Bus Gadgets, here's two
Page: 1, 2, 3  Next
Opossum
Opossum is offline
PostPosted: Thu Jul 10, 2008 5:11 pm    Post subject: Bus Gadgets, here's two Reply with quote
I like all the gadgets and accessories for the bus. Ez Gruv's outside the bus table is a great idea, the tiki torch holders are cool, and even the pantograph rear window wiper is good (If you live where it rains). Here are a couple, I made this week, to make camping a little easier:
We get things out of this compartment mostly here, through the top. I usually use my shoulder, no more!
This hanger is also good to dry out towels and is easy to make.
Two sprinkler parts:
Just cut a couple notches and screw together.
I'd like to see what other "gadgets" have been made.
"Stay Air-Cooled my friends"
"You can lead an aircooled to water, but you can't make it drink"
"Live and learn or crash and burn"
"It's only Cool, If it's Air-Cooled"
Virginia Whiteface (Opossum) the first VW
Camper Special Club Member
1973 Orange Westfalia Hard top, Original owner
Karl
Karl is offline
PostPosted: Thu Jul 10, 2008 5:45 pm    Post subject: Reply with quote
I don't remember if 1973 Westies have them, but 76-79 Westies have the seat bottom hold-up when open factory installed. It is on the left side hinge. It swings down and rests on the round thing when you are not using it. Up, it rests against the rubber stop on the lower right screw.
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Thu Jul 10, 2008 5:47 pm    Post subject: Re: Bus Gadgets, here's two Reply with quote
Opossum wrote:
My bus has one of these stock. Its on the left hand side of the seat.
Edit: Karl to the rescue with a photo!
Eric
1977 Deluxe Westfalia - 2.0L FI Type IV, Completely Original
Photographer for HotVWs, VolksWorld, AirMighty, VW Camper & Commercial, Hayburner, and more.
My Photography Page.
Kirwin
Kirwin is offline
PostPosted: Thu Jul 10, 2008 5:48 pm    Post subject: Reply with quote
I was going to mention the hold-up brace. I like the hanger deal though. That was ingenious.
1978 VW Transporter (DLNDBUS)
Rubber Duck
Rubber Duck is offline
PostPosted: Thu Jul 10, 2008 6:06 pm    Post subject: Reply with quote
My 74 has something like that Karl...complete with the rubber stopper thingy.
Rubber Duck
1974 Westfalia
WendyArmbuster
WendyArmbuster is offline
PostPosted: Thu Jul 10, 2008 6:41 pm    Post subject: Reply with quote
I'll be danged. All this time and I never noticed the hold up bracket. I just went out to the garage and checked it, but it only holds the seat up a little. Mostly the seat wants to fold into a bed when resting on the brace.
I think the lantern hanger is freaking cool.
whip618
whip618 is offline
PostPosted: Thu Jul 10, 2008 6:51 pm    Post subject: Reply with quote
Here is a set of homemade awning brackets that use regular tent poles, the brackets slide into the jack points and when the awning is taunt enough just snug down the cap screws. It isn't a huge awning but it does the job and is easy to set up.
Phil
Life is simple....either you're qualified or you're not.
USSVI.......Pride Runs Deep
USSVI Life member and Holland Club member
Samba Member No. 3307
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Thu Jul 10, 2008 6:52 pm    Post subject: Reply with quote
Me too! And it should be easy enough to fabricate!
Eric
fusername
fusername is offline
PostPosted: Thu Jul 10, 2008 7:29 pm    Post subject: Reply with quote
that gutter thing is up next on my list of thingies to build.
and an awning based off the jack points... that gives me reason to weld mine back together!
CustomBusBits@Gmail.com
Need something custom bent up? shoot me an email, maybe we can make it work!
FORSALE: Thrust cut T4 and 1.9 main bearings
obnoxiousblue wrote:
Maybe Ben Pon's ghost comes and vomits NOS stampings for your bus, but not mine!
Karl
Karl is offline
PostPosted: Thu Jul 10, 2008 8:05 pm    Post subject: Reply with quote
What is wrong with yours? I took the picture with it holding the seat up farther then his wood piece. There is a built-in ratchet to keep the seat from going into a bed.
Wildthings
Wildthings is offline
PostPosted: Thu Jul 10, 2008 8:54 pm    Post subject: Reply with quote
Not wanting to burst anyone bubble, but that bracket for the lantern looks way to flimsy to me, especially if someone where to smack it as they passed. The plastic extending over the lantern isn't so cool either, as gas lanterns get damn hot. Buy a battery operated light if you want to use it or stick with just using it for the flag, we don't want to see a thread about your bus burning.
Opossum
Opossum is offline
PostPosted: Thu Jul 10, 2008 9:53 pm    Post subject: Reply with quote
Karl and EZ gruv, thank you. I had to go out and look . My bus does not have the hold for the bed, I guess after 1973, VW figured it was needed.
The gutter hanger does not have to be for a gas lantern, if you do not feel it is safe. I know that it is safe cause I bumped it from every direction. Like you said you can use it for battery operated lanterns. It has many other uses; my wife and I will mostly use them for drying out towels.
tubdub
tubdub is offline
PostPosted: Thu Jul 10, 2008 10:04 pm    Post subject: a Reply with quote
how long is that gray piece of pipe?
Opossum
Opossum is offline
PostPosted: Thu Jul 10, 2008 10:08 pm    Post subject: Reply with quote
12"
tubdub
tubdub is offline
PostPosted: Thu Jul 10, 2008 10:15 pm    Post subject: a Reply with quote
thanks
jtauxe Premium Member
jtauxe is offline
PostPosted: Fri Jul 11, 2008 7:11 am    Post subject: Reply with quote
Here's the lantern holder I rigged up. Works great!
Here it is in the stowed configuration. The boom is a solid 1/2" x 3/4" aluminum bar, which just happens to fit perfectly inside the rectangular cross-section Thule rack. The pin holds it in place. The eye and the end of the bar is for clipping on a pulley, and another pulley clips onto the little flat-bar-eye that is mounted to the roof just forward of the rack.
and here deployed:
It ties off at a small cleat mounted to the pillar.
John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus
, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
thewalrus
Big Jack
thewalrus is offline
PostPosted: Fri Jul 11, 2008 7:20 am    Post subject: Re: Bus Gadgets, here's two Reply with quote
Opossum wrote:
Ya know...all this time of holding the seat up with my back/shoulder it never crossed my mind to put something in there to hold the seat up!! Brick wall That would be perfect on my '71....thanks for saving my back!!
'73 Transporter 1.7L Dual Carb
notchboy wrote:
You ran over some #Vanlife'ers hopes and dreams?
60vwnewengland wrote:
Looking forward to next weekend, weed, krunk juice, hookers, blow, hanging with bums, philly, ...the awards!
barrysmith
barrysmith is offline
PostPosted: Fri Jul 11, 2008 9:18 am    Post subject: Reply with quote
Phil
that looks handy as hell,did you use pre existing parts off something or make em in a machine shop Phil?
Great ideas in this thread!
vdubadm
vdubadm is offline
PostPosted: Fri Jul 11, 2008 9:42 am    Post subject: Reply with quote
holy crap I love that lantern idea!!!!!!
Hippopotabus
Hippopotabus is offline
PostPosted: Fri Jul 11, 2008 9:48 am    Post subject: Reply with quote
Opossum - Great idea and thanks. Getting sick and tired of smackin my head while climbing into the seat storage space.
Also - will be creating one of these lantern arms.
Nice job.
Celer, Silens, Letalis
www.2dreconbn.net
Page: 1, 2, 3  Next
