, 2008 9:15 pm Post subject: |
| Lind wrote: |
| ukdj wrote: |
Yes, my original inserts from my '64 are clearly hand shaped. They are not even perfectly smooth, although the shaping is pretty even. I'm wondering if they cut them with a hot knife.
My technique:
1. Cut strip from roll. If using original pieces as a pattern, make sure they haven't shrunk when you cut the overall length.
2. Cut rough shape with a box knife or razor blade.
3. Carefully shape with bench grinder
4. Hand sand/shape with 60 grit on block and free hand
5. Smooth out minor scratches and final shaping with 150 grit
6. Wet sand with 600 grit
7. Wet sand with 2000 grit
8. Buff with some paint polish
9. Install
A wooden kitchen spoon works great to push the insert into the trim, although I prefer to push from the bottom. Use the handle end, not the spoon end. The spoon end will break if it's too thin.
Do the fronts first so if you screw up, you can cut it down and make a rear. _________________ How to Post Photos
Split 1 Samba Member
Joined: May 03, 2005 Posts: 764 Location: Adelaide. South australia
Posted: Sun Dec 14, 2008 4:32 am Post subject: |
Can you buy repro inserts, or what are people using.
Thanks
Dave |
IN2RUST Samba Member
Joined: October 30, 2005 Posts: 1942 Location: West Coast
Posted: Sun Dec 14, 2008 8:34 am Post subject: |
Yes, wolfsburg west sells repop insert. Fairly inexpensive _________________ RUSTFARMER....I like anything old and rusty! |
Rich Hanson Samba Member
Joined: February 10, 2004 Posts: 61 Location: Becker, MN
Posted: Sun May 10, 2009 6:54 am Post subject: Installing rubber insert |
I just finished installing the rubber insert on the bumper trim I bought from Westling Machine. Instead of using a grinder to shape the rubber, I used a 4-way wood rasp (available at most hardware stores) to work the rubber (Wolfsburg West). In just minutes, I had the shape I needed and kept the mess to a minimum. I used the finer "teeth" on the rasp to clean it up, then used Everett's suggestion on sanding and finishing.
I used a wood block with a taper on one end to push and roll the upper bead of the rubber into the trim. Worked good! _________________ Ragtop Rich
61 Ragtop Bug
60 Bug
57 23-Window Bus
57 oval window
83 1/2 Westy |
Posted: Fri Jun 12, 2009 5:14 am Post subject: |
I bought the insert from WW but its for the US spec ones and I can only get 3 of the Euro ones out of a length, so now I have to order another length, 8 foot for just one insert??
I also found it easier to get in if you let is soften in boiling water for a few minutes first.
Dave |
Damon22 Samba Member
Joined: January 03, 2006 Posts: 238 Location: New Forest, Ingerland.
Posted: Fri Jun 12, 2009 7:27 am Post subject: |
I bought the inserts in 4 strips from Creative Engineering, I mentioned that I have a Wolfsburg bus and therefore the front inserts are longer and Mandy told me their trims come in lengths to compensate for that, 2 short 2 long.
I used a grinder to shape them, came out perfect. I was dreading geting them in, given the agro getting the old ones out, but it was a breeze.
Dunked the strips in a bucket of hot water for 10 minutes before fitting each one.
Following Everetts advice I used a liberal application of personal lubricant (unflavoured) and a wooden Spatchula.
Posted: Fri Jun 12, 2009 8:13 am Post subject: deluxe bumper trim |
I had e-mailed W/W with the suggestion that they offer the inserts in both 8' & 10' rolls, so that those with pressed bumpers can get all 4 pieces from one 10' roll. If enough people e-mailed that to them, hopefully they'd be responsive enough to customers to accommodate that request. Even if they charged a little bit more proportionate to the length, it'd still be better than having to order an additional piece for just one 30" strip of insert. _________________ Ragtop Rich
61 Ragtop Bug
60 Bug
57 23-Window Bus
57 oval window
83 1/2 Westy |
hitest Samba Member
Joined: September 30, 2008 Posts: 10327 Location: Prime Meridian, ID
Posted: Fri Jun 12, 2009 4:39 pm Post subject: |
If WW just offered the 10 foot lengths- I'd still buy it. I'd use the extra couple feet as a tire stop so my wife will stop running her car into the water softener! _________________
| EverettB wrote: |
FU#5 |
