Using tweeters only as front speakers
lt1 kenobi
lt1 kenobi is offline
PostPosted: Thu Jun 19, 2008 12:19 pm    Post subject: Using tweeters only as front speakers Reply with quote
Ok I DONT want the kick panels. So please don't mention them as an option. I'm thinking about two one inch tweeters and using them as my front speakers to compliment my 6x9's and 10" sub in the rear... would this work? Do tweeters put out vocals???
kyle242gt
kyle242gt is offline
PostPosted: Thu Jun 19, 2008 12:29 pm    Post subject: Reply with quote
check your manufacturer's specs - the crossover frequencies are probably too high to make the tweets much use as front stage.
You could try using the components' crossovers and send highs to the tweets and the mid/bass to the 6x9.
Either way, you're not going to get great sound...
1967 Type 3 Fastback, gathering parts for resto mod - "Stay on Target!"
gone but not forgotten:
1964 Type 1, sunroof, 1600sp, 4" narrow, 2.5" trans raise, pan smacker
1972 Type 3 Squareback - never did much to it
lt1 kenobi
PostPosted: Thu Jun 19, 2008 12:30 pm    Post subject: Reply with quote
I'm just looking for a way to bring some vocals up front.. the sound doesn't have to be competition sound... just bring me some vocals up front.
clarkbre
clarkbre is offline
PostPosted: Thu Jun 19, 2008 12:33 pm    Post subject: Reply with quote
They would create some sound...very little though. Tweeters are used to produce very high range noises. The human ear can hear between about 20 to 20k hertz. The human voice is anywhere between 300 to 3000 hertz. Most tweeters start at around 3000 hertz and go up from there. The noise you would hear out of the tweeters would be static from the radio and chimes or symbols in the music. Personally, I wouldn't bother with the tweeters. It wouldn't sound right having the mid range to back them up.
As far as placement, see how 6x9's sound in the back. I ran only rear speakers in my bug for a long time and it sounded pretty good to me. you could always fit a 4" speaker in the stock location and modify the glove box door with a speaker grill insert. Just a thought.
andk5591
andk5591 is offline
PostPosted: Thu Jun 19, 2008 12:35 pm    Post subject: Reply with quote
Works great for me[/url]
D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
There's more, but not keeping them...
Kuncle
I am Kyle Deese
Kuncle is offline
PostPosted: Thu Jun 19, 2008 12:57 pm    Post subject: Reply with quote
[quote="andk5591"]
Works great for me[/url][/quote
Did you just continue the Partition where the bottom sinks in?
Ost Kuste.
andk5591
andk5591 is offline
PostPosted: Thu Jun 19, 2008 2:09 pm    Post subject: Reply with quote
This is an early cardboard template that I started with
You'll notice that I forgot the dimmer switch cut out Embarassed (this is for a 65). I used 1/2" plywood and drywall screwed it to the lower part of the bulkhead. I cut a couple braces for the upper portion that I glued in. Be careful of your speaker selection so that they aren't too deep to where the magnets hit the bulkhead (my 5 1/4" Alpines are VERY close - I put some stick on weatherstrip on the back of the magnet so that they wouldn't rattle against it. The space is pretty small, so your bass response is non existent even with fiberglass batting in the space. But, I get the bottom end from the rear speakers. The nice thing about the Alpines is that you can aim the tweeters, so I have plent of top and mids from these and don't impact leg room at all. [/img]
Chad1376
Chad1376 is offline
PostPosted: Thu Jun 19, 2008 2:55 pm    Post subject: Reply with quote
You'll need at least a 4" to get any decent vocals/mid. It's not ideal, but if you have door panels without map-pockets, you can mount them into the lower front corners and get two of the speaker screws into sheet metal. I've got some 6.5" Polks in that location and component tweeters just below the wing vents. It's sounds OK, although the panels are a little flimsy and muddy up the sound. Dynamat would help this a little.
My never ending 1302 Autocross Project:
http://www.shoptalkforums.com/viewtopic.php?f=51&a...02b8f83f22
67 Shane
67 Shane is offline
PostPosted: Thu Jun 19, 2008 3:52 pm    Post subject: Reply with quote
So I think by now you realize that tweeter only isnt a good idea. Everyone here though has posted some solid ideas. 6.5" speakers with an intergrated tweeter would sound good with your setup.
-OstKüste-
67 Euro Type 1.
67 SO-42 Westfalia
sano66
sano66 is offline
PostPosted: Thu Jun 19, 2008 4:33 pm    Post subject: Re: Using tweeters only as front speakers Reply with quote
Tweeters are for high frequencies, just like subs are for low frequencies. They are only there to ENHANCE the tonal range that you can hear. Tweeters are small for a reason, same as subs being larger for a reason. With the cone being so small, it becomes more rigid and only lets out the highest of frequencies. I have 6x9s angled a little forwards in my package tray and it sounds great, i have no need for speakers in the front (mainly because i think they're ugly up front). I say just use the 6x9s.
Traver
Traver is offline
PostPosted: Fri Jun 20, 2008 2:21 am    Post subject: Reply with quote
Why would you not want to use kick panels? I've used them on several bugs including my current ride and been very happy with them.
bill may
bill may is offline
PostPosted: Fri Jun 20, 2008 6:04 am    Post subject: Reply with quote
if you run only tweeters up front you will need to buy "tip toe thru the tulips" sung by tiny tim. it will rock the tweeters. Shocked
Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617
sano66
sano66 is offline
PostPosted: Fri Jun 20, 2008 3:53 pm    Post subject: Reply with quote
hahaha Cool
Maimas13
Maimas13 is offline
PostPosted: Fri Jun 20, 2008 7:25 pm    Post subject: Reply with quote
Oh well if you want to bring vocals up front you will need a midrange speaker not a tweeter (standard 4,5.25, or 6.25 speaker), as the tweeter really only makes the high-pitched instrumental noises like symbols and such. Having tweetrers only would really f-up the sound, most of it would be coming from the rear but the symbols would miraculously come from the front.
Plus when you run tweeters you will need a crossover so the tweeter doesnt waste energy trying to reproduce the mid and bass notes, making it sound like crap.
My vote would be the buy a set of component speakers (seperate tweeters, midrang, and crossover) and mount them either in the doors or (I know you said you wouldnt) kick panels.
What do you have against those kick panels anyway? Ease of install? Cheap price? Not cutting holes in the car/door panels? "clean look"? adequate leg room? Ideal speaker angle/location?
MAIMAS... read it backwards
(.o\ ! /o.) 62 chopped, dropped, cal looked, oval grafted, 57 styled, ragtop with polk audio sound system, driven daily by an 18 year old
A must read for understanding tires sizes and wheel offsets
Go Bears!!! Mech E
glandnut
40 horses of Fury
glandnut is offline
PostPosted: Fri Jun 20, 2008 10:43 pm    Post subject: Reply with quote
Put one speaker in the stock drivers location (behind the dash grille), then fabricate a baffle board holding another speaker so when you open the glove box you have your front soundstage. Only option other than your door panels or the other panels you don't want. Maybe a parcel tray with some component speakers in little boxes sitting on it?
Looking for aluminum single port Kadron manifolds.
MikeBock
MikeBock is offline
PostPosted: Sat Jun 21, 2008 5:00 pm    Post subject: Reply with quote
I did not want kick panels either so I made my own that work great....check them out:
Just cut some sheet metal, cut to fit and installed shallow Infinity speakers. They are right behind the Map cutout so sound is unaffected but still covered by light material.
The below handles the mids, the tweets, mid/lows and 10 in sub in custom speaker box in rear. Powered by 700 wats amp.
Perfect for what I was looking for....crystal clear to bumpin hard
"Every day above ground is a good day.....keep it all in perspective!"
"There's no such thing as bolt-on"
My 57 Ragtop and 65 Sunroof
http://s618.photobucket.com/albums/tt270/Timbockhold/
Maimas13
Maimas13 is offline
PostPosted: Sat Jun 21, 2008 6:03 pm    Post subject: Reply with quote
Just curious, why do you guys not like the kick panels?
Go Bears!!! Mech E
MikeBock
MikeBock is offline
PostPosted: Sat Jun 21, 2008 6:13 pm    Post subject: Reply with quote
I guess just want the clean look and need the most leg room possible. Nothin wrong with them though.
andk5591
andk5591 is offline
PostPosted: Sat Jun 21, 2008 6:25 pm    Post subject: Reply with quote
For me - (front kick panel speakers) - I am trying to keep the interior a "stock looking" as possible. My rear speakers are in the rear kick panels as well. You really don't notice any speakers unless you look. I went so far as to use an MPs player that sits in the ash tray when you pull it out - so there is no head unit in the dash or even in the glove box. Amp is hidden under passenger front seat. It all depends what trips your trigger. And the best part is that my set up sounds really good and was relatively inexpensive.
sano66
sano66 is offline
PostPosted: Sat Jun 21, 2008 8:32 pm    Post subject: Reply with quote
I personally like the uncluttered look of a stock style interior.
