25hp lack of power
sconord
sconord is offline
PostPosted: Wed Apr 09, 2008 7:26 am    Post subject: 25hp lack of power Reply with quote
I need to know what degree of advance to set the timing of a 25hp. It is correct with a 25 hp distributor.
Thanks, Stan
sconord
sconord is offline
PostPosted: Wed Apr 09, 2008 7:35 am    Post subject: Reply with quote
found it 5 degrees
http://www.thesamba.com/vw/archives/manuals/techbulletins/m1/66_page2.jpg
tasb
The Distributor Distributor
tasb is offline
PostPosted: Wed Apr 09, 2008 8:40 pm    Post subject: Reply with quote
not so fast...
the 383 would have been set at 7.5 BTDC static...
Suboval
Suboval is offline
PostPosted: Thu Apr 10, 2008 9:15 am    Post subject: Reply with quote
My Split Manual (Section E, page 5-3) says 5 degrees BTDC static for a VE 4 BRS 383.
sconord
sconord is offline
PostPosted: Thu Apr 10, 2008 1:19 pm    Post subject: Reply with quote
I am having a lack of top end "power". I thought it might be timing.
I had to take the 1-2 head off for an oil leak in one of the lifter tubes. After putting it back in, it idles fine but lacks the power that it DID have.
I rechecked the vavle gap and checked for an intake leak and both no problems. I am thinking now either dirt in the carb or compression leak. I can't hear any kind of compression leak noise.
Splitdog
Samba Split Personality
Splitdog is offline
PostPosted: Thu Apr 10, 2008 1:40 pm    Post subject: Reply with quote
Engines should be timed at max advance. I'm not sure about a 25 hp, but my stock 1600dp is set at 40 and runs fine. (@ 3000 rpm) Let static timing fall where it may. Unless it pings or hard to start-back it down.
CH³NO²
Z = z² + C
Der Blitzkrieg Kafers
#notacallooker
johnshenry
johnshenry is offline
PostPosted: Thu Apr 10, 2008 4:39 pm    Post subject: Reply with quote
Re torque the head bolts (nuts) on the side you took off. Sometimes after running for a bit they can get loose and cause a loss of compression.
Also check the plugs and see if there is any differences in color on the tips side to side..
If you find something, let us know!!
John Henry
'57 Deluxe
'56 Single Cab
DDub
DDub is offline
PostPosted: Thu Apr 10, 2008 4:58 pm    Post subject: compression Reply with quote
Why not just use a gauge and know for sure?
53 0val
Samba Professor
53 0val is offline
PostPosted: Thu Apr 10, 2008 5:44 pm    Post subject: Reply with quote
Put 40lbs of air in the tires and you will get the "biggest" speed improvement. Wink
Brezelwerks
Brezelwerks is offline
PostPosted: Fri Apr 11, 2008 9:17 am    Post subject: Reply with quote
Once you check the other stuff mentioned above, you may also need a distributor rebuild, might be a flat spot at higher rpms, may be worth having it curved at Vintagewerks to see how it matches up to the factory curve, then it can be adjusted as needed.
Seb67
Seb67 is offline
PostPosted: Fri Apr 11, 2008 11:03 am    Post subject: Reply with quote
In circumstances such as these I find it very amusing that you may actually have a horse power rating in the teens. Shocked
1964 Type 1
dogapult
dogapult is offline
PostPosted: Fri Apr 11, 2008 1:53 pm    Post subject: Reply with quote
25hp IS a lack of power! Laughing
I can haz beetle?
1963 Type 1:"Ellie"
gzg1406: "bamboo sounds almost like manboob"
52HoffmanSplit
52HoffmanSplit is offline
PostPosted: Sat Apr 12, 2008 12:50 am    Post subject: Reply with quote
But the cool factor is HIGH... like... Off the scale High.... just drove mine tonight.... smooth as can be.... 55 up the little rolling hills, 69 down the little rolling hills and 65 top Speed on the Flats..
DB
11/1966 Porsche 912
7/1968 Type 265 Double Cab
4/1955 Type 117 - 3 Fold
Eric Outland
Eric Outland is offline
PostPosted: Sat Apr 12, 2008 11:35 am    Post subject: Eric (VMR) Reply with quote
Did you replace the Cylindrical o-ring seal on the head/ barrel I hope? did you have the slit on the seal ring facing the right way? Have you done a compression check?
Check your advance, and do a static time with a lite. Retorque manifold and head and check valve adjustment.
If you do have loss of compression and all was fine before you removed the head for the leak--check your bently and do the oil cylindrical test to trouble shoot possibilites on bad valve, broken ring etc.etc.
splitjunkie
splitjunkie is offline
PostPosted: Sat Apr 12, 2008 3:28 pm    Post subject: Re: Eric (VMR) Reply with quote
Those o-rings are not the primary seal. The junction between the top of the cylinder and the head is what forms the seal. The o-ring is just there as a fail safe to prevent exhaust gases from getting into the car since the heat is generated by the cooling air blowing over the cylinders and heads.
VW did away with the copper o-rings shortly after going to the fresh air heating system.
If the mating surface is suspect you can take the cylinders off and using valve lapping compound you can lap the cylinder to the head. That will ensure a perfect seal.
Chris
sconord
sconord is offline
PostPosted: Wed Apr 16, 2008 3:06 pm    Post subject: Reply with quote
I retorqued the head nuts.
I replaced the throttle cable which was wrapped around the clutch cable- shortening it about 1 1/2".
Seems to have solved the problem
iamdonquixote
iamdonquixote is offline
PostPosted: Thu Apr 17, 2008 9:26 am    Post subject: Reply with quote
custom rev-limiter!
