Yustrn JHC Controla
Joined: August 01, 2000 Posts: 5494 Location: Ovaland, CA
Posted: Wed Mar 01, 2006 11:03 am Post subject: Grey Primer / Paint color used on Bus chassis and cargo area |
Looking to repaint/primer the rear of my Kombi anyone have a correct color code or matching primer color for the rear of a kombi? _________________ I own a copy of "The Car of the Century" by Garwood. This means I am authorized to act like a twat in thesamba forums. |
busracer Samba Member
Posted: Wed Mar 01, 2006 12:03 pm Post subject: |
| i got mine color matched and then had a matting agent added when it was mixed. the primer can vary ...look very different in different buses. ive seen some goofy looking greys in commercial buses applied by owners and it just looks wierd...either too glossy or the color waaay off. ppg epoxy primer in grey has the perfect sheen but is a little too blue looking for me. the plus is its super tough. |
Yustrn JHC Controla
Posted: Wed Mar 01, 2006 1:16 pm Post subject: |
I'm not doing 100 point resto, but want it to look nice overall, thanks for the info on the .ppg I need to buy some epoxy anyway. _________________ I own a copy of "The Car of the Century" by Garwood. This means I am authorized to act like a twat in thesamba forums. |
Macca_nzl Samba Member
Joined: December 22, 2003 Posts: 367 Location: Sydney, Australia
Posted: Wed Mar 01, 2006 5:36 pm Post subject: |
What about micro's.
Does the inside colour match the outside colour/colours?
I'm doing my bus PGSG need to know what the interior should be?
Mac _________________ 71 1302s
wanted - Blade from ambo fans. |
Skywave Samba Member
Joined: January 15, 2004 Posts: 73 Location: San Diego, CA
Posted: Thu Mar 02, 2006 6:48 pm Post subject: |
I've matched this color in the past for a few projects. You can just shoot a primer but it won't be as well protected and you can't choose the color. I ordered the paint in semi gloss to match the matte finish of the original paint.
These photos are for an ambulance fan I restored. Being a retard I thought I'd go through the trouble to paint the back side in the proper grey even though no one will ever see it. But fortunately I can sleep at nights now knowing it’s the right color underneath.
This grey will match a majority of the matt grey colors used without having to match every single one. It’s an off the shelf color and can be made ay any paint store. I thoroughly went through the book and held this color to the back of this fan and then took it out to the bus and compared it against the inside cargo door and front splash pan. All three pieces appeared to be slightly different shades believe it or not. While not dead ringer for all three this color is by far the closest of any others without having each part sampled and ordering separate paints for everything. Dar is a single stage paint, make sure and get it in semi gloss and then let ‘er rip! Good luck!
PPG Delstar DAR-33127
(note that the ambient lighting throws the hue off in some of these photos)
Kombi Samba Member
Joined: August 02, 2002 Posts: 562 Location: Edmonton, AB, Canada
Posted: Fri Oct 12, 2007 12:00 pm Post subject: |
For those who did a close as possible to original restoration, what paint did you use on your bus frame/chasis?
What about an original paint code for a kombi interior or chasis? wouuld it be L29? Thanks _________________ Air and Water are needed to survive,
you just can't live as long without air!
Air Riders, VW Club |
jayres12 Samba Member
Joined: November 07, 2007 Posts: 13 Location: Northern California
Posted: Thu Nov 08, 2007 6:48 am Post subject: |
This is the first time I've used this site. What an asset! Thank you guys for the good information.
Jim |
ol36er Samba Member
Joined: May 24, 2006 Posts: 308 Location: East Coast Kanada
Posted: Fri Nov 09, 2007 7:56 am Post subject: |
| Macca_nzl wrote: |
What about micro's.
Mac |
The whole bus is painted the sand green color first then top half painted palm green, with obvious PG overspray. Not sure about underbelly, prob.
primer.
Here's a few examples
Battery tray
pass.side
wheelwell
wheelwell
_________________ WTB - Green Middle Seat Snowflake Kickpanel
WTB - Wingnut air cleaner |
SixVolt Samba Member
Joined: January 04, 2004 Posts: 1147 Location: Cleveland, Ohio
Posted: Wed Apr 23, 2008 6:10 pm Post subject: |
Is the PPG Delstar DAR-33127 the same as L29 ?
Anyone know if this other color next to the cargo gray on my '59 split is anything other than a PO repaint?? (The bus was originally a mango green/seagull grey if it matters.)
Before I sand it off, I want to make sure it's not a stock interior color. Appreciate it...
Here is another look showing the color...
Campy Samba Member
Joined: January 10, 2005 Posts: 4933 Location: Chico, CA
Posted: Wed Apr 23, 2008 8:34 pm Post subject: |
I painted the underbody, wheel wells, body, and interior of my 1958 walk-thru camper using Nason grey epoxy primer (the body, engine compartment, and cab will be painted dove blue). The underbody looks awesome and if you spray on two coats of the epoxy primer, it will seal out moisture.
For my 1963 walk-thru camper, I sprayed Omni grey epoxy primer over the whole bus (over the polyester primer filler), then painted it dove blue, leaving the cargo area grey. _________________ Don't worry; be happy. (Baba) |
Stocknazi Samba Member
Posted: Thu Apr 24, 2008 5:32 am Post subject: |
| Sean Gallagher wrote: |
sean,
yes, that looks like the og brown that was brushed on at westfalia when the kit was installed. westfalia applied it to some buses with the interior installed and in some with it not installed. appears your bus has had it applied with the interior not having been installed. are you doing a complete resto? if you are you want to re-apply it with a brush for the right look. if it were my bus i would buff it out lightly and wax to leave og. _________________ WANTED:
Thomas Jefferson |
Posted: Thu Apr 24, 2008 6:05 am Post subject: |
| StockNazi wrote: |
sean,
yes, that looks like the og brown that was brushed on at westfalia when the kit was installed. westfalia applied it to some buses with the interior installed and in some with it not installed. appears your bus has had it applied with the interior not having been installed. are you doing a complete resto? if you are you want to re-apply it with a brush for the right look. if it were my bus i would buff it out lightly and wax to leave og. |
I greatly appreciate that info. Yes, its become a complete resto. I ask because I don't want to screw it up by removing something that really shouldn't be removed. The "brown" is in good enough shape that I can clean it and buff it out. That will be my approach. When I get the welding done I will want to repaint portions of the grey.
Is that PPG code above the right grey? Is it L-21? In the event I need to touch up that "brown", do you know a color code? (I can always take a door in for a color match if necesssary.)
I greatly appreciate those with early bus knowledge sharing info. |
Posted: Thu Apr 24, 2008 6:18 am Post subject: |
the L-21,pearl grey, i think is an exterior color code.
the general consensus on the primer gray is that it varied in hue over the years and there is not 1 set color that is correct for all buses. best bet is to take a door in to have matched. the og primer seems to be more of a semi-gloss.
glad to here you will be preserving the og westy brown, and that it's in nice shape. if you need to touch up any of the brown, having it color matched would be your best bet. if anyone has had this done and has a color code they want to share that would be helpful. _________________ WANTED:
Thomas Jefferson |
gonzee Samba Member
Posted: Mon Sep 21, 2015 4:46 pm Post subject: |
| Painting my double door decided to paint body dove blue and cargo area grey. Does anyone have pics of where the colors change from grey to blue on bulk head. |
EverettB  Administrator
Joined: April 11, 2000 Posts: 72013 Location: Phoenix 602
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2611 Location: UK (South)
Posted: Mon Dec 12, 2016 12:59 pm Post subject: Re: Grey Primer / Paint color used on Bus chassis and cargo area |
I thought I'd add this here as a reference. My truck spent the first 50-odd years in California and is very dry underneath. I took the heater wrap off at the weekend to clean it and inspect the heater tube. It's a bit dusty from the crud that came off the heat wrap as I removed it (I haven't wiped it clean yet), but I'm pretty sure this is the original finish. It's a bronze colour and has a smooth satin finish. The underside of the cab floor is a similar colour. This stuff doesn't react to phosphoric acid. It is not surface rust. The truck was built in October '56.
Would it benefit anyone if I took some better pictures after cleaning the dust off and posted them here?
_________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26400 Location: Olympia Wash Rinse & Repeat
Posted: Mon Dec 12, 2016 1:23 pm Post subject: Re: Grey Primer / Paint color used on Bus chassis and cargo area |
| Who.Me? wrote: |
| It's a bit dusty from the crud that came off the heat wrap as I removed it (I haven't wiped it clean yet), but I'm pretty sure this is the original finish. It's a bronze colour and has a smooth satin finish. The underside of the cab floor is a similar colour. This stuff doesn't react to phosphoric acid. It is not surface rust. The truck was built in October '56. |
Our MAR62 built SO-34 has same finish inside the body. Had to cut out the crushed upper driver "A" pillar to find this:
_________________ In Stereo, Where Available! |
Posted: Tue Dec 13, 2016 6:26 am Post subject: Re: Grey Primer / Paint color used on Bus chassis and cargo area |
| Eric&Barb wrote: |
I figured it must be the colour of the anti-corrosion coating that VW dipped vehicles in before painting and that would make sense if it's found inside body cavities, but I thought the coating was Zinc Phosphate? I'd expect Zinc Phosphate to be grey or black not bronze like this, so I'm not sure what they used?
I'd also expected that if they'd primered the underside, they'd have sprayed the heater tube too, or at least that there would be evidence of overspray from the primer, but there is no evidence of any on the heater tube.
Did VW prime the underside of Type 2s from day one, or was that introduced later? Progressive refinements says that the underside was 'additionally painted' from 20th June 1958* and chassis 366949. Do they mean 'primed' rather than painted (i.e. primer introduced in June '58 )?
The treasure chest of my truck is painted/primered a sort of grey/beige. It's an obvious colour. I figured the primer must have worn/rusted off of the underside and frame, but the more I look, the more it looks like there never was any primer.
The rear U-cradle is body colour, but nothing else under there seems to have any paint/primer.
*Typo corrected  _________________ Andy
Posted: Tue Dec 13, 2016 8:45 am Post subject: Re: Grey Primer / Paint color used on Bus chassis and cargo area |
You have a typo of "20th June 1985".
The word "paint" is both a noun and verb.
https://www.merriam-webster.com/dictionary/paint
So a primer is still painted onto a surface. Plus the grey "primer" used by VW does seem to be more of a primer & paint in one.
Your normal cheap primer is porous kinds of like newspaper, so it needs to be painted over or water passes right thru it causing the steel to form rust very quickly in just days. That type of primer was designed to cling well to metal and at same time give paint over it something to cling to much better than bare metal. Which otherwise it would easily peel off from metal without a primer. _________________ In Stereo, Where Available! |
