PTFE Additive?
Beaboy
Beaboy is offline
PostPosted: Sun Dec 30, 2007 9:10 am    Post subject: PTFE Additive? Reply with quote
I've used a PTFE additive in all my cars and trucks every 50K miles since they were new (truck just clicked over 200K, wife's Mazda just turned 145K, daughter's pickup is currently at 93K) with absolutely no primary engine work ever required and still getting the same fuel mileage as when I bought them.
My question - Has anyone used a PTFE additive (i.e. Slick 50) in their type 1? I've finished my restore and as of this Wednesday, it will be my daily driver, so I'm wondering if I can continue using this product or similar in a bug.
Thoughts?
'69 Standard Beetle
Beaboy
Beaboy is offline
PostPosted: Sun Dec 30, 2007 9:13 am    Post subject: Reply with quote
Oops. Probably should mention that it's a '69 type 1 w/ a 1970 1600 single port engine, mostly stock.
'69 Standard Beetle
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Dec 30, 2007 9:20 am    Post subject: Reply with quote
Have to done any reading on what happens when the PTFE comes out of suspension?
http://www.msgroup.org/tip.aspx?num=043
http://www.thegsresources.com/garage/gs_additive.htm
http://www.ftc.gov/opa/1997/07/slick.shtm
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Beaboy
Beaboy is offline
PostPosted: Sun Dec 30, 2007 9:35 am    Post subject: Reply with quote
Interesting reads, Glenn. Guess my engines are the only ones that work well with the stuff. That said, I'll run my '69 without it.
Thanks.
'69 Standard Beetle
propflux01
propflux01 is offline
PostPosted: Sun Dec 30, 2007 9:46 am    Post subject: Reply with quote
Snake oil
A 55-gallon Drum and a Shovel Can Solve Many Problems.....
vwracerdave
vwracerdave is offline
PostPosted: Sun Dec 30, 2007 12:58 pm    Post subject: Reply with quote
I read a 10 year study by a major university engineering Dept on oil additives. There final result was that they could not prove they did any good.
Bruce
Bruce is offline
PostPosted: Sun Dec 30, 2007 2:02 pm    Post subject: Reply with quote
Polytetraflouroethelyene, aka Teflon. Dupont is the trademark holder of Teflon, and the supplier to Slick 50. Dupont says teflon in an engine oil suppliment does not work. That should tell you something.
A few years ago, Dupont decided to stop the fraud by Slick 50, by cutting off supplies to them. Slick 50 took Dupont to court, and some ignorant judge sided with them, forcing Dupont to continue to supply Slick 50 with teflon.
fonz15
fonz15 is offline
PostPosted: Sun Dec 30, 2007 3:45 pm    Post subject: Reply with quote
not to steal the thread but i have a question about LUCAS oil additives, are those any good, anyone use them?? is it a ptfe additive?
grimace007
grimace007 is offline
PostPosted: Sun Dec 30, 2007 4:54 pm    Post subject: Reply with quote
do NOT use lucas in any motor you want to keep
i used a little less than a half qt. in my old 69.
within 100miles my motor locked up.
from what i understand lucas froths up and decreases the oiling to bearings which would explain why my #3 rod bearing got welded to the crank
Brian
68 sedan
Dallas Air Coolers
perrib wrote:
Hey It is The Samba where well thought out rational answers can take a while and getting side tracked is normal. I was just lucky this time. Smile
cr@M wrote:
No one has any personal responsibility these days. This country is sue happy. Intelligence is no longer a requirement, just an accessory.
