Posted: Sat Feb 01, 2003 5:05 pm Post subject: Underseal/sound deadener question |
Due to recieve my 67 standard back from the paint shop soon.
Before painting the bus I stripped it back to a bodyshell and pan and sandblasted the entire underbody ,welded where required , and then painted it all with grey POR.
The blasting removing all traces of underseal etc and exposed areas I would have missed otherwise.
The POR has left a great finish but now I am concerned that noise will be an issue and cannot decide what the best stuff is too use .
My bodyman has suggested some spray on stone chip style product?
Is POR really as durable and stone chip proof as the ads say and if so is it best to take care of soundeadening on the inside of the bus instead.
Appreciate all feedback on this. |
Posted: Mon Feb 03, 2003 10:46 am Post subject: Underseal/sound deadener question |
I did the same on my bug. Por15 all around under the wheel wells. I think it is. If anything get some sound deadener from like CIP1 they have this stuff that has a metal like background and seems to keep alot of sound. I think it will work well. I would go spraying everything with some rubber crap that might leave moisture behind it. I think POR 15 does its job Just insulate the inside and see what happens. It took me days to get all that old rubber off my car
Mark
Good luck |
75 Super Beetle Samba Member
Posted: Tue Feb 04, 2003 11:46 am Post subject: Underseal/sound deadener question |
Does Por15 come in a spray can? and is it good for painting the bottom of the car?
David ù JHC |
Posted: Tue Feb 04, 2003 4:37 pm Post subject: Underseal/sound deadener question |
Not as far as I know although you can thin it with POR thinner and then use a spraygun.
I hand painted the complete underbody after blasting - laying on my back with POR runing down my arms..........its true it DOES NOT come off like regular paint - took weeks to "wear" off my skin - use gloves!
The POR when painted on self levels and leaves a super smooth finish - you must prep the area first ensuring it is oil/grease free .Is it good I'm still not sure - my bus is still in parts and yet to be driven.
All reports are good though ,but I'm still not sure whether additional underbody coatings are advisable for sound deadening and stone chip properties.
Good Luck.... |
dougefresh Samba Member
Joined: June 22, 2002 Posts: 75 Location: Lakeland, FL.
Posted: Sat Feb 08, 2003 7:25 pm Post subject: Underseal/sound deadener question |
As for sound control, I bought some 'generic dynomat' from
http://www.mcmaster.com/
They are a huge industrial supply house in Atlanta. When you get to their home page, put this part # (9709T19) in their search function. Here is the item description.
Polymeric Mastic 0.070" 32" x 54" 0.10 -30¦ to +300¦F 0.7 Black 9709T19 14.62
They are fantastic about shipping. I had my stuff the next afternoon after I ordered from their web site. And no I dont work there.
My plan is to use contact cement to glue a layer of roofing tar paper to one layer of this stuff. This will make a sandwich to replace the tar boards on the bottom of a 70 Beetle. Not quite there yet as we are still stripping paint.
Later
Doug |
Scooter Samba Member
Joined: December 18, 2002 Posts: 201 Location: California
Posted: Tue Feb 11, 2003 10:09 pm Post subject: Underseal/sound deadener question |
| Also you can try B-Quiet |
ets80 Samba Member
Posted: Sun Dec 30, 2012 7:17 pm Post subject: Re: Underseal/sound deadener question |
| dougefresh wrote: |
Later
Doug |
Make sure you prime the area before you glue the tar paper. Actually an EPDM roofing is a better choice and it comes with its own glue that will adhere to anything |
Joined: January 01, 2007 Posts: 17907 Location: sticksville, ct.
Posted: Sun Dec 30, 2012 8:04 pm Post subject: |
wow, a 10 year old thread, congrats newbie  _________________
| gprudenciop wrote: |
| Jake Raby wrote: |
| Thanks for the correction. I used to be a nice guy, then I ruined it by exposing myself to the public. |
| Brian wrote: |
| Also the fact that people are agreeing with Skills, it's a turn of events for samba history |
j.goodspeed Samba Member
Posted: Tue Jan 01, 2013 9:37 pm Post subject: |
Often I use Wurth sound deadening panels. They are a heavy duty bitumen based material with a polypropylen covering. Wurth sound deadening panels reduce noise within the car that are due to resonating body panels such as floors, doors etc. Panels are adhesive backed for easy installation. For roof areas, I generally cut the panels into 5 or 6 inch squares and apply using the pre-installed adhesive. A rubber roller makes installation a snap. These panels also easily heated and mold to shape without wrinkles or other distortion. This material is superior to Dynamat and others. It is also very thin, so it does not affect areas with tight tolerances. Most important, no petroleum smells in hot weather.
http://www.goodspeedmotoring.com/auto-car-sound-pr...00060.html
robierobot Samba Member
