70bugken Samba Member
Joined: November 20, 2007 Posts: 154 Location: Riverside, Illinois
Posted: Thu Dec 06, 2007 1:34 pm Post subject: 70 Radio block-off panel |
I've been hunting high and low for a radio block-off panel for a '70. For some reason, nobody has one. The only ones available are from '58 to '67. Fill in the blank space:
(I have the original steering wheel, too...i just need to get around to putting it on. Pay no attention to the trash on the floor..it's a work in progress )
MAM: '58 - '67 only http://www.mamotorworks.com/acvw?frame=1.3091
Wofsburg West: '58 - '67 only http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111857233AA
BFY: The catalog shows everything BUT the radio block off panel:
Does anyone have a template or anything so's I could MAKE one?!? |
Calisupastarz Samba Member
Joined: January 25, 2005 Posts: 610 Location: Sylmar, California
Posted: Thu Dec 06, 2007 2:28 pm Post subject: |
The reason why you don't see a block-off plate for a '70 is because the part that blocks off the radio area would be contained within the dash pad. In other words, if you want to block off the radio on a '70 the way that they would have at the factory, then you would replace the dash pad with a new one and leave the area for the radio uncut.
If you plan on rolling without the dash pad then I would just cut a piece of sheetmetal to fit that area, weld it in and you're done. _________________ 69 Beetle Autostick DD
"At first glance, you will notice the lack of a clutch pedal. Driving with the Automatic StickShift is simpler and shifting is easier." |
johneliot Samba Member
Joined: August 29, 2005 Posts: 2195 Location: Chico, CA
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80520 Location: Sneaking up behind you
Posted: Thu Dec 06, 2007 2:46 pm Post subject: |
That is actually for a Bay Window Bus. But if you add a open bezel from a late model Beetle you get...
_________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
DrDarby Samba Member
Joined: May 12, 2004 Posts: 6544 Location: Northern Illinois
Posted: Thu Dec 06, 2007 2:54 pm Post subject: |
Let me add that this info is correct, 68+ beetles were shipped without radios and the dash pad was non cut so the radio block off was built right in.
Glenn's bay window bus radio block off + Beetle surround is the only thing to do and a very stock looking fix.
And may I add that Glenn, you continue to amaze me with the pictures you come up with of every imaginable thing ! _________________ Midwest Autosavers, Inc. Crystal Lake, IL |
Glenn  Mr. 010
Posted: Thu Dec 06, 2007 3:01 pm Post subject: |
| DrDarby wrote: |
| And may I add that Glenn, you continue to amaze me with the pictures you come up with of every imaginable thing ! |
Top is NOS 71-72
Middle is aftermarket 73-74,76-77
Bottom is used OEM 75 with the radio hole cut.
Member #1009
#BlueSquare
Posted: Thu Dec 06, 2007 3:10 pm Post subject: |
When I decided I didn't want to cut my dash or use the glove box, I used that block off plate and trim to do this:
Stereo is mounted in the trunk, I got radio and ipod inside.
John _________________ John
There is no distinctly American criminal class - except Congress.
Mark Twain
69 bug - "The Grey Ghost" |
J-Gaz. Samba Member
Joined: November 19, 2007 Posts: 757 Location: 253 Then, Now 206.
Posted: Thu Dec 06, 2007 4:20 pm Post subject: |
JohnEliot-
is that just velcrowed or 3m taped to the block off Plate? is it a wireless remote for your stereo? I am not up on new stereo's, as i dont have a radio in any of my cars. |
Posted: Thu Dec 06, 2007 7:53 pm Post subject: |
That is a marine unit. It is a wired remote. Normally it is what you would use when you are in the water and it is attached around the swim platform. I like it because the head unit is made to withstand moisture. My trunk is sealed well, but it's nice to eliminate one variable. It is held in back by a piece of "C" channel. Two holes are drilled through the channel and long bolts are threaded through to the back of the unit. As you tighten the bolts it sucks the remote unit tight.
Mark Twain
Cusser Samba Member
Joined: October 02, 2006 Posts: 33489 Location: Hot Arizona
Posted: Fri Dec 07, 2007 5:10 am Post subject: |
Did you paint your own grill and glove box? My '70 has a black grill and glove box, while earlier ones were same color as the VW, just wondering. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Fri Dec 07, 2007 7:40 am Post subject: |
Yes, I painted them. I preferred black to the gray that I painted the body. I used a satin finish and it came out real nice.
Mark Twain
