Baywindow light bulb chart?
rjonas
rjonas is offline
PostPosted: Tue May 20, 2008 5:47 am    Post subject: Baywindow light bulb chart? Reply with quote
Looked through my Bentley (1979 edit) last night but could not find a chart on light bulbs stating lamp numbers for specific locations. Ex- tail/brake=1157.
Is there such a guide or chart?
Specifically I need a license plate lamp # now.
Searched first using "lamp" and "bulb" in titles. Sorry if this is a repost.
Thanks,
Dim in St Louis.
1979 Type-2 Westfalia “Sandy”
1973 Type-181 Thing "Velma"
1956 Type-1 Beetle Patina Project “Rosie”
www.azbusclub.org
VDubTech
VDubTech is offline
PostPosted: Tue May 20, 2008 5:51 am    Post subject: Reply with quote
Yes, there is a chart right in your owner's manual, many of which there are electronic copies of on this very site.
Althea78
Althea78 is offline
PostPosted: Tue May 20, 2008 5:56 am    Post subject: Reply with quote
I took my old bulb to the auto parts store and looked in the light bulb section. They had 2 that looked like it. The difference was 5 watt or 10 watt. I went with the 10 watt. It works great.
'78 Westy
hazetguy
hazetguy is offline
PostPosted: Tue May 20, 2008 5:57 am    Post subject: Reply with quote
rjonas
rjonas is offline
PostPosted: Tue May 20, 2008 6:22 am    Post subject: Reply with quote
Ah ha! The owners manual. I knew I had seen that chart before.
In my glovebox just under my nose while I was sitting in the passenger seat thumbing through the Bentley last night.
I am a dumbass. Embarassed
At least I can buy the #89 license plate lamp on my way home from work now.
Thanks.
www.azbusclub.org
NASkeet
NASkeet is offline
PostPosted: Tue May 20, 2008 6:26 am    Post subject: Baywindow light bulb chart? Reply with quote
The official VW Owners' Handbook, for the British specification, 1973 VW 16/1700 Type 2, also specifies the bulb wattages, for each application; including those in North America.
hazetguy wrote:
Regards.
Nigel A. Skeet
https://vwt2oc.co.uk
Tcash
Tcash is offline
PostPosted: Fri Aug 25, 2017 2:43 pm    Post subject: Light Bulb Chart T2 Reply with quote
To link to this thread copy and paste
Code:
[url=https://www.thesamba.com/vw/forum/viewtopic.php?p=8539877#8539877]Light Bulb Chart T2[/url]
LIGHT BULB CHARTS
- NOTE BULBS NOT LISTED
- N 17 751 2 = 2721 12v 1.2w Instrument/Warning light bulb
2723 12v 2.3w bulbs can be used for brighter Instrument illumination. (note: not to be used for warning idiot lights)
- N 17 723 2 = 6411 12v 10w Dome light Bulb.
LED lighting upgrades FAQ
1969
1970
1971
1972
1973
1974
1975
1976
1977
1978
1979
Tcash
Tcash is offline
PostPosted: Wed Sep 06, 2017 10:47 am    Post subject: Philips Bulb Guide for: VOLKSWAGEN Transporter Reply with quote
High & low beam headlamp H6024
Parking light 1157
Front turn signal 1157
Rear turn signal 1156
Tail light 1157
Stop light 1157
License plate 89
Back up light 1156
Front side marker 1895
Rear side marker 1895
Instrument-general 12516
Yoda78
Yoda78 is offline
PostPosted: Sun Jul 02, 2023 1:31 pm    Post subject: Re: Baywindow light bulb chart? Reply with quote
I've been replacing bulbs with LED replacements, and I found 2 very small bulbs beside the front turn signal lamps - I can't read the markings - any Idea what they are?
Thanks for any advice,
busdaddy
busdaddy is offline
PostPosted: Sun Jul 02, 2023 1:42 pm    Post subject: Re: Baywindow light bulb chart? Reply with quote
Welcome!
I'ts on the charts posted above, front and rear side marker lamps is what they are called.
Слава Україні!
