extra hole in front tin
widget2k4
widget2k4 is offline
PostPosted: Tue Apr 01, 2008 12:33 pm    Post subject: extra hole in front tin Reply with quote
hi,
could someone tell me why i have an extra hole in my front tin ?
i have 3 in total,2 for the heaters and 1 next to the right heater hole about the same size but i cant remember taking a pipe from there ?
thanks
74bug
74bug is offline
PostPosted: Tue Apr 01, 2008 12:35 pm    Post subject: Reply with quote
it's for the stove pipe carb pre heat hose.
widget2k4
i dont think i have one of those ?
Glenn Premium Member
Mr. 010
Glenn is offline
It's the hot air intake for the air filter. It's used to feed warm air intpo the carb on cold days.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
widget2k4
PostPosted: Tue Apr 01, 2008 1:00 pm    Post subject: Reply with quote
thanks
that explains things I dont have a normal airfilter fitted I have a chrome round one
should I blank the hole with something?
Mr. 010
Glenn is offline
Yes... close it off.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Zundfolge1432 Premium Member
Zundfolge1432 is offline
PostPosted: Tue Apr 01, 2008 1:03 pm    Post subject: Reply with quote
No I'd shitcan the cheap after market filter and get the correct oil bath air cleaner then hook up the preheat as it should be......
widget2k4
I dont have that steel pipe that's on your photo going to the crankcase just to the left of the pully ?
DeanJ
DeanJ is offline
PostPosted: Wed Apr 02, 2008 6:31 am    Post subject: Reply with quote
Front tin? I thought that was the rear?
