Is this a small diameter 12V generator?
mpribanic
mpribanic is offline
PostPosted: Tue Apr 22, 2008 4:46 am    Post subject: Is this a small diameter 12V generator? Reply with quote
A friend of mine came across 3 NOS generators. He said the were small diameter Porsche generators & were 12V. The ones were he could upgrade his 356 from 6V to 12V using the 6V generator stand.
When I got there to see them, they were in the VW box, wrapped in cardboard and wax paper.
VW part number is: 113.903.031
Bosch part number: Bosch 0-101-206-116 14V/38A
I could not find this number referenced on line at Bosch. Can anyone confirm the compatibility of this generator?
My question is to confirm or refute that this generator is a possible option for replacement of a small diameter 6V generator with a small diameter 12V generator. Can this be substituted in a 12V upgrade.
Here's some pics showing the markings and codes:
TIA[/quote]
Call your Cunado's:
https://vimeo.com/67661950
runamoc Premium Member
runamoc is offline
PostPosted: Tue Apr 22, 2008 6:09 am    Post subject: Reply with quote
From what I remember, these can be used when changing over to 12v. You don't have to change out the gen stand. It can be used on those old 25 hp engines that can't change the gen stand, if need be.
hazetguy
hazetguy is offline
PostPosted: Tue Apr 22, 2008 6:20 am    Post subject: Re: Is this a small diameter 12V generator? Reply with quote
the part number, on the part, is 113 903 031 E, which, according to my parts book is a generator, 12V, without regulator, 90mm diameter. so yes, you could use this on a 25hp, 36hp, 40hp (that had a 90mm generator pedestal). measure the diameter of the generator. if it is indeed 90mm, and not 105mm like the later style 12V, you should be good to go, as long as you get the correct 38A regulator.
mpribanic
PostPosted: Tue Apr 22, 2008 9:56 am    Post subject: Re: Is this a small diameter 12V generator? Reply with quote
Thank you.
I had the hardest time trying to look up the part number.
Which parts book did you use to reference the numbers?
Call your Cunado's:
towd
towd is offline
PostPosted: Tue Apr 22, 2008 10:30 am    Post subject: Reply with quote
Do you have any Idea of the value of those ???
A core will go for 100 Bucks, I should say thats what I got not non working small gen's.. The good ones went a bit higher ...LOL.
runamoc is offline
PostPosted: Tue Apr 22, 2008 10:32 am    Post subject: Reply with quote
I did a google search on 113 903 031 E and found this:
http://www.allzim.com/acatalog/Remanufactured_Generator__356_912_12V.htm
they even have other interchange numbers. $309.95 REMANUFACTURED Shocked with a $325.00 core deposit. That's one valuable item you have there.
Lionhart94010
Lionhart94010 is offline
PostPosted: Tue Apr 22, 2008 1:11 pm    Post subject: Reply with quote
Interesting, all my Type 2 bus Generators are 38A, and they are longer than the standard 30A Bug units, it seems that it would be hard to put 38A in a smaller diameter than standard case if they had to lengthen the 30A to get the 38A?
Part numbers comes up at Bus depot for 113903031
Generator
New, Bosch
Part Reference Number*: 113903031PX $172.81
Brand: Bosch/Germany*
Dynamo
Part Reference Number*: 113903031E $1,022.27
Brand: Volkswagen/Germany*
Do you think they could be OEM VW bus generators, I bet if you e-mail www.busdepot.com they will tell you the difference :0)
Current VWs 71 T2 Westy SO-72/6(Miami), 71 Crew Cab, 2015 GSW TDI
Other owned VW’s 59, 68 1500s, 69 & 71 Bug’s; 72 & 73 S-Bug’s; 67 Westy, 67 Deluxe, Other 71 DC, 72 KG GT that now lives in Australia, 12 JSW TDI, 2015 GSW TDI, 2023 Tiguan
VW technical information sights
thesamba - www.ratwell.com - www.shoptalkforums.com/ - www.vw-resource.com - http://www.type2.com/
http://bobhooversblog.blogspot.com/ - www.aircooled.net/gnrlsite/resource/articles.htm
Ferdinand
Ferdinand is offline
PostPosted: Thu Jun 07, 2018 8:15 pm    Post subject: Re: Is this a small diameter 12V generator? Reply with quote
I intend to use this 101 206 116 generator on a Porsche 356 B engine, which correct regulator (part number) should I use for this generator ? Thanks
Can I use this voltage regulator with no risk ?
perello
perello is offline
PostPosted: Fri Jun 08, 2018 6:42 am    Post subject: Re: Is this a small diameter 12V generator? Reply with quote
No, that one is 30A
you need BOSCH F 026 T02 205
Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200
Dale M.
Dale M. is offline
PostPosted: Fri Jun 08, 2018 8:00 am    Post subject: Re: Is this a small diameter 12V generator? Reply with quote
This quote from CIP1 ad... Also reflected in many other ad's...
"This is the new style SOLID STATE voltage regulator (Part # 919004009) which replaces the old style box regulator.
Will work with both the 30 or 38 amp Generators."
http://www2.cip1.com/ProductDetails.asp?ProductCode=BOS-30019
Dale
FreeBug
FreeBug is offline
PostPosted: Fri Jun 08, 2018 8:52 am    Post subject: Re: Is this a small diameter 12V generator? Reply with quote
I used one of those electronic regulators on a 38 amp 12V gen, on my bus, for years, was very happy with it and highly recommend them: the overall voltage of the system went up, better lighting, faster starter, faster turn signal relay, happier battery, etc...
Finally, an actual improved product!
Brian
Brian is offline
PostPosted: Fri Jun 08, 2018 11:17 am    Post subject: Re: Is this a small diameter 12V generator? Reply with quote
I have a few NOS 38 amp regulators for sale. Send me a PM if you want one.
But yes, you can use a 30a regulator with a 38a gen. You cannot use a 38a regulator with a 30a generator.
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
Ferdinand
PostPosted: Fri Jun 08, 2018 9:24 pm    Post subject: Re: Is this a small diameter 12V generator? Reply with quote
Thank you for your replies.
