Stocknazi Samba Member
Posted: Fri Jun 20, 2008 7:05 am Post subject: Mounting a late front sway bar on an early beam |
is it possible to use a front sway bar from a 64-67 beam on an 55-63 beam? _________________ WANTED:
Thomas Jefferson |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12570 Location: Over 2002 posts deleted!
Posted: Fri Jun 20, 2008 7:16 am Post subject: |
I don't know but can tell you it will be well worth the effort!
The Dormy's disc brake fatchick beam has that weak half inch bar on it. It broke on me once and after getting all squarely in an on-ramp, I went straight to the wrecking yard to get a replacement!
I wish I could get a thicker heavy duty one as it will make it more stable even!  _________________ Some people are so busy being clever they don't have time enough to be wise. |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Fri Jun 20, 2008 8:35 am Post subject: Re: front sway bar on early beam |
| StockNazi wrote: |
| is it possible to use a front sway bar from a 64-67 beam on an 55-63 beam? |
1966 and 1967 stock nazi. EMPI makes aftermarket ones. it cost me $29 for clamps from wolfsburg west (211 498 101 part number) i am going to mount it on my 1965 panel/camper. not sure about earlier beams tho'.. check EMPI catalog. _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
Posted: Fri Jun 20, 2008 4:14 pm Post subject: |
i was hoping this would be a bolt-on thing that i could use all the hardware from a spare stock swaybar i have. i'm suprised i have not seen the idea mentioned before, unless the beam mounting area on the beams is slightly different. i haven't really noticed a difference, but it's certiently possible. _________________ WANTED:
Thomas Jefferson |
Posted: Fri Jun 20, 2008 6:21 pm Post subject: |
my sway bar is a stock 66/67 one. i did not have the mounting clamps or anything. just the sway bar. now i have new clamps and can mount it on my 65. you may have to hold it up to 63 and older to see if trailing arms are same distance apart and same diameter. _________________ Admin note: Bill Passed away - July, 2017
www.sv2s.com
SBS #100
EverettB  Administrator
Joined: April 11, 2000 Posts: 71934 Location: Phoenix 602
quartermilecamel Samba Member
Posted: Sat Jun 21, 2008 1:15 am Post subject: |
| I would so love to have a stiffer front sway bar for my 69 front end. Hell I would love to have a rear sway. |
Lind Samba Member
Joined: November 06, 2000 Posts: 10273 Location: idaho
Posted: Sat Jun 21, 2008 11:24 am Post subject: |
I bolted a '67 sway bar onto my '61 front end. it bolts up fine.
the bar only touches the trailing arms, not the main part of the beam.
I actually pulled the sway bar off of a junk front end because someone had a wanted ad up for one. they never responded to my $75 price so I just installed it onto my bus. I am glad now that they didn't get back to me, because the sway bar really makes a noticeable difference in the handling of the bus around corners. I am planning on putting sway bars onto most of my buses now. _________________ .
Wanted:
Posted: Sat Jun 21, 2008 5:18 pm Post subject: |
that's awesome, thanks lind. i can tell a difference in my 66 with bar and my 61 w/o around the corners. _________________ WANTED:
Thomas Jefferson |
Posted: Sat Jun 28, 2008 12:50 pm Post subject: |
got the sway bar on my 61; there is a noticible improvement around the corners. kinda a bitch to get on and off, that's for sure. _________________ WANTED:
Thomas Jefferson |
kingodirtp3 Samba Member
Joined: December 07, 2007 Posts: 1062 Location: Monterey CA
Posted: Tue Nov 18, 2008 2:20 pm Post subject: |
| has anyone seen 4" narrowed sway bars? do i even need one since its narrowed 4 inches? |
RobzKombi Samba Member
Posted: Tue Nov 18, 2008 3:07 pm Post subject: |
| I don't think they make a sway bar for any narrowed beams, my beam is narrowed 4" and I still have noticeable body roll going around corners. I'm now getting a new beam (non narrowed) and hopefully a swaybar aswell. |
Riff Raff Shivering Sambian
Joined: October 25, 2004 Posts: 3097 Location: Alberta
Posted: Tue Nov 18, 2008 3:21 pm Post subject: |
| kingodirtp3 wrote: |
This has been discussed before if you want to do a search on the subject.
AFAIK, there are no narrowed sway bars.
It would not be a big deal to cut 4 " out of a sway bar and weld it back together. One would want to do a superior welding job on it though I think (root, fill, cap).
Although it is spring steel, the attributes of the spring steel would only be compromised in the heat affected region, so it should still work pretty well I would think.
There is also the feature of narrower bar so stiffer response, same effect as narrowing torsion leaves, but it should still work fine.
Someone needs to try this out and report back. _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
bigmau Samba Member
Posted: Fri Nov 21, 2008 1:42 pm Post subject: |
I didn't want to start a new thread so here it goes:
Can I make a stock baywindow swaybar fit on my 60 stock width beam? It seems like baywindow shit is easier to find in junkyards/classifieds. My beam has chunky lower control arms, if that might make it better or worse. thanks. |
Clara  Samba Member
Posted: Fri Nov 21, 2008 2:18 pm Post subject: |
split (regular and ambulance versions):
211 411 309 stabilizer 18mm dia.
271 411 309 stabilizer 16mm dia.
bay:
211 411 309 A
This is from parts list, I don't know the difference to look at them _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Culito 11010101
Joined: December 07, 2006 Posts: 5882 Location: Columbia Missourah
Posted: Fri Nov 21, 2008 7:40 pm Post subject: |
I'm assuming that the sway bar doesn't make much difference on a single cab because of the lower center of gravity? _________________ © CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
| johnnypan wrote: |
| ...dont pay no attention to Culito,he's a cornhole.. |
big bus mike Samba Member
Posted: Fri Nov 21, 2008 7:45 pm Post subject: |
So I've got a sway bar and a new rubber mounting kit, but I'm concerned about bolting it up. The buses I'm using for reference have little metal bands with pinch bolts holding the end of the swaybar onto the contol arm. The bay buses at the shop just use a bolt and a nut.
I'm assuming that I need these clamps to properly secure the swaybar, correct? Just using the rubber mounts seems like a bad idea to me... |
Clara  Samba Member
Posted: Fri Nov 21, 2008 10:29 pm Post subject: |
67 bus:
Dewayne  Samba Member
Joined: October 05, 2003 Posts: 334 Location: Oklahoma
Posted: Thu Jun 18, 2009 6:12 am Post subject: |
Just got a front sway bar and camber compensator from Empi after reading this thread...
My question is.. since my 64 DC didn't have a sway bar, I don't have the two clamps for the end of the bar. I'm not talking about the bushing and clamp, it's the pinch clamp on the very end. I looked on WW's site and they don't show them... any ideas where I can purchase a set? Or are they a 'salvage yard only' item... in which case I'm in BIG trouble....
Thanks!
Dewayne _________________ "My ex-wife had a hint of a beard and she looked like a manly-girl... that made no difference..."
Drive 'em if ya got 'em, and don't brag if you didn't do the work yourself...
'64 SO34
'60 SO23 |
westy@7000 Samba Member
Joined: July 06, 2005 Posts: 214 Location: Central Colorado
Posted: Thu Jun 18, 2009 6:52 am Post subject: |
| I got mine used from Bus Boys. |
