Vin Plate Restoration
Page: Previous  1, 2, 3  Next
Kafer Krazy
Kafer Krazy is offline
PostPosted: Wed May 03, 2006 8:10 pm    Post subject: Reply with quote
No car is titled, and clean, the Vin Plate has some surface rust, and it's hard to read the numbers. I am trying to save the plate.
Thanks
Gary
My57Oval
My57Oval is offline
PostPosted: Mon Jun 12, 2006 8:46 pm    Post subject: Reply with quote
Personally, I like to see a car that has not had the VIN plate removed. That way it's easy to see that the front clip has not been messed with, and you can see the original color when you DO take it it off. Wink
Russ
Russ is offline
PostPosted: Wed Mar 12, 2008 6:16 pm    Post subject: figured i would revive this Reply with quote
just had my vin tag lightly blasted then i sent it out for zinc plating.it turned out really well.
not sure if the made in germany tag is supposed to be like this or black but i went with zinc and i'm happy
Cruiser pedals for sale (see my ad's)
55 hardtop finally finished
65 beetle done:)
technik
technik is offline
PostPosted: Thu Mar 13, 2008 2:58 am    Post subject: Re: figured i would revive this Reply with quote
they came up nice.... originally are they both bare metal?
Russ
Russ is offline
PostPosted: Thu Mar 13, 2008 6:54 am    Post subject: Reply with quote
no they definatly had some type of plating on them from the factory
65 beetle done:)
denizen224
denizen224 is offline
PostPosted: Thu Mar 13, 2008 6:39 pm    Post subject: Reply with quote
Has anybody tried this guy's "ribets" for the VIN tag? Any good?
http://www.thesamba.com/vw/classifieds/detail.php?id=483999
My tag is in such bad shape I'm not sure I'd be able to clean it up in place. I'd like to refinish behind it as well, and remount it with the correct look. It'll be titled and registered on a replacement chassis, so I'm not that worried about the draconian Maryland MVA taking it away to the crusher if they don't like whatever "ribets" I use... Mad
Mr. Bill
'57 oval sedan
'59 Karmann Ghia coupe
'70 std. sedan
'74 Karmann Ghia cabriolet
Russ
Russ is offline
PostPosted: Thu Mar 13, 2008 7:07 pm    Post subject: Reply with quote
i bought little alluminum blind rivets.
i'll mount my plate this weekend and if you like it i'll send you the same rivets i used for free (think i have a couple extra)
65 beetle done:)
ericktheelectrician
ericktheelectrician is offline
PostPosted: Thu Mar 13, 2008 7:33 pm    Post subject: Reply with quote
I used the ones in the ad for $16.00 a set and they worked great
Trevor P
Trevor P is offline
PostPosted: Fri Mar 14, 2008 5:22 pm    Post subject: Reply with quote
Here is mine before and after I soaked it in lemon juice for a day. I'm also gonna get mine plated like you did Russ. BTW all the "Made in Germany" tags I've seen have been silver like yours.
53 SG Barndoor SC
53 Canadian standard oval
56 Wolfsburg PG/SG
57 Oval, 2332 & Berg 5
70 911T
91 Westy
KantDriveFast
KantDriveFast is offline
PostPosted: Fri Mar 14, 2008 5:42 pm    Post subject: Reply with quote
So is bead-blasting is bad or ok?
Guess it depends on the blaster huh? Cool
Russ
Russ is offline
PostPosted: Sun Mar 16, 2008 5:54 pm    Post subject: Reply with quote
here it is mounted in the car. turned out pretty good i think
65 beetle done:)
dirtydeedss
dirtydeedss is offline
PostPosted: Sun Mar 16, 2008 5:57 pm    Post subject: Reply with quote
so russ, When are we going to be able to see your car? Tony says its looking pretty Sweet
View user's profile Send private message MSN Messenger Classifieds Feedback
Russ
Russ is offline
PostPosted: Sun Mar 16, 2008 6:08 pm    Post subject: Reply with quote
the classic if all goes well Wink
i want to finish it before i start posting a ton of pics of it.
65 beetle done:)
David
David is offline
PostPosted: Sun Mar 16, 2008 7:36 pm    Post subject: Reply with quote
Looks great!
As long as you're taking photos for the future 'build' thread, I can handle the occasional 'teaser' pic Smile
Good luck in getting it to The Classic.
Cheers,
Dave
*October '54 Ragtop
Denz
Denz is offline
PostPosted: Sat Mar 22, 2008 4:20 pm    Post subject: Reply with quote
I don't actually have a VIN plate for my Oval. Its obvious that the car had a smash at some point and the plate must of perished. Anyone know somewhere where I can get a replacement?
joshbuchan
joshbuchan is offline
PostPosted: Sat Mar 22, 2008 8:02 pm    Post subject: Reply with quote
Lanny & Darren at LanD make a billet one with your #'s on it
http://www.landproducts.ca/
Denz
Denz is offline
PostPosted: Sun Mar 23, 2008 2:13 am    Post subject: Reply with quote
Cheers Josh. Cool
Denz
Denz is offline
PostPosted: Sun Mar 23, 2008 9:04 am    Post subject: Reply with quote
Looking good Russ. What colour is that?
Russ
Russ is offline
PostPosted: Sun Mar 23, 2008 9:51 am    Post subject: Reply with quote
iceland green
65 beetle done:)
54vert
54vert is offline
PostPosted: Wed Oct 07, 2009 10:44 am    Post subject: Reply with quote
Russ.....I need to do the same to mine...what material was used to blast your vin plate?...sand/baking soda/other?
Thanks
James
Page 2 of 3
