ID a vacum part in vacum curcuit, No bentley right now
tclark
tclark is offline
PostPosted: Fri Feb 22, 2008 6:04 am    Post subject: ID a vacum part in vacum curcuit, No bentley right now Reply with quote
85, 1.9
was trying to trace down this odd hesitation when i go WOT at 1 point i pulled the electrical connector off this white vacum valve ?? in the top right corner of the rear firewall, well that cured this hestiation...
Well it looks like this valve is leaking or failing some how since when i put the vacum guage on the engine vacum is about 5 lbs lower with the electrical connection on ..
anyone have the part # it really does not seem to make any different to engine running what is it actually supposed to do ?
mightyart
mightyart is offline
PostPosted: Fri Feb 22, 2008 6:13 am    Post subject: Reply with quote
Does it look like this?
tclark
tclark is offline
PostPosted: Fri Feb 22, 2008 6:16 am    Post subject: Reply with quote
no that is the idle stableizer this white cerramic looking thing is on the opposite side
its got 3 or 4 wire electrical connector(sorry inside right now) & its on the rear firewall not the side
Captain Pike
Captain Pike is offline
PostPosted: Fri Feb 22, 2008 6:24 am    Post subject: Reply with quote
Power steering vacc assist___or do you have AC.
LEARN TO SELF RESCUE
....Bad Sneakers....
bucko
bucko is offline
PostPosted: Fri Feb 22, 2008 6:57 am    Post subject: Reply with quote
You can live without the device that adjusts the idle for the power steering. There can be 2 of these mounted on the left: one for the power steering, and one for the Air Condition.
I have power steering, and a previous owner removed the device on the left side of the engine bay that is supposed to increase the idle when the steering is turned sharp left or right. My 84 1.9 does not stall when I do this.
However, my Air conditioner is currenty disabled (belt is removed from the AC compressor, so I cannot vouch for this.
Current VW drives: 1984 Westfalia
Past VW drives: 1967 Beetle, 1973 Beetle, 1977 Bus, 1971 Military Type 181
tencentlife
tencentlife is offline
PostPosted: Fri Feb 22, 2008 9:54 am    Post subject: Reply with quote
Those idle boost solenoid valves are very hard to find.
tclark
tclark is offline
PostPosted: Fri Feb 22, 2008 10:29 am    Post subject: Reply with quote
ah interesting yah my van will now stall if I am in parking lot trying to execute some real tight left to right turning maneuvers
but the vacuum is no longer reading 11 it up to 16
and i don't have the weird hesitation when i go wot
do we have an orientation issue you say left side
do you mean the driver side ???
OK i just went to van
I mean mine is on the right rear firewall passenger side
its a white ceramic unit with 2 vacuum lines attached and a 2 wire connector (not 3/4 i said earlier)
going to the black box (with the 2 relay)
that is on the left rear firewall driver side
here are pics
http://members.shaw.ca/trclark/images/P2220395.JPG
http://members.shaw.ca/trclark/images/P2220396.JPG
Captain Pike
PostPosted: Fri Feb 22, 2008 11:41 am    Post subject: Reply with quote
That's the booster fer sure. You may cave a cracked vacc line somewhere in the loop or the valve has failed (will not open). Ohm test it for an open circut.
bucko
bucko is offline
PostPosted: Fri Feb 22, 2008 11:44 am    Post subject: Reply with quote
I was refering to turning the steering wheel all the way to the left or right, which I believe puts the power steering pump at it's greatest pump pressure output.
I cannot say for sure if a mechanic from previous ownership compensated for the removal of this idle adjuster circuit by turning the air screw on my 84.
I can say for certainty that my 1.9 idles smooth, with it's power steering pump operational, and without the valve you are talking about.
If you need one, I may have 1 or 2 of these in a box.
