HELP: Need wiring diagram for MotoMeter Tach
1970 vw bug
1970 vw bug is offline
PostPosted: Sat May 31, 2008 3:45 pm    Post subject: HELP: Need wiring diagram for MotoMeter Tach Reply with quote
I scored a Motor Meter Tach @ the Sacramento Bug O Rama swap meet. It had no instructions. 10,000 RPM sweep w/ fixable RED LINE indicator. Marked on back with a "V" and "DJ 121". Terminals "Z", "12", "6", and an un marked terminal w/ a black wire attached to the body (Ground?). I do not want to hook this TACH up in-correctly as it will probably harm it. Does any one have a old diagram for a MotionMeter Tach????
Dale M.
Dale M. is offline
PostPosted: Sat May 31, 2008 5:33 pm    Post subject: Reply with quote
Exactly what is it......
You have mentioned...
Motometer
Motor Meter
Motion Meter
GOOGLE doesn't return much other that a manufacturer in Taiwan.
Dale
1970 vw bug
PostPosted: Sat May 31, 2008 8:59 pm    Post subject: Reply with quote
It is actually spelled MotorMeter. It is a German Tachometer w/ a Black Face, Orange Sweep Hand, Orange/Red "Red Line" set hand, tin body, silver painted bezel. It came w/ a Late Model "Left" Side Gauge panel w/ a oil pressure and Ampmeter both VDO's.
Dale M.
Dale M. is offline
PostPosted: Sun Jun 01, 2008 1:15 pm    Post subject: Reply with quote
This is as close as I can come.....
www.motormeter.com.tw/
And site seems to be down at this time...
Dale
Randy in Maine
Randy in Maine is offline
PostPosted: Sun Jun 01, 2008 1:45 pm    Post subject: Reply with quote
Go over here an see if you can find something similar (they all hook up pretty much the same anyway).
http://www.egauges.com/Instruct.asp
