mr. warehouse Samba Member
Joined: February 27, 2001 Posts: 5002 Location: Nor Cal 707
Posted: Tue Dec 04, 2007 7:06 pm Post subject: |
Wouldn't really matter where the slot goes. All that affects is where your wheel sits when it's "locked"
With that being said, mine are all just about in line with the key. |
DaveB Samba Member
Joined: June 03, 2002 Posts: 489 Location: Raeford, NC
Posted: Tue Dec 04, 2007 7:17 pm Post subject: |
Thanks Greg
I've got a steering box with no pay that is being shortened 1.5 inches. So I didn't want to pull mine to see what is the "back" of the shaft.
Don't have a lock yet, going to look for one of the Brazilian units. _________________ Dave Brooks
USAF Retired
1966 Custom Camper |
Posted: Tue Dec 04, 2007 7:23 pm Post subject: |
| DaveB wrote: |
Thanks Greg
Don't have a lock yet, going to look for one of the Brazilian units. |
Cut the outer column at the bottom so you can hid it under the floor, and cut the main column at the top so you can gusset it with the locker. |
zimblewinder Samba Member
Joined: January 22, 2004 Posts: 900 Location: Australia
Posted: Wed Dec 05, 2007 4:59 am Post subject: |
Hey Greg, Thats my bus in the first photo. Sorry I was late to chime in, only just read this. The shells dont have any number stampings that I could find. They were pretty basic and only brazed on fairly loosly. The Tech bulletin describes it fairly well. You could easily make a set of the shells as you only need the i.d. and the slot gap required front and back for the bolt to drop home into. Ley me know if you need any more info. The bolt isnt that tight, with a little play/rotation in the slot but no one will be driving off in it.
By the way. Anyone have a source for the sheer bolts?
Cheers
dale _________________ 58Euro 23 343208 The Ultimate Zimblewinder Machine.
59 mango standard
Wanted- splash pan supports, og pressed bumper coach bolts, ivory blaupunkt knobs (early), armrest alloy strips, NOS door mechanism |
ebuscopaulian Samba Member
Joined: October 05, 2007 Posts: 25 Location: western slope, CO
Posted: Thu Dec 06, 2007 10:12 am Post subject: steering column locks |
| greg, paul in slc! hey sent $ yesterday for the hinges-could i get the upper section as well? hey i sent that og paint velvet gn/white 65 hardtop westy to my friend in the portland area (the one clara liked in my carport in slick city...)anyway it has a factory steering lock that appears to be completely unmolested-his name is craig and his # is 503-550-6278...p |
campingbox  Samba Member
Joined: November 14, 2000 Posts: 10267 Location: Petaluma, CA
Posted: Thu Feb 21, 2008 11:22 am Post subject: |
| zimblewinder wrote: |
Cheers
dale |
Hey Dale-
Which bolt isn't that tight? The small one on the side ot the shear bolt?
I'm getting ready to dive into my steering lock project today. Here are the shells I made;
My friend has access to a screw machine, I'll look into getting some shear bolts made. |
Posted: Thu Feb 21, 2008 11:24 am Post subject: Re: steering column locks |
| ebuscopaulian wrote: |
Hey Paul, I didn't see this until now. Next time drop me a PM or an email. |
Posted: Thu Feb 21, 2008 6:54 pm Post subject: |
Hi Those shells look the part. Good work. The tolerance of the bolt in the gap isnt that good. Maybe 1-1.5mm play left/right once its locked.
Keep in touch about the sheer bolts.
Thanks
59 mango standard
Posted: Thu Feb 21, 2008 7:03 pm Post subject: |
Thanks
dale |
Do you have your steering box apart?
What is the height of your shells?
Do you have a picture of what the welds look like to install them?
I just realized that my worm gear had a 20mm rod where the later worm gears are 19mm.
I'll have to make new shells to fit the '56 steering box.
Damn. |
Posted: Thu Feb 21, 2008 11:29 pm Post subject: |
OK did some measuring.
From the top of the steering shaft to the top of the hole in the column tube is 210mm
The slot is 20mm long
The top of the shaft is exposed 40mm (out of the column)
so for just the column tube
the top of the hole is 170mm down the column (ie. 210mm down the shaft from the very top.)
The shells are seam welded along the curved edge in a continuos weld top and bottom and run from above the column hole to below the column hole.
Hope that makes sense.
Cheers _________________ 58Euro 23 343208 The Ultimate Zimblewinder Machine.
59 mango standard
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15515 Location: Casa de Oro, California
Posted: Fri Feb 22, 2008 8:37 am Post subject: |
| I've found metric and SAE shear-bolts at better lock shops like Grah Safe and Lock by my house. Moss Motors in Goleta, California has some also. You might try them if you want to see what they're willing to part out. I've made some by "veeing" regular bolts but I was sorry afterwards when I wanted to take it off. |
Posted: Sat Feb 23, 2008 1:06 am Post subject: |
| If anyone knows the length of the locking shells on a '61 and older steering lock let me know. I estimated them at 2.75" long based on the drawing/measurements in the technical bullitin, but if anyone knows for certain let me know. I plan to weld the shells on tomorrow. I know, it will all get hidden inside the box but I'm O.C.D. and it will bother me knowing they aren't 100%. |
Posted: Sun Feb 24, 2008 11:14 pm Post subject: |
I finally finished the steering lock shells and welded them on. What a pain.
I took some steel pipe with a 20mm I.D. and cut it in half. Cut to length. The technical bullitin calls for the shells to have a .33" gap (+/- .020") on each side. Both shells need to be totally identical in size, have lines that are parralel to each other and parallel to themselves. I ended up using a grinder to get them close, and then did the finishwork with a file and some 60 grit sandpaper laid out on a piece of glass. Welding them to the column was a challenge as well. If you want the steering wheel to be perfectly centered when locked you need to get it dead nuts in line with the keyway in the column. I ended up using two angle finders to make sure the keyway was in line with the center of the slot, and that the second slot was exactly 180 degrees off of that.
BarryL  Samba Member
Posted: Mon Feb 25, 2008 8:38 am Post subject: |
| Man that is some nice work. Is the perfectly centered steering wheel a cosmetic thing or what?. My later style locking one only locks in a non centered position; rumor has it so a thief could only go in a circle. Of course, yours is easy cuz you'll always know where to turn it to to lock it straight or turned. |
Posted: Mon Feb 25, 2008 9:25 am Post subject: |
| BarryL wrote: |
The technical bullitin said to have it centered with the keyway, so no matter where you turn the tires it will lock with the steering wheel centered. The "shells" also give you twice as many places to lock it because there's a gap on each side of the steering shaft. |
dstefun Samba Member
Joined: February 20, 2002 Posts: 3338 Location: Sacratomato
Posted: Mon Feb 25, 2008 10:57 am Post subject: |
| Lookin' good, Greg! Always happy to see great craftmanship! |
Posted: Tue Feb 26, 2008 3:22 am Post subject: |
looks spot on Greg. Nice work.
So Greg when youve worked out the sheer bolts reqd would you get some for me? I can dig these out to measure them off too. I havent been able to find any here in Oz. _________________ 58Euro 23 343208 The Ultimate Zimblewinder Machine.
59 mango standard
Clara  Samba Member
Posted: Tue Feb 26, 2008 8:15 am Post subject: |
| BarryL wrote: |
I though the 62-67 steering lock collar is supposed to be oriented so that it locks when the steering is straight ahead, or one spin to each side.
You get 3 and a bit spins of the steering wheel from wheel lock to the left to wheel lock to the right, so there are three places where the steering lock tongue can hit the lock slot.
That is how it is on the 65 westy I had, and also Greg's 66 widebed truck. Those are the only split buses I've driven with steering locks, actually.
My 69 beetle also locks like that. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
BarryL  Samba Member
Posted: Wed Feb 27, 2008 11:16 am Post subject: |
| I reckon mine must be worn away or whatnot. It starts to drop in at about 2 degrees to the right and finishes at about 30 degrees. I don't like it when it is sprung loaded and I never release the lock without taking the tension off the steering wheel. It's a '65 also and the latest lock tongue is hardly worn. I'm guessing that a lot of abuse before me widened it? |
schnidlee Samba Member
Posted: Wed Mar 01, 2023 6:13 am Post subject: Re: '55-'60? steering lock question |
I thought I would put up a couple of pictures of how I did my locking collar.
I had shortened the steering column for a steering box raise and positioned my join about 30mm above where the slot in the collar needed to be.
A good friend helped me turn up the collar which is a press fit and has a larger OD than the original shells/collar but that should really just make it stronger.
the slot in the collar was lined up with the keyway and then TIG'd around the top and bottom as well as 4 big plug welds. Locking collar and gusset all in one.
