Narrowed Beam- Major understeer...???
volksmike
volksmike is offline
PostPosted: Fri Jun 13, 2008 10:28 pm    Post subject: Narrowed Beam- Major understeer...??? Reply with quote
I have a 6" KCW beam uner my fastback and I have real scary understeer. The tires are 135's. I have the "no shock" bounce/stiffness and the bumpsteer from the weird angle of the tierods, this I expected. But the understeer is freeky. When I turn, the outside tire (in relation to the turn) scrubs.
Is this normal for the narrowed beam-small tire setup. Does the Akerman effect really make that big a difference. I plan on re-doing the beam to make room for shocks, and flipping the tierods to reduce the bumpsteer.
Any thoughts?
JSMskater
Samba Grease Gorilla
JSMskater is offline
PostPosted: Fri Jun 13, 2008 10:40 pm    Post subject: Reply with quote
go back to stock.
71 Squareback-FI -- 73 Bay (subaru powered)
TOOB Member #3
I make D-jet FI connectors
Tram
Samba Socialist
Tram is offline
PostPosted: Fri Jun 13, 2008 11:14 pm    Post subject: Re: Narrowed Beam- Major understeer...??? Reply with quote
Any thoughts?
Either it's a characteristic of the narrowed radius, or the caster got seriously screwed up when the beam was installed. I haven't seen people complaining of this on other narrowed beams, so I'm thinking maybe you have another problem.
You can lower a stock T3 beam very easily.
Bryan67 wrote:
Those who can- do.
Those who can't? Subaru.
Ghoti
Ghoti is offline
PostPosted: Sat Jun 14, 2008 12:03 am    Post subject: Re: Narrowed Beam- Major understeer...??? Reply with quote
Any thoughts?
WHAT??? Shocked The VW purist of purists... Wink
OH SNAP!
Slowlow Premium Member
Slowlow is offline
PostPosted: Sat Jun 14, 2008 12:22 am    Post subject: Reply with quote
You would most likely get better responce in a beetle forum, where people have more experience with narrowed beams.
Sounds like some sort of alignment issue to me.... a 6" beam shouldnt have that extreme of an Akerman angle.
Flipped tie-rods are a must to cancel out the bumpsteer.
• Metal Fab & Quality Suspensions, Type I-II-III. Since 2004 •
Tram
Samba Socialist
Tram is offline
PostPosted: Sat Jun 14, 2008 10:18 am    Post subject: Re: Narrowed Beam- Major understeer...??? Reply with quote
Ghoti wrote:
Any thoughts?
I didn't say I approve of it. I said that original T3 beams could be lowered easily- which means that they can be brought back up to stock height easily, too. Razz
Are we gonna make a T3 guy out of you, Ghoti? Very Happy See my sig line.
Bryan67 wrote:
Those who can- do.
Ghoti
Ghoti is offline
PostPosted: Sat Jun 14, 2008 10:38 am    Post subject: Reply with quote
I dunno....really like my Bug. Laughing I know you're not liking it about now.
I could add a T3 later! T will be needing a ride in a few years.
OH SNAP!
volksmike
PostPosted: Sat Jun 14, 2008 11:16 am    Post subject: Reply with quote
Beam was in there when I got the car...
I'm trying to fix PO F-up.
The bottom of the frame head was cut away for ground clearence and so a stock beam won't go back in safely.
The way it was when I got it had the T1 beam held in place with the worn out rubber grommets and clamps from the stock set-up. The WHOLE beam flopped around on the frame head, I fixed that by welding the clamps to the beam and bolting the beam straight to the frame head. Aside from welding on a new frame head, I'm sort of stuck with the T1.
There are VERY few T-3's around here so there aren't parts cars...
Tram
Samba Socialist
Tram is offline
PostPosted: Sat Jun 14, 2008 11:23 am    Post subject: Reply with quote
I can fix you up with a good straight frame head if you need one. I was thinking "bent frame head" from the get- go. Sounds like whoever installed that beam wasn't exactly dainty about it.
Bryan67 wrote:
Those who can- do.
crede999
crede999 is offline
PostPosted: Sat Jun 14, 2008 11:43 am    Post subject: Reply with quote
hi hope this helps heres some pics of my 6inch narrow beam ,it has drop spindels aswell , you maybe able to zoom in to see closer the set up i have , i did have rub issues til i fitted steering stops on th beam , i dont get understeer , and i have 125s on 4 inch wheels on the front, anyhow hope the pics help,
best regards
chris
Russ Wolfe
Russ Wolfe is offline
PostPosted: Sat Jun 14, 2008 11:46 am    Post subject: Reply with quote
And if you are closer to the mid-west, I have a good frame head.
Gary: OK. Ima poop.
volksmike
PostPosted: Sat Jun 14, 2008 10:27 pm    Post subject: Reply with quote
crede999--- Nice pan Smile
I will have to look at the alingement I guess. There must be something hokey going on there. It has dropped spindles as well, so it rubs on the doubler panel on the inner fenders and the fuel filler piping also.
thanks
blankmange
Type 3 Darksider
blankmange is offline
PostPosted: Sun Jun 15, 2008 4:37 am    Post subject: Reply with quote
thanks
I would be looking at doing what I could to reconstruct the entire front end if this was going on....
póg mo thóin
Certified DHS Technician
Samba Member # 24517
lowindO
lowindO is offline
PostPosted: Thu Jun 19, 2008 4:12 pm    Post subject: Reply with quote
thanks
I would bet that the rubbing on the double panel on the inner fenders combined with the angle of the tie rods is whats doing it. Also if your alignment isn't straight you will be all over the place.
I had to cut out that panel on the inner fenders for mine and flip the tie rods. Mine doesn't ride as good as it did with a lowered type 3 beam but it rides better than my old slammed beetle ever did.
Mine rubs only on bumps while turning on my fuel filler tho, what year do you have?
Is this the Nasty Fasty?
Why don't you have a narrowed beam yet?
My Squareback's Video
JSMskater
PostPosted: Thu Jun 19, 2008 4:35 pm    Post subject: Reply with quote
lowindO wrote:
thanks
NOOOOOO the antichrist of t3's! Don't let it have resurfaced!
TOOB Member #3
Mr. Bubblehead
El Chupa Nibre
Mr. Bubblehead is offline
PostPosted: Thu Jun 19, 2008 7:15 pm    Post subject: Re: Narrowed Beam- Major understeer...??? Reply with quote
Any thoughts?
Assuming the alignment (camber angle and toe-in) is correct, an educated guess tells me the caster angle is probably wrong. With the small footprint of the tread width of 135 tires, you shouldn't notice the Akerman Effect, regardless of the narrow front track width. You could try shimming the lower beam tube and see if that helps. A simple geometry correction may greatly improve the vehicle's handling. Also, in regard to bump steer, no shocks on the front has way more effect than incorrect tie rod angle. While modern rack-and-pinion steering systems require a very precise tie-rod angle to reduce bump steer, the roller type steering that these VWs use is very forgiving. If you do decide that you need to flip the tie rods, flip the outers only (providing the tie rod ends have enough articulation, which they should, given that the vehicle is lowered).
BTW, it's been years since I've heard an "Akerman Effect" reference. Good job!
OGST
Samba Member #4862
VWporscheGT3
VWporscheGT3 is offline
PostPosted: Thu Jun 19, 2008 7:48 pm    Post subject: Reply with quote
i had this problem when i first got my fastback and had not a clue about handling characteristics and lowering.... i had 135's up front on rivies... lowering it didnt help it , correcting toe in didnt help it , adding weight to the front helped slightly but only made hard corners scary if i went in too fast. after new shocks (didnt help) and raising the front to a sane lowered level (didnt help either) i changed my tires . which were nankook 135 r-15's and changed them to stock 165 R15's again on riviera's and 1 click lowered in the front , all the understeer went away with just a little more meat touching the pavement. i lowered it again and the handling got even better , when i added stiffer shocks even better... but it was the 135's... it you corner hard like i do , and corner a little hot... your gonna want some more meat touching the ground... you have a type1 beam in your car but i would almost bet five bucks that its a lack of contact with the road... there are other tire options for more meat on the pavement just ask or look around. hope this made ANY sense...
-Trevor
69 Fasty
aveyinc
aveyinc is offline
PostPosted: Thu Jun 19, 2008 7:50 pm    Post subject: Reply with quote
JSMskater wrote:
lowindO wrote:
thanks
The Nasty is dead.
http://www.thesamba.com/vw/forum/viewtopic.php?t=2...p;start=40
Check grimace007 's sig line too.
GHOSTWAGENS!
WOMAN with short dirty nails!
RennyRB
Samba Textbook Gangsta
RennyRB is offline
PostPosted: Thu Jun 19, 2008 7:52 pm    Post subject: Reply with quote
I haven't got too much driving time in it yet, but my Square handles pretty well slammed on 3 notches in front and 2 in rear, on 155/60 up front and 195/60 in back. Just a suggestion for those running stock beams and wheels with good offset. If I were to do more serious driving I'd probably upgrade to 175/55-205/65 and maybe add a sway bar and camber compensator?
The point is, with my pretty skinny front tires, I don't have any grip or understeer problems, in fact my bug with 165s has far less grip, but thats another suspension design entirely.
1967 Squareback
lowindO
lowindO is offline
PostPosted: Fri Jun 20, 2008 2:09 pm    Post subject: Reply with quote
i am very happy with my 145/65s slightly wider and slightly lower profile than 135s.
i however don't recommend the 165/45s except maybe if your trying to squeeze every millimeter out of a slammed job and save your fenders. stock width and very low profile.
