sconord Samba Member
Joined: February 22, 2005 Posts: 704 Location: Dallas Texas
Posted: Wed Apr 09, 2008 7:26 am Post subject: 25hp lack of power |
I need to know what degree of advance to set the timing of a 25hp. It is correct with a 25 hp distributor.
Thanks, Stan
Joined: April 27, 2002 Posts: 6880 Location: Pentwater, Michigan
Posted: Wed Apr 09, 2008 8:40 pm Post subject: |
not so fast...
the 383 would have been set at 7.5 BTDC static... |
Suboval Samba Member
Posted: Thu Apr 10, 2008 9:15 am Post subject: |
| My Split Manual (Section E, page 5-3) says 5 degrees BTDC static for a VE 4 BRS 383. |
Posted: Thu Apr 10, 2008 1:19 pm Post subject: |
I am having a lack of top end "power". I thought it might be timing.
I had to take the 1-2 head off for an oil leak in one of the lifter tubes. After putting it back in, it idles fine but lacks the power that it DID have.
I rechecked the vavle gap and checked for an intake leak and both no problems. I am thinking now either dirt in the carb or compression leak. I can't hear any kind of compression leak noise.
Splitdog Samba Split Personality
Joined: February 16, 2004 Posts: 4148 Location: Planet VW
Posted: Thu Apr 10, 2008 1:40 pm Post subject: |
Engines should be timed at max advance. I'm not sure about a 25 hp, but my stock 1600dp is set at 40 and runs fine. (@ 3000 rpm) Let static timing fall where it may. Unless it pings or hard to start-back it down. _________________ CH³NO²
Z = z² + C
Der Blitzkrieg Kafers
#notacallooker |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9418 Location: Northwood, NH USA
Posted: Thu Apr 10, 2008 4:39 pm Post subject: |
Re torque the head bolts (nuts) on the side you took off. Sometimes after running for a bit they can get loose and cause a loss of compression.
Also check the plugs and see if there is any differences in color on the tips side to side..
If you find something, let us know!! _________________ John Henry
'57 Deluxe
'56 Single Cab |
DDub Samba Member
Joined: January 06, 2005 Posts: 320 Location: central pa.
Posted: Thu Apr 10, 2008 4:58 pm Post subject: compression |
| Why not just use a gauge and know for sure? |
53 0val Samba Professor
Joined: July 03, 2003 Posts: 11396 Location: Irvine, CA
Posted: Thu Apr 10, 2008 5:44 pm Post subject: |
Put 40lbs of air in the tires and you will get the "biggest" speed improvement.  _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Brezelwerks Samba Member
Joined: March 17, 2003 Posts: 1421 Location: Tyngsboro, MA
Posted: Fri Apr 11, 2008 9:17 am Post subject: |
| Once you check the other stuff mentioned above, you may also need a distributor rebuild, might be a flat spot at higher rpms, may be worth having it curved at Vintagewerks to see how it matches up to the factory curve, then it can be adjusted as needed. |
Seb67 Samba Member
Joined: December 02, 2003 Posts: 1012 Location: New England
Posted: Fri Apr 11, 2008 11:03 am Post subject: |
In circumstances such as these I find it very amusing that you may actually have a horse power rating in the teens.  _________________ 1964 Type 1 |
dogapult Samba Member
Joined: April 28, 2006 Posts: 552 Location: Qiryat Motzkin, Israel/ Allentown, PA
Posted: Fri Apr 11, 2008 1:53 pm Post subject: |
25hp IS a lack of power!  _________________ I can haz beetle?
1963 Type 1:"Ellie"
gzg1406: "bamboo sounds almost like manboob" |
52HoffmanSplit Samba Member
Joined: April 07, 2006 Posts: 1276 Location: Lamorinda CA
Posted: Sat Apr 12, 2008 12:50 am Post subject: |
| vwpimpster wrote: |
25hp IS a lack of power!  |
But the cool factor is HIGH... like... Off the scale High.... just drove mine tonight.... smooth as can be.... 55 up the little rolling hills, 69 down the little rolling hills and 65 top Speed on the Flats.. _________________ DB
11/1966 Porsche 912
7/1968 Type 265 Double Cab
4/1955 Type 117 - 3 Fold |
Eric Outland Samba Member
Posted: Sat Apr 12, 2008 11:35 am Post subject: Eric (VMR) |
Did you replace the Cylindrical o-ring seal on the head/ barrel I hope? did you have the slit on the seal ring facing the right way? Have you done a compression check?
Check your advance, and do a static time with a lite. Retorque manifold and head and check valve adjustment.
If you do have loss of compression and all was fine before you removed the head for the leak--check your bently and do the oil cylindrical test to trouble shoot possibilites on bad valve, broken ring etc.etc. |
splitjunkie Samba Member
Posted: Sat Apr 12, 2008 3:28 pm Post subject: Re: Eric (VMR) |
| Eric Outland wrote: |
| Did you replace the Cylindrical o-ring seal on the head/ barrel I hope? did you have the slit on the seal ring facing the right way? |
Those o-rings are not the primary seal. The junction between the top of the cylinder and the head is what forms the seal. The o-ring is just there as a fail safe to prevent exhaust gases from getting into the car since the heat is generated by the cooling air blowing over the cylinders and heads.
VW did away with the copper o-rings shortly after going to the fresh air heating system.
If the mating surface is suspect you can take the cylinders off and using valve lapping compound you can lap the cylinder to the head. That will ensure a perfect seal. _________________ Chris
Posted: Wed Apr 16, 2008 3:06 pm Post subject: |
I retorqued the head nuts.
I replaced the throttle cable which was wrapped around the clutch cable- shortening it about 1 1/2".
Seems to have solved the problem |
iamdonquixote Samba Member
Joined: January 28, 2003 Posts: 2087 Location: M*ssholia
Posted: Thu Apr 17, 2008 9:26 am Post subject: |
| custom rev-limiter! |
