Hose from reservoir pipe to master cylinder
funbus
funbus is offline
PostPosted: Mon Jun 02, 2008 7:27 am    Post subject: Hose from reservoir pipe to master cylinder Reply with quote
Have a 68 Westy and I'm looking to replace the hose between the steel tube (that runs from the dash reservoir) and the master cylinder. Merchants list 7mmID rubber hose... the hunk I removed measures more like 11-12mm. Am I missing something? NO WAY 7mm can stretch that far. Found a thread or 2 but looks like nobody has a proper replacement hose available in this size? Heard transmission cooler hose is good for brake fluid, but not finding it in 7/16 either. Any new ideas since earlier threads? Even be willing to buy a roll if I had to and resell what I don't need cheap here on the Samba. Thanks!
Chris
Blaubus
Blaubus is offline
PostPosted: Mon Jun 02, 2008 9:58 am    Post subject: Reply with quote
this reminds me of the 78 FI system, which requires 11mm fuel hose between pump and filter. i did find 7/16 fuel hose nearby, but i really dont know if fuel hose handles brake fluid. you could consider changing your resevoir to the 71 style behind the seat. that hose is easy to find. it plastic and for all i know might be 11mm. the 71 plastic hose uses a rubber sleeve between it and the snout. the sleeve can be bought thru wolfsburgwest.com
Alan Brase
Alan Brase is offline
PostPosted: Mon Jun 02, 2008 10:19 am    Post subject: Reply with quote
I think there are actually rubber sleeves in each end where the tube connects to the reservoirs. I've bought some from the dealer within the last 5 years. They might still have them. But I can't answer your main question.
al
Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home
Rocknrod
Rocknrod is offline
PostPosted: Mon Jun 02, 2008 11:17 am    Post subject: Reply with quote
The rubber sleeves are still available from the dealer. They are just 8 bucks a piece! I lost the note with the part number on it around after calling the dealer. (Grin)
A fellow I know has used hardware store clear vinyl for a few years... haven't decided if I'll go that path or not. The thicker hose means not much of a grommit going through the body.
1971 Westfalia with a high top.
http://71vwbus.blogspot.com/ - Pictures and words... Oh My!
Blaubus
Blaubus is offline
PostPosted: Mon Jun 02, 2008 1:38 pm    Post subject: Reply with quote
wolfsburgwest wants 4 each
Karl
Karl is offline
PostPosted: Mon Jun 02, 2008 3:38 pm    Post subject: Re: Hose from reservoir pipe to master cylinder Reply with quote
Chris
?? There is no hose on the metal pipe.
If you have a hose, someone CUT the pipe.
The upper with the pipe looks like this:
The upper fittings;
Here is one of MANY threads on the 68 only set-up: http://www.thesamba.com/vw/forum/viewtopic.php?t=283369&highlight=
karmann57
karmann57 is offline
PostPosted: Tue Jun 03, 2008 5:29 am    Post subject: Re: Hose from reservoir pipe to master cylinder Reply with quote
Chris
I had the same hose running from the metal line to the master on my '68, it was blue cloth braided line but definitely not 7mm as you have found. I managed to find some silicone hose that was rated for brake fluid but it was not a metric size and didn't fit very well I just replaced it with the later upper reservoir and plastic hose.
Crappy pic, but you can see the hose here -
Shane
View user's profile Send private message Send e-mail Twitter Gallery Classifieds Feedback
Karl
Karl is offline
PostPosted: Tue Jun 03, 2008 10:18 am    Post subject: Re: Hose from reservoir pipe to master cylinder Reply with quote
karmann57 wrote:
Chris
Shane
Wrong clamp!
That hose was part number 311 611 521. NLA many years ago......
Basilbomb
Basilbomb is offline
PostPosted: Wed Jun 04, 2008 2:28 pm    Post subject: Reply with quote
welcome to the wonderful world of 68 - bus twilight zone. i ran into the same problem with mine - still haven't solved it to my satisfaction.
funbus
funbus is offline
PostPosted: Sun Jun 08, 2008 6:29 am    Post subject: Anyone try this part? Reply with quote
CIP has a hose piece 10mmID x5.5" for 73-79 busses or so they say. Anyone try that yet? Sounds like just the ticket... mine measured a bit over 11mm ID but not sure if it stretched/aged that way.
funbus
funbus is offline
PostPosted: Sun Jun 15, 2008 4:23 am    Post subject: Case Closed Reply with quote
Got the brake hose part from CIP, thier PN VWC-211-601-805-F. Turns out to be an actual VW part from Brazil, VW PN 211-611-801 7. Diameter was good at ~10mm ID but at 5.5" long it was about 1/2" short. (probably why they were advertised for 73-79, not my 1968. Bought 2, cut about an 1.5" off the steel line to use as splice and clamped everything up nicely. Only down side was the price at $7.95 ea. Stings a little, but I'm back on the road without worries. Thanks for everyone's help.
porschpow
porschpow is offline
PostPosted: Tue Jun 24, 2008 6:19 pm    Post subject: Reply with quote
I have a 1973 VW Bus. I got a new master cylinder. However, I am getting furious that after installing it, it leaks. After careful looking, I found out that the hose that goes between the resevoir in the cabin and the resevoir on top of the master cylinder leaks. However, I changed the clamp on the end of the hose that goes to the master cylinder with a hose clamps. IT STILL LEAKS!!!! Should I change the hose, I am at a loss and already lost my patience!
HELP!!!!!!!!!!!!!!!!!
-1973 Volkswagen Bus Westy (Weekender)
1.8 liter from 1.7(original)
-2011 Subaru Outback
-1986 Honda Magna
porschpow
PostPosted: Tue Jun 24, 2008 7:43 pm    Post subject: Reply with quote
What is this sleeve or gromet everybody is talking about between the tube and reservoirs?/??
-1986 Honda Magna
Karl
Karl is offline
PostPosted: Tue Jun 24, 2008 10:12 pm    Post subject: Reply with quote
#59 here:
Part number 211 611 833 C
Available from your local VW dealer and most on-line suppliers:
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211611833C
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D211%2D611%2D833%2DC
http://www.busdepot.com/details.jsp?partnumber=211611833C
