Missing Brake Bolts
Ponder
Ponder is offline
PostPosted: Thu Aug 14, 2008 5:05 pm    Post subject: Missing Brake Bolts Reply with quote
I have an 86 vanagon westfailia with the girling 60 calipers, and I'm wondering where I can find the 22mm bolts that hold the carriers to the hub?
mr_vanagon
mr_vanagon is offline
PostPosted: Thu Aug 14, 2008 5:21 pm    Post subject: Reply with quote
I'd say check with the local VW dealer. I know I've gotten caliper guide pins and the 10 mm bolts that hold them in place. Can't see the caliper carrier bolts being a problem for the stealer.
'68 Autostick Bug Mom bought new
'89 Tintop Vanagon Dad bought new
syncrodoka
syncrodoka is offline
PostPosted: Thu Aug 14, 2008 6:08 pm    Post subject: Reply with quote
I think that he is looking to buy bolts for the custom audi brakes that can be modified for use in the vanagon. The clue is he mentioned girling 60 I was told that M16x70 is a better fit then the ones listed on the site. http://www.syncro.ca/tech/audibrakes.htm
Ponder
Ponder is offline
PostPosted: Thu Aug 14, 2008 6:20 pm    Post subject: Reply with quote
No, sorry I'm looking for the oem bolts. I know these vans came with ate and girling calipers, I thought they were girling 60 calipers, maybe they're called something else I don't know. Wasn't sure if they used different bolts or something. They're big old bolts with a 22mm head on them. I'll try calling the stealership tomorrow and seeing what luck I have with them. Or else try and find some new bolts or used ones from someone?
syncrodoka
PostPosted: Fri Aug 15, 2008 2:48 pm    Post subject: Reply with quote
VW part number N90499301. For a 2wd vanagon
http://busdepot.com/details.jsp?partnumber=N90499301
