Type 1 front end in a type 3, dis/advantages, obstacles?
red_6
red_6 is offline
PostPosted: Wed Jul 30, 2008 3:37 pm    Post subject: Type 1 front end in a type 3, dis/advantages, obstacles? Reply with quote
Hello,
I'm putting a parts-car '73 fastback on the road with spare parts for use in a rally-cross race circuit here in Colorado.
I need the front end that's in it for my wife's 68 and hers may be too rusty/bent to use even for racing.
Does anyone make new replacement or upgrade torsion tubes/bars setups for type 3?
If not, does a new type 1 or sand-rail front end like those sold by some of the banner sponsors here drop in? If so what are the advantages/disadvantages to that set-up in regards to handling?
If not, what modifications are required to pull it off?
I likely will not lower it unless handling benefits dictate it (which so far I have not see to be the case).
any other ideas?
Thanks in advance.
ETPEak
ETPEak is offline
PostPosted: Wed Jul 30, 2008 3:46 pm    Post subject: Reply with quote
no bolt in conversions persay but KCW makes a link pin type with adjusters etc... I have several stock beams I would sell ya cheap but getting them there would kill ya.... I am taking a different aproach in my type 3 but untiil I see if it works I am hush on it.... link pin is the way most are going.. ease of parts avaible drop dpindles narrowed front etc so search the forum there are a bunch of pics in here about the subjuct
red_6
red_6 is offline
PostPosted: Wed Jul 30, 2008 3:52 pm    Post subject: Reply with quote
Thanks! Very Happy Very Happy Very Happy
ETPEak
ETPEak is offline
PostPosted: Wed Jul 30, 2008 3:53 pm    Post subject: Reply with quote
no problem... how is your car set up? are you all hacked up wheel wells cut wide open big mtor?
red_6
red_6 is offline
PostPosted: Thu Jul 31, 2008 9:01 am    Post subject: Reply with quote
First year out we'll likely just run stock class with a 1600, 34 webers, standard trans and whatever front end I can find to cram in there that will work well.
If we think we need or would enjoy it, we may go nuts after next season with performance (see SI motor thread)
cheers,
Scott
Erik G
Erik G is offline
PostPosted: Thu Jul 31, 2008 10:39 am    Post subject: Reply with quote
i like the narrowed front that the type 1 style beam provides, along with the ease of installing 5 lug discs, but you will definetly lose in the handeling dept. they are quite a bit more narrow, and the torsion bars are weaker. for auto crossing, or any serious high performance car, i would stick with the stock type 3 beam, hands down
josh
josh is offline
PostPosted: Thu Jul 31, 2008 1:20 pm    Post subject: Reply with quote
In terms of performance the type3 beam is superior both in handling and ride department.
But in terms of availability the type3 is at a huge disadvantage both for stock and aftermarket parts.
I don't know what rally-cross is. For auto cross I would go with a type3 beam. If it's like rally racing and you're likely to bend beams doing crazy off road stuff I would go type1 just because new beams are cheap and easy to find.
On the other hand if the rally portion is just dirt/gravel road type stuff I don't the you would be damaging the beam anyway. It's pretty tough.
modok wrote:
...If If stoner A takes a hit and then stoner B goes right away(not waiting two seconds), he's trying to suck on it while it's still got a vaccum, doesen't get much of a hit at all! Cause it hasn't filled back up all the way yet.
Stoner A is cylinders #2/4 B is #1/3 The plugged bowl is the throttle, the bong is the manifold
ETPEak
ETPEak is offline
PostPosted: Thu Jul 31, 2008 2:43 pm    Post subject: Reply with quote
I have 3 or 4 type 3 beams in different stages of tear down, if you need parts or a replacement, let me know, I do not need all these beams
red_6
red_6 is offline
PostPosted: Thu Jul 31, 2008 4:28 pm    Post subject: Reply with quote
The rally cross here in Colorado is almost always on a flat gravel lot with a corse laid out in cones... there's no jumps or curbs or even large holes to deal with but our friends have gotten their rabbit on the two side wheels before and have bent up their control arms doing it.
I think it will take us a couple years of experience before getting to that level but even then I doubt the rear-engine, rear drive set up will be nearly as hard on the front end.
flip side is that the front will have to be 'just so' for the rear/rear setup to be handle really well in gravel.
The 67 I had after Highschool was killer in the snow,gravel, grass and even on paved it seemed like on the right on/off ramp i could get a nice controlled drift or atleast a consistant howl from the rear tires under throttle.
I'd like to recreate that experience... Twisted Evil
and dude, i'm very interested in one of your T3 front ends, I'm not toooo far from Pheonix
