Homeade/DIY Awning?
One by One
One by One is offline
PostPosted: Thu Apr 10, 2008 10:51 am    Post subject: Homeade/DIY Awning? Reply with quote
Anyone have some ideas or better yet pictures of any awnings you have built? I've seen some really nice permamently attached awning for sale as well as the Kelty type.
The theme I'm looking for is, ummm, inexpensive.
'91 Carat
Vanagon Nut
Vanagon Nut is offline
PostPosted: Thu Apr 10, 2008 11:30 am    Post subject: Reply with quote
Here check this out:
http://web.mac.com/tubaneil/iWeb/Site%205/AWNING.html
The notes I made are a little out of date as I have changed it a little.
I plan on making the jack point pieces a twist/turn lock kind of thing.
The neat thing is that whey you push out the struts (L/R) it puts enough tension on them at the jack point tubes that it doesn't slide *easily*. I plan on using bungees to help keep the struts "out". Just hook it on PVC piece and end of "beam" tube.
Not totally tested, but may give you some ideas.
Neil.
1981 Westy DIY 15º ABA
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN
jackbombay
jackbombay is offline
PostPosted: Thu Apr 10, 2008 11:52 am    Post subject: Reply with quote
*bookmarked*
I like the EMT conduit, I saw a similar one made from PVC, but the metal is better IMO.
Gas struts to pop your top easily!
Pop Top strut kits now available for late Bay window Westies Smile
Samba ad here.
DIY artificial rain gutters (ARGs)
Vanagon Nut
PostPosted: Thu Apr 10, 2008 12:05 pm    Post subject: Reply with quote
I agree. And so it seems, they are surprisingly strong.
When collapsed, and using the bungees, the polls fit along the area just above the slider door inside the Westy. IIRC, they run up into the PS area, but are not in the way.
I'll be curious to field test it under some stronger winds when I make the "L" groove for twist-locking in the jack point piece and possibly some kind of simple pin arrangement to hold poles in jack point part.
btw, some don't like the idea of the struts being in the way.
Also, I installed a SS eyehook at rear of poptop, (in place of carriage bolt on hinge) and a SS bolt/nut/washer arrangement (there must be an eyehook for this too??) mounted in place of a bolt on the luggage carrier. Although untested, it's possible with this setup, that the top can be up OR down and awning still mountable. The rear SS part doesn't raise so much that it's not doable. In theory....
Enjoy!
Neil.
(VW Gas I4)
VE7TBN
One by One
PostPosted: Thu Apr 10, 2008 6:23 pm    Post subject: Reply with quote
Thanks. Nice work, very nice.
I actual have access to some scrap 1" conduit and a bender at the job site. I'm thinking of trying to bend the conduit into jack points and see if that will be stable enough.
'91 Carat
jalopyjockey
jalopyjockey is offline
PostPosted: Thu Apr 10, 2008 6:55 pm    Post subject: Reply with quote
ive been slowly collecting parts to do a cheapy awning setup....canvas is pvc backed painters drop clothes(theyre kinda heavy, but i also kinda like that theyre that way, from home depot for 14).....the support pieces are metal adjustable clothes line props also from the depot for 5/ea.....those will be welded to two springs that have conduit or somesuch welded to the other end to slip into the jack supports......the other end of the props will slip into grommets in the clothe and the poles will be kept apart with a fiberglass rod that slips into drill holes in the poles.....im not so sure thats easy to visualize but the way i picture it the springs will force the pole tips away from the van and the fiberglass will be kept away from the canvas so that it can be used to hang towels and also allow water to run off.....i still havent figured out how to attach the clothe to the gutter yet though.....hope some of that helps
Vanagon Nut
PostPosted: Thu Apr 10, 2008 7:24 pm    Post subject: Reply with quote
Thanks!
Ironically I brought a couple of 90* pieces home today in hopes of using it as a transition from Jetta rubber lines to rubber lines then long pipes. This is for a Jetta engine to Vanagon conversion.
Oddly enough, 1.25" EMT pipe isn't really that dimension. Almost 1.5" OD
But I like the idea! No kooky holes to drill, just a slot (if you want) to fit into the tang inside of jack point hole. (there's one on each point on my '81)
The hard part for me was getting the angles so it would drain back to gutter if it rained. Bad idea. Much better, and easier, IMHO, to have it drain away from the van.
Best of luck with the awning.
Neil.
(VW Gas I4)
VE7TBN
Van Morrison
Van Morrison is offline
PostPosted: Mon Feb 09, 2009 3:18 am    Post subject: My Try at DIY awning Reply with quote
I read all the posts and thought I’d give a try at the DIY awning. Here’s my take:
Bottom Line: VERY Cheap, very quick, won’t work for me.
Ingredients: 1.7meter x 1.7meter tarp, 4 spring clamps, two adjustable height laundry poles, and one plant stake (1.7meters long).
Without wasting any time sewing I just pinned the plant stake into one edge of the tarp. I then placed the plant stake edge of the tarp into my rain gutter and secured it with the spring clamps. Next I pulled the tops off my laundry poles and placed them through each of the outer corners of the tarp. I then extended the tarp and had each of my two children hold a pole in place (in lieu of staking the tarp off or embedding the poles into the ground). The 15 knot wind blew the tarp around extensively making it clear that this would be a sun shade awning on a still day ONLY.
All tolled I spent $12.34, about an hour shopping for the goods at the 100Yen Store (aka Japan’s Dollar Tree) and the local Home Depot type and about 15 minutes on the initial attempt. What I learned is that for my purposes (withstand wind and rain) I’d need something a lot sturdier. However, the plant stake in the edge in the rain gutter held by spring clamps held like a champ though!
the poles
the tops come off the poles
tarp and clamps[/img]
'74 Transporter - Burnt to ground on I95. Cos Cob, CT.
'84 Westy - Totaled in freak drive-by while parked at repair shop. Monterey, CA.
'95 Mazda Bongo Friendee - Vanu Chau while in Northern Japan.
'81 Westy - New England
syncrosimon
syncrosimon is offline
PostPosted: Mon Feb 09, 2009 4:38 am    Post subject: Reply with quote
This is my set up.
I have a rail screwed to and the same length as the hightop. Then I sewed together 3 army tarps and a length of kador gusset. This tarp now slides onto the rail, and is much longer than the rail, so can be arranged to provide shelter as required. Total cost £30. Just need some adjustable height poles for the front. I have sewed loops all around and the trap can be used in it's own right.
But we use a tent version when staying more than one night, or it is raining.
1991 16" 2.1 DJ Syncro factory hightop ex Finnish Army Ambulance, now sold.
Thinking about Thing or 181 (182) ownership.
PDXWesty
PDXWesty is offline
PostPosted: Mon Feb 09, 2009 8:47 am    Post subject: Reply with quote
Tarps and adjustable poles work remarkably well.
climberjohn
climberjohn is offline
PostPosted: Mon Feb 09, 2009 10:12 am    Post subject: Reply with quote
I get a "file not found" error on Vanagon Nut's post at the top of this page, so I am not sure what he refers to. But it sounds like electrical conduit.
I saw a pretty nice set up at the recent Wetwesty gathering on the Oregon coast. A guy from Seattle had a Syncro hardtop with a nice Yakima rack system, He rigged an electrical conduit awning frame and then put the horizontal ends into the already mounted Yakima bars, thus connecting the conduit frame to the van in a very fast and pretty sturdy way. A tarp, awning, camel skin etc. can then be tossed over the frame. This rig has apparently been field tested in the heat and winds of Burning Man several times, so that seems a pretty good endorsement.
[/img]
'86 Westy, 2.5 Subaru power
Know your limits. Exceed them often.
campism
campism is offline
PostPosted: Mon Feb 09, 2009 10:55 am    Post subject: Reply with quote
Not exactly homemade, but home-modified. This one works for us.
http://picasaweb.google.com/bike2vcu/AwningProject#
It also retains the ability to be used as the four-pole freestanding fly in its original configuration.
Stephen
winkshog
winkshog is offline
PostPosted: Mon Feb 09, 2009 11:06 am    Post subject: Reply with quote
campism wrote:
Note exactly homemade, but home-modified. This one works for us.
Stephen
I like this idea.
85 Westy
85 7 pass w/AC 2.2_Subaru
Facebook for Operation Injured Soldiers For those how gave when they servered
Loghome for sale For those that want to get away from it all....
Vanagon Nut
PostPosted: Mon Feb 09, 2009 1:08 pm    Post subject: Reply with quote
Yah, stupid iWeb wasn't uploading files completely to my .mac. Seemed like $ was needed for software update to solve problem. I shut my .mac site down out of principal. Ain't gonna pay to upgrade software when already paying premium for space/bandwidth.... <rant off> Smile
Here's some pics from my FREE googlepages site:
http://tubaneil.googlepages.com/homemadeawning
They're tiny, but should shed some light.
Neil.
(VW Gas I4)
VE7TBN
Timwhy
Timwhy is offline
PostPosted: Wed Feb 11, 2009 3:17 am    Post subject: Reply with quote
Stephen
Your pictures look great and your work on the awning is excellant! This awning looks simular to the Bus Depot Ez Awning. At least in the design and presentation. Your idea along with my desire for a BD awning convinced me to purchase the Northwest Territory dining canopy from Sears. It will be my V-Day project, don't think I like the idea of drilling holes in my van so I'll go the BD route and secure it to the van via pole & clamps. Stephen thanks again for saving me some ca$h!!
'15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
campism
campism is offline
PostPosted: Wed Feb 11, 2009 6:15 am    Post subject: Reply with quote
The BD awning has a perimeter frame in addition to the X supporting the dome so it may be sturdier, and is pretty fairly priced. Good luck with your project!
campism
campism is offline
PostPosted: Wed Feb 11, 2009 7:56 am    Post subject: Reply with quote
For those of you using tarps as awnings, I found some interesting fittings. Go to www.leevalley.com and then click on Gardening>Leisure>Camping & Hiking.
They show several different tarp clips that might be handy for anchoring in different conditions. These things may also be available elsewhere but my gardening bride just got their newest catalog.
dubstar
dubstar is offline
PostPosted: Fri Jul 03, 2009 8:40 am    Post subject: Reply with quote
I found this link:
http://www.vanagon.com/info/accessories/inexpensive-awning/index.html
and I tested mine for the first time yesterday:
it worked really well and I am happy with the results...total cost about $28, but I already had the steel pole for the rain gutter...
I think the tent rope lengths can be shorter and only one per side is necessary if it is not windy...with two lines coming off each pole, it is very solid...little flags or bits of ribbon on the ropes will also prevent people from running into them...I'm going to try to figure out a way to set this up on hard surfaces next...
Bruce Wayne
Bruce Wayne is offline
PostPosted: Fri Jul 03, 2009 9:06 am    Post subject: Reply with quote
I used some re-bar "feet",not sure what you really call them. you can see them in this pic.
my awning is made from conduit so they may be to big for your needs. something like it should work for you though. I also put eye-hooks in the feet of mine so I could stake it down and added a middle leg since this pic.
buildyourown
buildyourown is offline
PostPosted: Fri Jul 03, 2009 9:33 am    Post subject: Reply with quote
Here is the best one I've seen.
Guy lines were a deal breaker for me since I regularly camp in large parking lots. (ie, bike races)
http://www.lcool.org/technical/sunshade/sun_shade.html
Not homemade, but probably one of the cheapest especially since shipping is free.
http://campinglab.com/awning.html
