vwsrus Samba Member
Posted: Thu Apr 17, 2008 10:31 pm Post subject: Floor Pan size questions |
I need to replace the floors in my 74 Thing.
I've often heard that they are the same size as the Ghia. True?
Can I use Ghia pans in it? Any differences if so? |
Ian Epperson Samba Member
Joined: January 12, 2005 Posts: 2262 Location: Alameda, CA
Posted: Thu Apr 17, 2008 11:22 pm Post subject: Re: Floor Pan size questions |
vwsrus wrote: |
I've often heard that they are the same size as the Ghia. True? |
Yes.
vwsrus wrote: |
You can use Ghia pans (I did). The Thing pans are stamped out of heavier gauge metal, but use the exact same pattern. _________________ VW-181 shirts and stickers.
http://ian.epperson.com/vw |
Ron Domeck Samba Member
Joined: August 05, 2007 Posts: 1466 Location: louisville Ky
Posted: Sat Apr 19, 2008 2:21 pm Post subject: |
The pans that they say are for the Ghia looks to be stamped from a Thing. The Ghia did not have the half circle stamping across the front on both sides and the replacement pans has indents in all the correct spots for the floor studs that hold the mats in. |
ConchThing Samba Member
Joined: March 23, 2008 Posts: 31 Location: Jupiter, FL
Posted: Mon May 12, 2008 2:59 pm Post subject: |
So which is better to have? The Thing Shop has both sides for $425 w/ shipping. Are the Ghia pans thicker? Where can you buy those? _________________ S&J
'74 Thing |
mrafindley Samba Member
Joined: December 29, 2007 Posts: 642 Location: miami Florida
Posted: Mon May 12, 2008 3:53 pm Post subject: |
Thing pans are thicker. Ghia pans work just fine and you can find them cheaper _________________ 73 THING
67 Beetle
http://w2.wolfsburgii.com/downloads.htm |
Posted: Mon May 12, 2008 8:47 pm Post subject: |
Cool, thanks. That's exactly where I'm at with the resto.....stay tuned! _________________ S&J
'74 Thing |
TeamSpatula Samba In The Rain
Posted: Tue May 13, 2008 7:44 am Post subject: |
Any recommended sources? It's up to about 99% chance I'll finally be getting a Thing pretty soon, and I know it's going to need both sides...
thanks, _________________ <---Air Cooled Search & Rescue Team - STICKERS & T-shirts for sale!
1981 Diesel Rabbit
I NEED A CAMPER!!!! (1971 is ideal but will consider other years)
http://www.TeamSpatula.com |
Posted: Wed May 14, 2008 3:47 pm Post subject: |
I know the Thing Shop sells both sides for $425 shipped. So far that's all I've found _________________ S&J
'74 Thing |
Posted: Wed May 14, 2008 9:28 pm Post subject: |
Checked out that site...Going to be just a couple bucks more for both sides, plus shipping to the east coast. Besides, says it's for Ghia, in which case they won't be as thick. Thanks for the site, though. Has alot of Thing parts. Nice to have a comparison!!! _________________ S&J
'74 Thing |
Posted: Thu May 15, 2008 5:23 am Post subject: |
They work just fine .002 thickness difference but to each their own. If your reall brave I know where there is a set of fiberglass pans for cheap _________________ 73 THING
67 Beetle
Posted: Thu May 15, 2008 5:41 am Post subject: |
mrafindley wrote: |
They work just fine .002 thickness difference |
Is that really the difference between Thing & Ghia pans? Man, if that's the case then really why not go with the Ghias? _________________ <---Air Cooled Search & Rescue Team - STICKERS & T-shirts for sale!
1981 Diesel Rabbit
Posted: Thu May 15, 2008 10:15 am Post subject: |
OK, I did it!! (' ') I finally bought the floor pans, Thanks Uncle Sam. I ended up going through TTS. I talk to my dad and he said it was a better idea to buy the Thing pans and not the Ghia pans-that the Ghia pans would need to be cut. I just wasn't keen on that idea, too much hassle. The bad news is that, as we are all feeling the fuel prices like thorns in our side, TTS can no longer have the free shipping. They do, however, pay half the shipping. Every little bit helps, mind you I'm in S Fla and TTS is in AZ-alot of dirt to cross! I also opted to get the rails now, since the shipping didn't increase with the extra weight.
Here is the breakdown...
Pans $212 ea
rails $110 ea
Shipping $30
Came out to $645.(' ') More than I planned, but I know that it'll fit and I got the rails so we can get it done quicker. Now just gotta break the news to hubby when he gets home....  _________________ S&J
'74 Thing |
Patina Turner Samba Member
Joined: December 26, 2004 Posts: 41 Location: Sacramento, CA
Posted: Thu May 15, 2008 10:47 am Post subject: |
Thats good that you were able to get TTS ones. I got the ghia ones from cip which I think are the standard ghia pans every one Carry's and they are a little ruff around the edges no seat rails, relief cuts, no holes drilled for the body bolts other than that they look like they fit well good luck. josh _________________ 73 Thing |
Posted: Thu May 15, 2008 11:37 am Post subject: |
Patina Turner wrote: |
Thats good that you were able to get TTS ones. I got the ghia ones from cip which I think are the standard ghia pans every one Carry's and they are a little ruff around the edges no seat rails, relief cuts, no holes drilled for the body bolts other than that they look like they fit well good luck. josh |
Looking at the Thing Shop pans, the don't have seat rails either, and will need those holes drilled out too...Could they be the same pan? There can't be that many companies stamping those out...
http://www.thethingshop.com/detail.asp?PRODUCT_ID=181FPH _________________ <---Air Cooled Search & Rescue Team - STICKERS & T-shirts for sale!
1981 Diesel Rabbit
Posted: Thu May 15, 2008 3:04 pm Post subject: |
you need to drill your own. The latest catalog ad's one's with the rails, but they said they didn't have enough manpower to have them already prep'd. That's cool, can drill holes, just didn't want to cut and fit, ya know......BTW, hubby is cool, pressure washing the yrs of grease/grime as we speak, just as psyched as I am ETA 3-5 days, will let you know more on arrival _________________ S&J
'74 Thing |
kubelmann Samba Member
Posted: Thu May 15, 2008 8:17 pm Post subject: |
Kinda high on the seat rail price ouch.. Hope you remembered to get new pan seals for your new pan halves. If not I got em. |
