Bluetork Samba Member
Posted: Mon Jul 21, 2008 2:37 pm Post subject: 1972 bay conversion |
I am transferring a 2000cc upright engine in to my 1972 bus. I have figured out the engine tin but how do i support the engine on the under bar. Do i need to modify that as well? if any one has i would like to know in detail how you did this. |
jah_B Samba Member
Joined: March 18, 2008 Posts: 1147 Location: Tempe, AZ
Posted: Mon Jul 21, 2008 2:45 pm Post subject: |
a quick search of "engine mount conversion" yields a lot of results...and nobody will get pissed off cause you asked an old question! _________________ 1984 CABRIOLET 6spd, quaife diff, Neuspeed springs, sway bars, tie bar, short shift kit, bilstein shocks, 16X7 RSE 3pc wheels, BFG TA 205 40s
1972 tintop P30 CAMPMOBILE: M/T, 1.7L, dual kadrons, 019 diz. Sunny the S'kool Bus
You gotta know what you don't know. That's the key to wisdom. man. |
TRN9 Samba Member
Joined: September 29, 2006 Posts: 309 Location: Where its rainy
Posted: Mon Jul 21, 2008 7:53 pm Post subject: |
When your "2000cc upright motor" dies put back what should be in there....... TYPE IV! |
calebmelvin Samba Member
Joined: July 19, 2006 Posts: 3140 Location: Seattle, WA
jah_B Samba Member
Posted: Wed Jul 23, 2008 4:53 am Post subject: |
There's an adapter plate that attaches to the rear of the case from the moustache bar. no big, isn't AS solid, but reportedly would only break under ridiculous circumstances. _________________ 1984 CABRIOLET 6spd, quaife diff, Neuspeed springs, sway bars, tie bar, short shift kit, bilstein shocks, 16X7 RSE 3pc wheels, BFG TA 205 40s
Blaubus Samba Member
Posted: Wed Jul 23, 2008 6:24 am Post subject: |
http://www.thesamba.com/vw/classifieds/detail.php?id=255240
that plate will bolt to the case at the oil pump. this ad should include the filler plate, but doesnt. i have one of these spare, which i could send you, as i dont have the rest of it.
these adaptors are known to promote oil leakage, but you can solve that by:
1) using german studs (plate needs longer than stock)
2) grinding back the ears of the pump cover to clear the filler plate thickness
3) smearing a very thin layer of permatex aviation gasket sealer to the thin gasket between the pump and its cover. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51163 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Jul 23, 2008 6:35 am Post subject: |
That's still not going to make a type 1 bolt up to a type 4 moustache bar, you'll need a 68-71 bar and something to adapt it to the later frame rails. Or a 72-79 1600 moustache bar and mounts (good luck finding one in North america, uber rare). _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
jah_B Samba Member
Posted: Wed Jul 23, 2008 6:40 am Post subject: |
Really? I thought that that was the whole point of the adapter plate, to bolt to a TIV moustache bar... oh, ok. _________________ 1984 CABRIOLET 6spd, quaife diff, Neuspeed springs, sway bars, tie bar, short shift kit, bilstein shocks, 16X7 RSE 3pc wheels, BFG TA 205 40s
Posted: Wed Jul 23, 2008 6:57 am Post subject: |
A plate does exist to do it, I saw one on a bus a couple of years ago, shoulda taken a pic.. It attached to the 3 case lugs and had the saddles for the angled rubber mounts, it was well constructed and cad plated, definitely not a one off effort.
Edit; Went digging in the gallery for the 71 bus I saw it on, found a pic of it when it still had the DTM type 4 installed (I saw it with a type 1 reinstalled after the hack), the mount plate looks very similar and seems to have holes for the type 1 lugs too, I thought it used stock rubber mounts though, Hmmmmm.
Слава Україні!
jah_B Samba Member
Posted: Wed Jul 23, 2008 7:05 am Post subject: |
There's this one.....
http://www.thesamba.com/vw/forum/viewtopic.php?t=283360 _________________ 1984 CABRIOLET 6spd, quaife diff, Neuspeed springs, sway bars, tie bar, short shift kit, bilstein shocks, 16X7 RSE 3pc wheels, BFG TA 205 40s
Posted: Wed Jul 23, 2008 7:11 am Post subject: |
That's what Dan has, very handy if your engine does not have the lugs to mount an upright moustache bar but no help attaching it to the type 4 bar. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
jah_B Samba Member
Posted: Wed Jul 23, 2008 8:09 am Post subject: |
OIC! _________________ 1984 CABRIOLET 6spd, quaife diff, Neuspeed springs, sway bars, tie bar, short shift kit, bilstein shocks, 16X7 RSE 3pc wheels, BFG TA 205 40s
