Fuch wheel question
65 vert
65 vert is offline
PostPosted: Sat Apr 03, 2004 8:44 pm    Post subject: Fuch wheel question Reply with quote
Im buying a set of 15 X 6 replica fuch to put on my 65 beetle, since I have original brake drums I will need adapters, the question is, will the tires come out too far out from the fenders?, or I will need to convert my car to disk brake, I know somebody must have done this before, any pics of cars so I know how mine will look with the 6" and adapters, any advise, thanks,
Skim
Rants Master
Skim is offline
PostPosted: Sat Apr 03, 2004 9:25 pm    Post subject: Reply with quote
The adapters will make the wheels stick out an inch. Drop spindles do push the wheels out a little. Your best bet is to run porsche pattern drums in the rear and disk up front drilled to porsche pattern and I would suggest atleast a 3" narrowed beam. Also what size front tires are you planning to run? Id contact CB Performance or Old Speed for all those parts.
GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
65 vert
65 vert is offline
PostPosted: Sun Apr 04, 2004 6:45 am    Post subject: fuch & adapters Reply with quote
Thanks for your valable information, IM using stock spindles for now, I just dont want the tires to stick out too much if at all, Did yousay that the tire will be 1" out of the fender? any way I could drill the drums?
vdub59
vdub59 is offline
PostPosted: Wed May 05, 2004 4:19 pm    Post subject: WATCH OUT FOR CB Reply with quote
hI THERE,
WHAT EVER YOU DO, IF YOU BUY FROM CB PERFORMANCE DISC BRAKES MAKE SURE YOU GET THE NEWEST DROP SPINDLES THAT ARE NOT WELDED. I GOT THEM AND THEY PUSH OUT AN INCH.
WATCH OUT FOR THE REAR DISC, WHICH THEY DO THE SAME, PUSH OUT MORE. THEY DONT TELL YOU THIS, UNTIL YOU FIND OUT ON YOUR Very Happy OWN.
ON THE DRUMS YOU CAN GET THEM DRILLED AT A MACHINE SHOP, AND HAVE THEM PRESS IN THE STUDS.
Very Happy
WharfRat
WharfRat is offline
PostPosted: Sun May 09, 2004 9:18 pm    Post subject: Reply with quote
chill with the caps lock, dude.
56_in_714
56_in_714 is offline
PostPosted: Mon May 10, 2004 12:10 pm    Post subject: Reply with quote
Check out blimp. They got porsche pattern drums for you ride for like 29 bucks. http://56bug.com/Brakes1.html
