Shiny new TB from scratch; pics
Page: 1, 2, 3  Next
Do you need a new throttle body?
Oh yes, please, mine's like a screen door after Katrina
63%
 63%  [ 35 ]
No, I like my crappy idle, surging and hot-starting problems just fine, thanks
12%
 12%  [ 7 ]
What's a throttle body?
23%
 23%  [ 13 ]
Total Votes : 55
tencentlife
tencentlife is offline
PostPosted: Thu Apr 24, 2008 8:42 pm    Post subject: Shiny new TB from scratch; pics Reply with quote
Here's a few shots of the project that has been busying me these last few weeks: a brand spankin new throttle body to replace the badly-designed worn-out POS that came on the wbx, and a complete workaround for the idiotic TB switches. This is the kind of fun you can have when you get a few small machine tools.
I love this stuff!
It's made up of a 1/2" adapter plate that fits to the tapered plenum spigot, using the OEM sealing ring.
Then the main valve body with butterfly and idle bypass circuit bolts to the face of the adapter. A tube extension seals with an o-ring into the valve body, and has a groove with another fat o-ring for the rubber intake bellows to grip and seal to.
You can see the idle air screw on the rear face of the valve body. I left the top surface clear because i didn't know if I would need to mount a switch there, but it's not going to be necessary, so future copies will have the air screw there where it will be easier to access.
Here's the adapter and valve body laid together, viewed from the engine side. You can see a slot between them, which is the delivery point for the idle air bypass. The inlet is a hole just upstream of the butterfly. The idle air screw varies how much air can flow around the butterfly thru this route.
I made the body as three pieces like this to save materials and make the process easier. Otherwise it would have to be made from a solid 4" round bar, with most of the material being turned into waste. The o-ring seal for the bellows is needed because the 2" aluminum pipe I can get is a little smaller OD than the OD of the stock TB spigot. It does make a good seal and grip, though. The adapter plate snugs down so the plenum spigot ends up butting right against the back of the valve body, eliminating a huge vacant groove left there in the stock installation, so it's a lot more aerodynamic internally once installed.
The 1/4" brass shaft runs in two tiny sealed stainless ball-bearings, and shaft endplay is tightly controlled, so there will be no wear on the ends of the butterfly, unlike the stock design that used the butterfly itself as an axial control, which guaranteed that it would wear badly.
I managed to get the clearance down to .001-.0015" all around the butterfly. That sounds pretty good, but I'd like to get it tighter still.
I drilled and countersunk the plate for flathead screws, so that side of the plate is smooth and aerodynamic, but the countersinks mean that the plate will center to the screws when tightened. That means the drillings have to be super-precise in the plate and the shaft, but it's tough to get the locations to within less than .001". Next time I'll just use some panhead screws because even though the heads will be bumps in the WOT airflow, it will enable me to locate the plate laterally with more precision after the fact. That will let me turn the butterfly to a total of .001" less than the bore diameter and still get it centered in the final install.
And finally, my secret weapon. I'm using an adjustable, very sensitive vacuum switch to replace the OEM mechanical TB switch or switches. I have it wired to the unused OXS LED in my inst. cluster as a test so I can see how it responds. The LED lights whenever there is switch closure, at idle and under load. This thing is far more responsive to transition off idle, the slightest touch of the pedal makes the LED go out, and it gives a WOT switch closure whenever manifold vac falls to less than 1"Hg. That means that the enrichment signal is given even at mid-throttle if engine load is high. No need to hold the pedal to the floor to get the ECU to run open-loop. Instead, it gives the signal when load is high, and opens again as vac returns, regardless of pedal position. Sometimes you're WOT, but don't need open-loop. This knows the difference. It just works on the EEC signal line.
Sorry, no pics of that.
Anyway, enjoy! And if anyone would like a copy, after working out any bugs I'll be offering these on my ad. Link below.
Experience is death to doctrine.
Christopher Schimke
PostPosted: Thu Apr 24, 2008 8:48 pm    Post subject: Reply with quote
HOLY CRAP!!!! I love you!
funagon
funagon is offline
PostPosted: Thu Apr 24, 2008 8:56 pm    Post subject: Reply with quote
That is awesome tencent. So, is it installed in the van, and are you driving it?
I didn't answer your survey because my lo-mileage van has a good TB. But I will need one eventually, just like everyone else who wants to keep driving these vans for years to come.
1990 GL 7-passenger
2.2 liter WBX
Dogpilot
Dogpilot is offline
PostPosted: Thu Apr 24, 2008 8:58 pm    Post subject: Reply with quote
Very nicely done! I think the vacuum switch is beyond clever, have you been raiding my Demerol supply? I have interest in one of your production models when you get it refined.
Bravo!
Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G
tencentlife
PostPosted: Thu Apr 24, 2008 9:13 pm    Post subject: Reply with quote
Oh, I forgot the installed pic, didn't I?
Thanks guys, glad you like it.
Oh, and Dog? save some.
rogerw
rogerw is offline
PostPosted: Thu Apr 24, 2008 9:51 pm    Post subject: Reply with quote
I don't "need one" but that won't stop me from sending you a check. That TB looks sweet and would be one more reason not to more seriously plan for the suby swap. Thanks for adding to the list of parts I need to buy from 10C (exhuast, TB, motor). Smile
Again, nice work.
RW
____________________________________
87 Sunroof Syncro with full Bluestar interior
CF
CF is offline
PostPosted: Fri Apr 25, 2008 1:12 am    Post subject: Reply with quote
some one has a bit of time on their hands...............lol
nice job.......
sagebus
sagebus is offline
PostPosted: Fri Apr 25, 2008 6:55 am    Post subject: Reply with quote
The wish list keeps growing. I dream about that fine engine you build, Have lusted over the SS exhaust, And today I marvel over that throttle body! Wow ! Fine work! Keep it up.
1984 Vanagon GL, Wolfsburg Westy 1.9 ltr
snoop
snoop is offline
PostPosted: Fri Apr 25, 2008 7:08 am    Post subject: Reply with quote
Schweet! The camel's gonna need a "10¢ powered" bumper sticker Smile.
87 Westy Camper
Wellington
Wellington is offline
PostPosted: Fri Apr 25, 2008 9:08 am    Post subject: Reply with quote
I'm loving it!
inspector58
inspector58 is offline
PostPosted: Fri Apr 25, 2008 9:27 am    Post subject: Reply with quote
Very nice work!!
Loud pipes save lives!
allsierra123
allsierra123 is offline
PostPosted: Fri Apr 25, 2008 10:40 am    Post subject: Reply with quote
Dang 10c you are going to make start wanting to build up a very high performance 2.1 If you could do something for the leaky head problem then I would be all over keeping my engine.
95 GMC Yukon 6.5 TD 2 Door Tow pig/ Daily driver.
91 Vanagon GL. 1.9TD Conversion Sold
81 Vw rabbit 1.6 Diesel. Sold
tencentlife
PostPosted: Fri Apr 25, 2008 10:48 am    Post subject: Reply with quote
No 2.1's coming outa my shop.
2.2 and up.
There's a leaky head problem?
Vanagon Nut
Vanagon Nut is offline
PostPosted: Fri Apr 25, 2008 11:00 am    Post subject: Reply with quote
Mr. .10
What *little* I've done turning stuff, or "designing" anything (adapting actually..... and limited to "L" bracket complexity at that Wink ) sure makes me appreciate the work you've done.
Bravo!
Neil.
1981 Westy DIY 15º ABA
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN
allsierra123
PostPosted: Fri Apr 25, 2008 11:02 am    Post subject: Reply with quote
yeah I need to see what I can do to remedy it before I put my engine back in my van.
floggingmolly
floggingmolly is offline
PostPosted: Fri Apr 25, 2008 3:28 pm    Post subject: Reply with quote
Awesome. And I thought home remodeling was a challenge. Geez.
'85 Wolfsburg Weekender
brooklynvan
brooklynvan is offline
PostPosted: Fri Apr 25, 2008 3:42 pm    Post subject: Reply with quote
in awe.
Can you put one on the engine I hope to get from you?
1990 Vanagon "Plain Jane" Bostig in the Back
TRADED: 1967 Panel for 1976 BMW 2002
SOLD: 1984 Sunroof Vanagon with EJ22
RIP 1986 Saab turbo
and my daily commuter: a Bicycle
View user's profile Send private message Visit poster's website Instagram Classifieds Feedback
Crankey
Crankey is offline
PostPosted: Fri Apr 25, 2008 4:56 pm    Post subject: Reply with quote
wow, killer ! I want one now ! with you, I may not do that subaru conversion. I still love that SVX manifold Rolling Eyes
but seriously I really find your work really interesting. I planned on a subie at some point but I might not since your work on the WBX is making it more interesting.
I'm definatly interested in the SS exhaust.
snoop
snoop is offline
PostPosted: Fri Apr 25, 2008 8:20 pm    Post subject: Reply with quote
Presumably no compatibility issue with the GW hot wire AFM...right? Or non-stock 2.1s (in particular GW WBXers)? Is tuning of your TB required (read: possible) for these motors? And/or when vented by your TBA headers? And/or to optimize 1.25 ratio rockers? With apologies for my ignorance, the more sophisticated the reply, the better.
Most sincere thanks for your efforts to keep vanagons volkswagens.
87 Westy Camper
allsierra123
PostPosted: Fri Apr 25, 2008 9:23 pm    Post subject: Reply with quote
Is this going to mean better gas mileage?
Page: 1, 2, 3  Next
