hendrix Samba Member
Posted: Sun Jun 08, 2008 4:23 pm Post subject: 356 in a 65 bus |
Anyone fit a 356 engine and gearbox in 65 bus.? |
LittleThunder Samba Member
Posted: Sun Jun 08, 2008 4:37 pm Post subject: |
Go to search on the toolbar at the top of the page. Type "Porsche engine in bus" in the subject, on search options check search title only. Lots of discussions on this one. Good luck in your search. |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10800 Location: the past
Posted: Sun Jun 08, 2008 4:47 pm Post subject: Re: 356 in a 65 bus |
hendrix wrote: |
sure. if you take the seats out, that stuff fits easily in the back. |
VWAdam Samba Member
Joined: February 14, 2002 Posts: 3350 Location: Birmingham, Alabama
Posted: Sun Jun 08, 2008 5:02 pm Post subject: Re: 356 in a 65 bus |
hazetguy wrote: |
hendrix wrote: |
Best response ever. _________________ All he needed was a wheel in his hand and four on the road.
'59 Euro Beetle ragtop
'63 Standard Microbus
Come to my show! www.volksjam.com
Looking for badge/sticker/frame from Western Motors in Great Falls, Montana |
sub-hatchtim Samba Member
Joined: September 19, 2006 Posts: 2670 Location: Phoenix AZ
Posted: Sun Jun 08, 2008 9:23 pm Post subject: |
a 356 is a super 90 engine it wil fit no problem there is a guy in my town named t-lo with a uper 90 in his 66 panel |
quartermilecamel Samba Member
Posted: Sun Jun 08, 2008 9:28 pm Post subject: |
just curious, is a 356 more powerful than a 1600Dual Port? When you say it bolts right on, what exacty is involved. Just because it bolts right onto the transmission doesnt mean there arent shitloads of sheetmetal mods to be done. |
Posted: Sun Jun 08, 2008 11:02 pm Post subject: |
there shouldnt be any mods needed they are a 4 cylinder
this is a 356 super 90 engine
http://www.thesamba.com/vw/classifieds/detail.php?id=620412
The type 616/7 engine had modified cylinder heads with larger, less restrictive ports and an inlet valve diameter size of 40 mm. They used Solex 40 PII-4 carburetors like those on the 1500 Carrera 4-cam. These changes, plus an increased compression ratio to 9.0:1 and a redesigned muffler resulted in an output of 90 hp at 5500 rpm (with the tachometer redline changed to that figure). In addition, the Super 90 model came standard with Koni sport shocks, slightly larger 5.90 - 15 tires (instead of 5.60), 23 mm rear torsion bars (not 24.1 mm, Conradt makes an error on the size, see below) and the now infamous compensating spring at the rear.
more info here
http://www.356registry.org/Tech/identifying_super90.html |
Simon uk Samba Member
Posted: Sun Jun 08, 2008 11:22 pm Post subject: |
quartermilecamel wrote: |
there shouldnt be much alteration to the engine bay metal, but you may need to do some work on the porsche tinwear. |
Alan Brase Samba Member
Joined: March 28, 2004 Posts: 4570 Location: Cedar Falls, Iowa
Posted: Sun Jun 08, 2008 11:24 pm Post subject: |
Yes, a 356B super 90 or 356SC have about 95-100 hp compared to a 1600 dual port engine at 57 hp. They make it at a much higher rpm than the VW. The 356 car is a lot lighter and both the power curve and the transmission ratios are made to give good performance to a light car that will go 110mph. Not at all like your bus.
Furthermore, the 356 engine is an evolved 36hp, not an evolved 40hp like the 1600VW engine. The 356 crank, rods, and cylinder spacing are all smaller than the VW's. In the 356, these engines last a good long time. Even in the 912, this engine is working a lot harder and they fail a lot sooner.
So, what I'm saying is, the 356 engine would not work well in a VW bus, nor would it last a long time. And they are expensive to fix. Some parts are getting very hard to find.
Just put it up for sale, it's worth a fair amount if it is in good shape. Sell it on the Samba classifieds.
Al _________________ Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home |
Posted: Sun Jun 08, 2008 11:25 pm Post subject: |
now I would guess 356 porsche engines well just the name says it.....expensive? |
Posted: Sun Jun 08, 2008 11:35 pm Post subject: |
the guy in my town with th s90 in his panel has been running it for at least 15 years but for what its worth build a 1915 with dual carbs youll be mutch happier |
lurkinstock Samba Member
Joined: September 04, 2006 Posts: 416 Location: n. ga.
Posted: Mon Jun 09, 2008 8:22 am Post subject: |
I bought my single-cab from Rick at Rusty Tubs in Atlanta. They deal pretty much exclusively with 356's and old porshe's. Rick bought the scab in missouri to use as a shop truck. They were trying to sell it with a S-90 motor in it. I told them I would buy it without the motor, because I already had a 1600sp in the garage waiting for something to throw it in. I figured if the S-90 motor went out I would be screwed.The price difference was 2,500.00 I think I did the right thing  _________________ " Southern Comfort Vintage Volks "
**The Grand Ole Dubs of the South**
52 split
59 single cab |
mpribanic Samba Member
Joined: October 25, 2004 Posts: 3177 Location: Neptune Beach, Florida
Posted: Mon Jun 09, 2008 4:23 pm Post subject: |
A couple of years ago, trying to get my single cab to Bulli Brigade, I tried stuffing my 356 engine in the '58 single cab. I think the exhaust hit & would need to be modified to fit. I can't remember if the carbs hit as well. Something wasn't right.... _________________ Call your Cunado's:
https://vimeo.com/67661950 |
clnvwe2 Samba Member
Joined: April 15, 2006 Posts: 881 Location: BBQ grill
Posted: Mon Jun 09, 2008 5:15 pm Post subject: |
mpribanic wrote: |
A couple of years ago, trying to get my single cab to Bulli Brigade, I tried stuffing my 356 engine in the '58 single cab. I think the exhaust hit & would need to be modified to fit. I can't remember if the carbs hit as well. Something wasn't right.... |
Mark, what motor do have in it now?  _________________ "Keep your horn on"
Instagram : Flatkool
WTB- The Brundage Motors Plate frame that Merrpie Pribanic's looking for. |
Posted: Mon Jun 09, 2008 5:17 pm Post subject: |
clnvwe2 wrote: |
mpribanic wrote: |
Mark, what motor do have in it now?  |
a VW 1600cc... Why do you ask? _________________ Call your Cunado's:
steve mighetto Samba Member
Joined: March 16, 2004 Posts: 78 Location: Berkeley, CA
Posted: Mon Jun 09, 2008 7:57 pm Post subject: |
I worked in an independent garage back in the late '70s and we had a customer put a 356 engine in his bus. He left the rear bumper and apron off. He may have bent the sheet metal in the engine compartment a bit. It was a real LB (low budget) job.
This customer was friends with the shop owner and brought the bus in to discuss what else to do. His reason for swapping in the motor was kind of unique. He had a peanut butter and chocolate situation with a bus and a 356 he couldn't drive. He had a DUI in his Porsche and had lost his license. He convinced a judge he needed his license to work and said his bus was his work vehicle. I’m pretty sure the guy was a “Trust Fund” kid and never worked a day in his life; not that that would be a bad thing, just totally inconsistent with what he told a judge.
I drove the bus. It was fun but more in a scary “Mr. Toad’s Wild Ride” kind of way. The bus was a beater with lots of play in the steering and bad brakes. The 356 muffler was cracked and noisy. It had been damaged in the "DUI spinout". First gear was next to useless; it was over in a flash. The bus owner recommended starting in second gear. Starting in second required slipping the clutch but worked OK. A motor with more torque would be much better.
My boss’s recommendation was to fix the exhaust, steering and brakes. And then put a rev limiter on the motor; “The motor is worth more than this bus so don’t blow it up”. The guy liked the rev limiter idea and the boss put one in. He skipped the rest of the recommendations.
I could hear the limiter kicking in as he drove off. He drove off with the engine cover flapping, three inches of play in the steering, crappy brakes, a loud exhaust, and the engine cutting out before each shift. You could hear him for miles.
I was in my 20’s and thought it was pretty cool.
BTW – the guy stayed sober and ended up swapping the bus engine back in after getting cited for the noisy exhaust. He didn’t want that information to get back to the judge.
Last edited by steve mighetto on Mon Jun 09, 2008 11:19 pm; edited 1 time in total |
Mark Henry Samba Member
Joined: November 24, 2005 Posts: 251 Location: Port Hope, ON, Canada
Posted: Mon Jun 09, 2008 8:28 pm Post subject: |
Why???
I can (and did) build a more powerful engine out of a T1.
A rebuild would cost you big time. _________________ '74 914, back on jackstands for a 3.0/6
'67 Bus 2007cc, Berg engine
'67 EMPI GTV bug w/ 102mm Nickies, massIVe bottom end, SDS FI, 2.6L T4 monster in the works |
Posted: Tue Jun 10, 2008 1:29 am Post subject: |
Mark Henry wrote: |
Why???
A rebuild would cost you big time. |
Right. back in the 50's and 60's a Porsche engine was the hot ticket in a bug or bus. Then the type 1 hot rod science got about 30 years experience. Now there is no point. You can build a better and stronger engine cheaper just using type 1 stuff.
Using a 356 engine in a bus is just a waste of a 356 engine.
Vanagons:
malachai Samba Member
Joined: August 02, 2004 Posts: 650 Location: Großbritannien
Posted: Tue Jun 10, 2008 1:59 am Post subject: |
if Hendrix is the same young boy who was known as Hendrixmaster on VZI (and then banned) then it doesn't really matter how well a 356 engine goes into a bus, or even a food mixer for that matter. If it is the same person they don't even own a bus, I don't think they can even drive, but he does love to ask stupid questions.
If its not the same person then sorry, carry on. _________________ http://www.facebook.com/groups/175509642524184/ |
Posted: Tue Jun 10, 2008 12:47 pm Post subject: |
[quote="malachai"]if Hendrix is the same young boy who was known as Hendrixmaster on VZI (and then banned) then it doesn't really matter how well a 356 engine goes into a bus, or even a food mixer for that matter. If it is the same person they don't even own a bus, I don't think they can even drive, but he does love to ask stupid questions.
If its not the same person then sorry, carry on.[/quote]
No its not henrixmaster . just curious and new on the scene , thanks for the feed back. |
