What rockers to use for what cams
Euro 67
Samba's 67 part whord
Euro 67 is offline
PostPosted: Fri May 23, 2008 8:29 am    Post subject: What rockers to use for what cams Reply with quote
This is a basic chart for the basic cams and the rockers that need to be used with them.
68 Bug totaled one day will live again
69 Bug donor car
Many parts had, always need em!
millerje78 wrote:
I'm no expert but I'm guessing the spike during cold running has everything to do with the roofing tar(20-50) in the crankcase.
bill may wrote:
...i could be wrong as i have only been driving air cooled beetles since august 1965.
APPLEGREENVW
APPLEGREENVW is offline
PostPosted: Sat Feb 02, 2019 8:50 pm    Post subject: Re: What rockers to use for what cams Reply with quote
Parts for sale https://www.thesamba.com/vw/classifieds/search.php?username=APPLEGREENVW
02/76 Beetle sedan
View user's profile Send private message Send e-mail YouTube Gallery Classifieds Feedback
bugguy1967
bugguy1967 is offline
PostPosted: Sun Feb 03, 2019 8:33 am    Post subject: Re: What rockers to use for what cams Reply with quote
This is common-knowledge, and can easily be found wwhen searching for a cam.
"A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine"
mark tucker
mark tucker is offline
PostPosted: Sun Feb 03, 2019 9:41 am    Post subject: Re: What rockers to use for what cams Reply with quote
I use whatever rockers I want to use.but the charts do make it eazy for bubba to see whats what and that he ordered the rong cam...again...but it wasent his fault the sales man sent the rong one just like those dam dowel pins that the salsman effed up the main bearings with.....he also sent the rong bearings since they no longer fit..... yes many cams are listed for specific cams as guidelines so you sorta know whats what. ratio rockers dont just affect the lift they also change the @ valve duration/lift rate the engine sees.the cam shaft does not know what rocker arms it is operating at the other end of the pushrod stick thingy's. so if your clueless use the guides....and if your a exspurt....use the guides... if you know what your doing then you know what to do.and remember just because You think you know what you are doing... dosent mean that you know what you are doing.....and just because there is a group of guy that say on "thats" junk or oh that wont work or oh that's just fine....or oh only the oe shit is good....just confirms. morons congregate in groups.and pass along their clueless fodder.
ac509
ac509 is offline
PostPosted: Sun Feb 03, 2019 9:50 am    Post subject: Re: What rockers to use for what cams Reply with quote
mark tucker wrote:
I use whatever rockers I want to use.but the charts do make it eazy for bubba ... ....the cam shaft does not know what rocker arms it is operating at the other end of the pushrod stick thingy's. so if your clueless use the guides....and if your a exspurt....use the guides...
that's good advice and much, much better than what we usually get around here.
Dumber people are doing harder things everyday.
No one questions a 73' Volkswagen?
I have a '73 Volkswagen and it is nowhere near 73' long!
Dan Ruddock
Dan Ruddock is offline
PostPosted: Sun Feb 03, 2019 10:44 am    Post subject: Re: What rockers to use for what cams Reply with quote
I do not follow or recommend those charts for every combo.
Dan
