CHT vs Oil Temp
Amplus
Amplus is offline
PostPosted: Tue Jun 10, 2008 2:47 pm    Post subject: CHT vs Oil Temp Reply with quote
Is there a need for monitoring Oil Temps if you are already watching CHT? I've got a LM1 with Aux Box and it comes with a thermo couple for monitoring either CHT or EGT.
I guess my question is does oil temp tell a different story than cylinder head temp or are they both just giving you a feel to if your engine is overheating? Is one a better indicator or more accurate?
I plan on monitoring AFR, #3 CHT, Oil pressure, throttle position and rpm with the aux box. It is capable of recording one more 0-.5V signal.
Jimmy111
Jimmy111 is offline
PostPosted: Tue Jun 10, 2008 5:16 pm    Post subject: Reply with quote
They both mean different things. You are not overheating untill your oil is too hot. You can have 400degree head temps and 180 degree oil. This shows a fuel problem. You can have 350 head temp and 250 oil. This is a airflow or oil flow problem. Get it?
Eaallred
Eaallred is offline
PostPosted: Tue Jun 10, 2008 5:23 pm    Post subject: Reply with quote
I overheated my camper bus motor and killed the motor without getting oil temps over 180.
Get the heads hot, and it don't matter what the oil temp is/was, your day is done. Mine was, and it happened on my honeymoon trip to Yellowstone. Great memory for me and the wife to cherish for years to come. Gee, and I thought I was doing myself a favor installing a killer oil cooling system on that thing to save me any and all headaches.
IMHO, head temps are critical. As long as the oil temp doesn't get hotter than the oil itself can handle, then oil temps don't matter.
Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn.
Jimmy111
Jimmy111 is offline
PostPosted: Tue Jun 10, 2008 5:33 pm    Post subject: Reply with quote
Yes eric. But that is not the motor overheating. You had a problem with something else. Your oil will get scorching hot from flowing thru the heads when they are too hot. Unless you had a really huge amoung of oil cooling. Im kinda suprised that you did not notice that something was wrong. Was it a type 1 or type 4?
Eaallred
Eaallred is offline
PostPosted: Tue Jun 10, 2008 5:56 pm    Post subject: Reply with quote
Type 1, 1600. Mese oil cooler with fan. Thermostat to allow oil to the cooler at 170, thermostat to activate the fan at 190 (shut back off at 180). Oil temp sending unit in the pressure relief valve.
No bearing failures, in fact being a cheap/broke guy that I was, I just replaced the heads and cylinders and left the short block alone. Drove the bus for years after that as well. The cool oil kept the bearings happy, but the hot heads wounded themselves and cooked the P's and C's as well.
I didn't notice anything wrong until my oil light came on after I just topped off the oil. The blow-by was so bad it was pushing the oil out everywhere. 14 miles, stop, put a quart of oil in, then have the (new at that time) wife push the bus while I popped the clutch since she didn't know how to work the bus yet. Plugs were so fouled from the oil it couldn't start on it's own anymore.
She didn't divorce me after that for some reason. She probably should have, but glad she didn't. lol.
I stand by it. You can overheat the heads and kill the thing without the oil itself 'overheating'. I've done it myself.
Eric Allred
SkrapMetal
Samba Hornblaster
SkrapMetal is offline
PostPosted: Tue Jun 10, 2008 7:22 pm    Post subject: Reply with quote
I almost cooked my stock 1600 due to dirty fan shroud, dirty cylinder tin, dirty cylinders. While my heads reached 450F or so, my oil was about 190F. Run oil thats too thick with a huge pump, and your oil will probably get too hot while your head temps can remain normal. If oil and head temps are related, it's a very very distant relation. Sort of like a 5th cousin... or something.
oo9less since 2007
-72 Ghia-
zorrro
zorrro is offline
PostPosted: Tue Jun 10, 2008 11:30 pm    Post subject: Reply with quote
I think I saw this in some old Gene Berg literature. He did a discussion on his opinion of gauges. For the most part the quality of the automotive gauges and sending units is pretty poor compared to "real" test instrumentation and for this reason he didn't care for gauges. However this part of the discussion I remember so well I'll quote it. "If you want a gauge that's really worth something, get a cylinder head temperature gauge." The reasoning was that cylinder temperature changes can happen rapidly and allow you time to react before they come critical. Oil takes time to heat-up and time to cool down. It may too late to save an engine once you notice your oil is hot...........Z
I have a great deal of respect for the wealth of knowledge Gene Berg has contributed to air cooled VW performance and I apologize if I've misquoted the man. I do think I've correctly summarized the intent of the discussion.
'68 Fastback. 1776cc, W-100 cam, 34-ICT, balanced c/w crankshaft. 70mi round trip daily driven. Never restored.
1970 beetle. (WIP) new heater channels and various body sheet metal. Owned since I was 12, sold when I was 38 bought back when I was 46! Most likely on its way to be a street/class 11 machine…
Amplus
Amplus is offline
PostPosted: Wed Jun 11, 2008 7:22 am    Post subject: Reply with quote
This was the kind of thing I was wondering about. The two temps aren't as closely related as I thought so having both can be valuable. I already have all the equipment needed for the head temps. Need to look into a compatible oil temp sender now.
[email protected]
john@aircooled.net is offline
PostPosted: Wed Jun 11, 2008 8:38 am    Post subject: Reply with quote
FWIW, several years ago when Eric Allred was McGyvering on his Bus, he drove around for a while with NO OIL COOLER AT ALL (not even the stock one in the shroud). And it did not run hot oil temps unless he was over 50mph or so. Crazy.
He knows a lot about oil, oil temps, and cooling, so listen to him.
John
Aircooled.Net Inc.
It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net
Jimmy111
Jimmy111 is offline
PostPosted: Wed Jun 11, 2008 9:47 am    Post subject: Reply with quote
The cylinder head temp is mainly a factor of fuel load and mixture. The oil temp is a mainly a factor of bearing pressure and cylinder head temp. Cylinder temp contributes to this by the oil flow thru the head. On tests I did, the oilflow was much more important than the airllow when the motor was removed from the car. Many people who have had flaps and a thermostat in their shroud have seen that when the thermostat fails closed the car can still be driven around untill the oil gets too hot. This is a factor of the oil cooling the head.
The oil gains most of its heat thru the compression of the oil film thru the bearings. This heat rise of the oil can be as much as 80 degrees on a 1600 at a 45hp load at 3800 RPM.
Both are important. They just have different causes.
I dont know why eric fried his heads. Possibly the altitude change?
[email protected]
PostPosted: Wed Jun 11, 2008 10:49 am    Post subject: Reply with quote
Head frying can happen climbing the "hills" we have around here. The oil temp will be fine but CHT thru the roof.
I suspect he didn't have a CHT gauge. We've all been there, usually some blow up leads to an increase in our knowledge.
I consider oil temp to be proportional to RPM, CHT to load. You can free rev a motor on a stand with no load and overheat the oil if you want to prove this to yourself. Especially with thick ass oil and oversized pumps. Most people just stare at me when I tell them their oil temps would drop if they'd use a thinner oil. OK, don't believe me? Use some Valvoline 60W and really cool it off. Rolling Eyes
John
Aircooled.Net Inc.
nikita
nikita is offline
PostPosted: Wed Jun 11, 2008 11:13 am    Post subject: Reply with quote
John, There you go again trying to inject facts and logic into a discussion.
Here is my take on this. CHT can change in seconds, where oil temps take several minutes to move significantly. Oil temp and pressure relates primarily to the bottom-end health of your engine where parts are pressure lubed, CHT and EGT the top end where combustion takes place. Ive repaired/replaced many valves and heads and never had to replace a crank in stock engines.
[email protected]
PostPosted: Wed Jun 11, 2008 11:24 am    Post subject: Reply with quote
I could be wrong but I think I heard that the Berg's cam break in machine gets oil temps around 170F, and that is with NO COMBUSTION, just the valvetrain!
John
Aircooled.Net Inc.
Jimmy111
Jimmy111 is offline
PostPosted: Wed Jun 11, 2008 12:00 pm    Post subject: Reply with quote
There are big hills around where I live. But I havent ever seen temps over 400.. The cylinders and heads are cooled mainly by the exhaust and incoming F/A mix. The blower is there mainly to provide circulation because it is in an enclosed space. The fan requires a lot of HP to overcone the pressure differances between the incomming negitive air pressure and the presurized area under the car. The freer flowing the exhaust and the higher the vaccum, the more cooling of the heads and cylinders that takes place.
I have 1915's and 2332's on mining equipment that is completly unshrouded. They run at about 400 CHT and they are jetted a little rich but I have little problems with them. I just use 72 plate oil coolers with fans and have little problems.
I always thought that VW should have designed a draw thru cooling system that would pull the air from Below the car and exhaust it out the back. Take advantage of the 2 psi or so under the car and reduce the energy load on the motor.
I know that busses are much more prone to overheating the heads. I had 2 busses and never had CHT guages so I couldnt tell you the temps... But I never fried the heads either.
Just my experiences and views. I really need to look into the overheating problems with busses.
John. I have a good study on bearing oil clearances and heat generation if you are interested in it. It is not VW but it is good.
Eaallred
Eaallred is offline
PostPosted: Wed Jun 11, 2008 3:53 pm    Post subject: Reply with quote
Here's my take on it from what i've experienced.
Head temps are related to engine load. That's about it.
Oil temps are slightly effected by head temps, but the majority seems to be effected by engine rpms. Heavy valvetrain/springs seems to increase this heat over light stock components. My theory there is the flat tappet cam and lifter setup has the oil taking a lot of the friction/heat abuse. The more load on this (via lifter to cam pressure, and an increase in rpms) the higher the oil temps get.
Oh yea, John, the 'magic' number was about 53mph. As long as I kept it under that speed, the oil temps stayed under 220 in that 90 degree weather.
One more bit of useless blabbering from me. My drag motor running E85 runs cool as a cucumber on the cylinder heads. But just idling (to get the head temps up before I run) with those K-800 springs and big heavy stainless valves, my oil temp will get right up close to 200 degrees even before I make a pass down the track. When I ran gasoline, the heads warmed up so fast oil temp was never an issue, lol.
Eric Allred
Jake Raby
Jake Raby is offline
PostPosted: Wed Jun 11, 2008 7:27 pm    Post subject: Reply with quote
I could not agree more, and of course I have the data that illustrates this clearly.
Absolutely. Internal bearing clearances and surface finishes do matter, but RPM= Friction and friction= oil temp.
Yes absolutely and if you saw the differences in oil temp that I saw the first time I did a back to back test with a flat tappet Vs roller cammed engine with the same CR, deck height and roughly the same lobe area and cam characteristics you'd really see the impacts this has. The roller engine had oil temps that were 30 degrees lower and WOULD NOT ever climb to the level of the flat tappet engine, even when revved higher for longer amounts of time under more load with higher head and cylinder temps.
All it takes is driving any aircooled car with a full compliment of gauges to see this, adding a 28 channel data logger helps you see it much faster and more clear...
And FWIW any gauge is better than no gauge, or a dipstick wired with some voodoo light that makes you wonder if your oil is hot, or if it has no pressure.. I never understood that: Gauges are bad, but its OK to confuse the hell out of the driver while worrying them half to death while not offering any clue as to why that idiot light is lit up.
If all else fails, just confuse the hell out out the driver and make them pull over... What Rocket Science!
Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell"
1432
1432 is offline
PostPosted: Thu Jun 12, 2008 6:46 am    Post subject: Reply with quote
If cylinder head / cylinder wall temps have no little or no relationship to oil temps, think about why our basic water cooled cars need no added oil cooler to maintain oil temps no higher and usually lower than their corresponding water based coolants.
Jake Raby
PostPosted: Thu Jun 12, 2008 6:52 am    Post subject: Reply with quote
The modern Porsche 986/987 and 996/997 engines do have a small external oil cooler fitted to them from the factory. Some other more modern engines also do, especially those that are use in sports cars that will see higher RPM. The Boxster and Cayman engines have this fitted right to the engine case and only air passes over it, it never comes into contact with the water used for engine cooling.
Water is also a much more stable cooling agent that has less spikes in temperature and takes longer to respond to these spikes than any air cooled engine.
People trying to compare "air to Water" and build from that are those who historically have the least success with an aircooled engine performance engine..
Jake Raby
1432
1432 is offline
PostPosted: Thu Jun 12, 2008 7:16 am    Post subject: Reply with quote
Jake,
I guess you just don't see the basic relationship I'm pointing out. the one that's been relied on for over 100years by the automobile manufacturers
Jimmy111
Jimmy111 is offline
PostPosted: Thu Jun 12, 2008 7:53 am    Post subject: Reply with quote
Oil IS cooled in water cooled cars. You might not think that there is a oil cooler but there is. It is built right into the castings of the Block. The oil journals pass thru the water jackets and that is where you get your cooling. Most water cooled cars run at much hotter oil temps tht VW's. Many are in the 220- 230 degree range. In VW's it is important to keep the oil temp lower than what is optimal due the the AS-41 case.
